Re: Bring Connection shape to front (z-index) [message #1749395 is a reply to message #1749392] |
Tue, 06 December 2016 08:56 |
Jerome Sivadier Messages: 15 Registered: May 2015 |
Edit: I though I had discovered where to look for the bug, actually not...
If you could spend some time on this issue Michael it would be really great! Test case is just to have 2 connections one above the other and to select the lowest one. I'd like to push the selected connection to the Front to see the selected shape .
I'll investigate a bit more on this issue later on and try to find a fix, this will be a blocking issue for my project around mid-january.
Thx!
[Updated on: Tue, 06 December 2016 16:55] Report message to a moderator
FUDForum. Page generated in 0.02981 seconds
