Home » Modeling » TMF (Xtext) » How to override and extend the JvmModelGenerator to generate complex enumerations(Is this the right way to solve the Problem?)
How to override and extend the JvmModelGenerator to generate complex enumerations [message #1747355] |
Sun, 13 November 2016 14:16 |
Thomas Kohler Messages: 15 Registered: November 2016 |
I'm working on a xbase based dsl using the JvmModelInferrer and I'm surprised how much functionallity works out of the box when using this concept!
Unfortunately I found out that the JvmModel and JvmModelGenerator does not support more complex Java Enumerations (also in xtend), so I started to enhance the framework to support them as I expect it.
To generate Java code for the content of the additional values for an enumeration instance I need to transform a XExpression to Java code when defining the body of a JvmEnumerationLiteral. To hook into this point I started overriding the JvmModelGenerator and I got following problem:
Question 1)
When using the Type org.eclipse.xtext.xbase.compiler.JvmModelGenerator I always get the following warning:
Discouraged access: The type JvmModelGenerator is not accessible due to restriction on required project
com.generali.fipos.dsl
This happens in
* generated by Xtext 2.10.0
package my.dsl
import org.eclipse.xtext.xbase.compiler.JvmModelGenerator
* Use this class to register components to be used at runtime / without the Equinox extension registry.
class MyRuntimeModule extends AbstractFiposRuntimeModule {
override bindIGenerator() {
MyJvmModelGenerator
as well as in
package my.dsl.compiler
class FiposJvmModelGenerator extends JvmModelGenerator {
Is this a problem and is the reason the restriction in the manifest of the plugin containing the original generator?
Question 2)
Is the a better way to solve my root problem? I try to describe enums as defined in the following grammar snippet:
EnumDef:
'enum' name=ValidID
('implements' interfaces+=(JvmParameterizedTypeReference)(',' interfaces+=(JvmParameterizedTypeReference))*)?
'(' (params+=FullJvmFormalParameter (',' params+=FullJvmFormalParameter)*)? ')' '{'
(enumEntries+=EnumEntry ','?)*';'?
(enumInits+=EnumInit)*
(ops+=Operation)*
EnumEntry:
name=ValidID (code=INT? & text=STRING?) ('(' values+=XExpression (',' values+=XExpression)* ')')?
EnumInit:
'init' '(' (params+=FullJvmFormalParameter (',' params+=FullJvmFormalParameter)*)? ')' body=XBlockExpression
enum OperationType:
OP='func' | STATIC='stat'
Operation:
optype=OperationType (type=JvmTypeReference)? name=ValidID
The following DSL-Code matches this grammar:
enum EModality(boolean visible, boolean enabled) {
mandatory 1 "Pflicht" (true)
optional 2 "Optional" (true, true)
forbidden 0 "Verboten"
dummy
init(boolean visible) {
// The following commented code would be better but JvmModelInferrer currently does
// not define 'this' for calling an other defined constructor in constructor body..
/* this(visible, false) */
this.visible = visible
this.enabled = false;
init() {
/* this(false, false) */
visible = false
enabled = false
func editable() {
visible && enabled
And should produce a Java code like:
package core;
@SuppressWarnings("all")
public enum EModality {
/* special columns code and text are handled during generation as additional enum columns and are set to null if not defined */
mandatory(1, "Pflicht", true),
optional(2, "Optional", true, true),
forbidden(0, "Verboten"),
dummy(null, null);
private final Integer code;
private final String text;
private final boolean visible;
private final boolean enabled;
/* Main Constructor derived from signature extended with code and text */
private EModality(final Integer code, final String text, final boolean visible, final boolean enabled) {
this.code = code;
this.text = text;
this.visible = visible;
this.enabled = enabled;
/* Constructor generated from init(boolean visible) with default for 'enabled' */
private EModality(final Integer code, final String text, final boolean visible) {
this(code, text, visible, false);
/* Constructor generated from init() with defaults for both signature parameters */
private EModality(final Integer code, final String text) {
this(code, text, false);
/* If not specified the negative ordinal is used for code */
public Integer getCode() {
return code == null ? -ordinal() : code;
/* If not specified the name is used for text */
public String getText() {
return text == null ? name() : text;
public boolean isVisible() {
return this.visible;
public boolean isEnabled() {
return this.enabled;
/* Additional defined function for enum entry */
public boolean editable() {
return (this.visible && this.enabled);
The main problem is to generate the additional values (as typed in the signature) to the enumeration literals. I've defined them as a XExpression because there should be the possibility not only to enter primitive values as in the example above but also references to other enumeration entries or calls to conversion methods (either using extensions or static methods) to simple enter Dates etc.. I don't need an inner scope of the enumeration class itself, but the scope of the package the enumeration resists in.
