Re: Unhandled event loop exception error [message #1750048 is a reply to message #1749856] |
Thu, 15 December 2016 08:01  |
for more detaile about the error I mentioned above this is the content of my .log file:
!ENTRY org.eclipse.epsilon.common.dt 1 0 2016-12-15 23:50:32.018
!MESSAGE Metamodel \FirstProject\Metamodel\Tree.ecore registered successfully
!ENTRY org.eclipse.epsilon.common.dt 1 0 2016-12-15 23:50:34.130
!MESSAGE Metamodel \FirstProject\Metamodel\Graph.ecore registered successfully
!ENTRY org.eclipse.ui 4 0 2016-12-15 23:50:42.799
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.epsilon.haetae.ast2exl.AbstractAST2ExLAction.run(AbstractAST2ExLAction.java:53)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:247)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
!ENTRY org.eclipse.ui 4 0 2016-12-15 23:50:45.982
!STACK 0
!ENTRY org.eclipse.ui 4 0 2016-12-15 23:50:49.262
!STACK 0
[Updated on: Fri, 16 December 2016 03:11] by Moderator
FUDForum. Page generated in 0.03149 seconds
