Re: CDT Remote Debugging/Launching [message #1750352 is a reply to message #1750348] |
Tue, 20 December 2016 10:18 |
Martin Schend Messages: 5 Registered: December 2016 |
Thank you! I did already suspect this is some kind of timing problem. I've also tried using Eclipse Luna instead of Neon which also fails
but you kind of see what happens because it displays the console output. It does send all commands at some point but they are not executed (as if
no one ever presses return after the command).
So I think we have to conclude that neither the TCF nor the SSH launcher work without code modifications which, as far as I know, leaves me without
any option to do automatic remote GDB debugging. I'm quite surprised so few of us seem to actually use this as I've found hardly anything about this on the internet.
[Updated on: Tue, 20 December 2016 10:19] Report message to a moderator
FUDForum. Page generated in 0.04060 seconds
