Home » Eclipse Projects » NatTable » programmatically calling keyEvents or other way for opening build in Dialogs
programmatically calling keyEvents or other way for opening build in Dialogs [message #1749940] Wed, 14 December 2016 02:59 Go to next message
I need to open dialogs, which are already implemented on nattable.
CTRL+F -> search
CTRL+E -> Export to Excel
etc...
but i need to do this via Code.
how can i do so?
i searched for a away to forward my keyEvents to natTable or to run a doCommand. but i did not find out how to do this.
any informations how i could achieve this?
thanks in advance!
Re: programmatically calling keyEvents or other way for opening build in Dialogs [message #1749943 is a reply to message #1749940] Wed, 14 December 2016 03:20 Go to previous messageGo to next message
For export you just need to execute the corresponding ExportCommand.
For searching you could try to create a SearchAction and call run()
Re: programmatically calling keyEvents or other way for opening build in Dialogs [message #1749946 is a reply to message #1749943] Wed, 14 December 2016 03:54 Go to previous message
excellent.
thanks for the rapid answer.
works!
Previous Topic:Mass update of Groupby table with Regular Expession is not working.
Next Topic:[NatTable]how to add icon in each column header?
Current Time: Sun Nov 09 12:13:24 EST 2025
Powered by FUDForum. Page generated in 0.18172 seconds
