Home » Eclipse Projects » Subversive » Could not acquire the framework manipulator service(Eclipse Neon throwing "Software Installation" while installing "Subversive SVN Team Provider": 4.0.2.I20160902-1700)
Could not acquire the framework manipulator service [message #1748977] Wed, 30 November 2016 11:37 Go to next message
Posting in the Subversive forum as suggested..
I have using the eclipse Neon version recently for pulling out some code from the svn repository. When i am trying to install the "Subeversive SVN Team Provider" by following this link "https://eclipse.org/subversive/installation-instructions.php" , I am getting the following error. I found one similar problem in the equinox version which suggested changing the "startLevel". But couldn't find the file to change. Any help in this regard will be of great help.
An error occurred while installing the items
session context was:(profile=_home_bishnu_eclipse_jee-neon_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]org.eclipse.team.svn 4.0.2.I20160902-1700, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction).
Could not acquire the framework manipulator service.
Environment details:
OS - Ubuntu 16.04
Eclipse version - Version: Neon Release (4.6.0)
Build id: 20160613-1800
Bishnu
[Updated on: Wed, 30 November 2016 11:38] by Moderator
Update : Could not acquire the framework manipulator service-[More Logs] [message #1749090 is a reply to message #1748977] Thu, 01 December 2016 12:48 Go to previous messageGo to next message
Below are the logs for this operation. I will probably do some more digging. But any pointers will be really appreciated.
!ENTRY org.eclipse.equinox.p2.core 4 0 2016-12-01 22:47:23.503
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at https://github.com/subclipse/subclipse.git.
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:395)
	at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:116)
	at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.fail(CachingRepositoryManager.java:314)
	at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:217)
	at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:437)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
	at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:117)
	at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:102)
	at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:83)
	at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2016-12-01 22:47:23.505
!MESSAGE No repository found at https://github.com/subclipse/subclipse.git.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2016-12-01 22:47:40.429
!MESSAGE Connection to http://http/download.eclipse.org/technology/m2e/releases/p2.index failed on http: unknown error. Retry attempt 0 started
!STACK 0
java.net.UnknownHostException: http: unknown error
	at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
	at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:928)
	at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1323)
	at java.net.InetAddress.getAllByName0(InetAddress.java:1276)
	at java.net.InetAddress.getAllByName(InetAddress.java:1192)
	at java.net.InetAddress.getAllByName(InetAddress.java:1126)
	at org.apache.http.impl.conn.SystemDefaultDnsResolver.resolve(SystemDefaultDnsResolver.java:44)
	at org.apache.http.impl.conn.DefaultClientConnectionOperator.resolveHostname(DefaultClientConnectionOperator.java:259)
	at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:159)
	at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:144)
	at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:131)
	at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:611)
	at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:446)
	at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:863)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
	at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1084)
	at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1075)
	at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:1071)
	at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:74)
!ENTRY org.eclipse.equinox.p2.core 4 0 2016-12-01 22:47:40.651
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unknown Host: http://http/download.eclipse.org/technology/m2e/releases/content.xml
	at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:243)
	at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66)
	at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
	at sun.reflect.GeneratedMethodAccessor59.invoke(Unknown Source)
	at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:370)
	at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:177)
Caused by: java.net.UnknownHostException: http
	at java.net.InetAddress.getAllByName0(InetAddress.java:1280)
	at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:304)
	at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:263)
	at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
	... 1 more
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1006 2016-12-01 22:47:40.653
!MESSAGE Unknown Host: http://http/download.eclipse.org/technology/m2e/releases/content.xml
!STACK 0
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2016-12-01 22:48:33.969
!STACK 0
!ENTRY org.eclipse.equinox.p2.engine 4 4 2016-12-01 22:49:05.662
!MESSAGE An error occurred while installing the items
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2016-12-01 22:49:05.663
!MESSAGE session context was:(profile=_home_bishnu_eclipse_jee-neon_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]org.eclipse.team.svn 4.0.2.I20160902-1700, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction).
!MESSAGE Could not acquire the framework manipulator service.
!STACK 0
java.lang.IllegalStateException: Could not acquire the framework manipulator service.
	at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManipulator.loadDelegate(LazyManipulator.java:45)
	at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManipulator.getConfigData(LazyManipulator.java:108)
	at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction.installBundle(InstallBundleAction.java:75)
	at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction.execute(InstallBundleAction.java:32)
	at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisioningAction.execute(ParameterizedProvisioningAction.java:38)
	at org.eclipse.equinox.internal.p2.engine.Phase.mainPerform(Phase.java:183)
	at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:95)
	at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
	at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
	at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
	at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:175)
	at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79)
[Updated on: Thu, 01 December 2016 12:54] by Moderator
Re: Update : Could not acquire the framework manipulator service-[More Logs] [message #1750838 is a reply to message #1749090] Thu, 29 December 2016 14:36 Go to previous message
Hi!
It seems there is a problem with your Eclipse Neon instance. Most likely it will cause issues not just with Subversive, but with different tools too, since it looks like its registry is broken. In order to solve the problem I would like to recommend you to reinstall your Eclipse instance.
Previous Topic:How to enforce checkout with 1.7 working copy format?
Next Topic:JavaHL on 64bit Windows
Current Time: Tue Oct 28 16:27:07 EDT 2025
Powered by FUDForum. Page generated in 0.05277 seconds
