Home » Language IDEs » C / C++ IDE (CDT) » How to reset running program?(program reset )
How to reset running program? [message #1749361] Mon, 05 December 2016 15:05 Go to next message
I have a simple test program, runs fine and terminates as far as I can tell.
But when I try to "run" it again I get a message " my program ( already running)".
About the only way I can restart it is to change something, than "Build All" , than I can do "Run" again.
int main( int argc, char* argv[])
cout << "!!!Hello World!!!" << endl; // prints !!!Hello World!!!
int value = 50;
int value2 = 0;
// namedWindow("main1",WINDOW_AUTOSIZE | WINDOW_OPENGL);
namedWindow("main2",WINDOW_OPENGL);
namedWindow("main3",WINDOW_AUTOSIZE);
waitKey(0);
destroyAllWindows();
//help();
return (0);
Re: How to reset running program? [message #1749363 is a reply to message #1749361] Mon, 05 December 2016 15:53 Go to previous messageGo to next message
Where do you get the message already running from? Is it an error or a hover over the run (or debug) button like this:
index.php/fa/27788/0/
If it is like that screenshot it means you have not terminated your last run/debug session. It is not an error, just a reminder that you still have it running. It is not an error because you can run the same program multiple times if you want to.
So you should terminate the program first (press the red square in the toolbar or on the console view):
index.php/fa/27787/0/
Re: How to reset running program? [message #1749366 is a reply to message #1749363] Mon, 05 December 2016 16:00 Go to previous messageGo to next message
It is a "tool tip" style message when I position mouse over "Run".
Were should I see this "red button" to terminate the run?
Sorry, just noted I should look at console view / output. Will try that.
My test program is designed to terminate / return when I press any key on keyboard.
[Updated on: Mon, 05 December 2016 16:02] by Moderator
Re: How to reset running program? [message #1749370 is a reply to message #1749366] Mon, 05 December 2016 16:59 Go to previous message
Glad you made some progress.
OK, I guess you have identified an issue here. Is waitKey listening on stdin or on a key pressed in a window. If it is on stdin then you should note that the console view in Eclipse is a line-buffered console. Nothing is sent to the program until Enter is pressed.
Previous Topic:no underscore in Oxygen edit view
Next Topic:Problem with eclipse while running simple c program
Current Time: Thu Sep 25 00:07:49 EDT 2025
Powered by FUDForum. Page generated in 0.04294 seconds
