| Post-Buildstep no .bin file [message #1749477] |
Wed, 07 December 2016 03:50  |
I am stuck here and cant realy find any solution that works. Ive been stuck on this for days.
I am using eclipse neon with CDT and working on ARM project.
I specified a post build command to start batchfile to run an exe file. But the exe can not find the binary file, because the binary file is only generated after the exe has finished. I already treid to start the exe via batchfile and "start" command but that simply kills the exe when the build process is done. So I need to run my command after the bin file is generated.
How can I achieve this? It seems a little strange that the post build step is not post at all.
FUDForum. Page generated in 0.07492 seconds