What will be the correct Way to convert those XExpressions to Java and where?
Last but not least Question 3)
As mentioned in the comments of the dsl snippet I can't call a constructor in a constructor using the java this(...) - syntax. Xtext alwas says that there is no function called 'this'. Is this a known restriction or a bug?
Thank you in advance,
Thomas.
PS: Is the enhancement of enumerations planned in future xtend versions? I've found some (very old) CRs and comments in the generator code related to this.
Especially for commercial Systems (e.g. Insurances) enums and may be efficient lookups in small (in memory) tables are very important...
Re: How to override and extend the JvmModelGenerator to generate complex enumerations [message #1747434 is a reply to message #1747355] |
Mon, 14 November 2016 16:17 |
hi,
this task wont be that easy.
- currently nobody i working on it nor has it any high priority
- the constructors are not working cause they are filtered at org.eclipse.xtext.xbase.scoping.batch.ConstructorDelegateScope.getLocalElementsByName(QualifiedName)
this can be fixed i think
public class MyFeatureScopes extends FeatureScopes {
protected IScope createConstructorDelegateScope(EObject featureCall, LightweightTypeReference type, IScope parent,
IFeatureScopeSession session) {
return new ConstructorDelegateScope(parent, type, session, asAbstractFeatureCall(featureCall)) {
protected List<IEObjectDescription> getLocalElementsByName(QualifiedName name) {
if (THIS.equals(name) || SUPER.equals(name)) {
IEObjectDescription description = getSession().getLocalElement(name);
if (description != null) {
EObject objectOrProxy = description.getEObjectOrProxy();
if (objectOrProxy instanceof JvmGenericType && !objectOrProxy.eIsProxy()) {
return createConstructorDescriptions(name, (JvmGenericType) objectOrProxy, SUPER.equals(name));
} else if (objectOrProxy instanceof JvmEnumerationType && !objectOrProxy.eIsProxy()) {
return createConstructorDescriptions(name, (JvmEnumerationType) objectOrProxy, SUPER.equals(name));
return Collections.emptyList();
protected List<IEObjectDescription> createConstructorDescriptions(QualifiedName name, JvmEnumerationType type, boolean superType) {
Iterable<JvmConstructor> constructors = type.getDeclaredConstructors();
List<IEObjectDescription> result = Lists.newArrayListWithCapacity(3);
for(JvmConstructor constructor: constructors) {
addToList(createDescription(name, constructor, superType), result);
return result;
- for the literals i think the easiest is to inferr for each literal and parmeter a own method and simpy call these methods in the initializer of the literal
e.g.
public enum Demo {
X(init_x_1()),
Y(init_y_1());
private Demo(String x) {
private static String init_y_1() {
return "x";
private static String init_x_1() {
return "y";
alternatives you can adapt the type computer to compute the types for the expressions
and use xbasecompiler to generator the code for it
that will be tricky and noone has a idea how to make this "nice"
Twitter : @chrdietrich
Re: How to override and extend the JvmModelGenerator to generate complex enumerations [message #1747448 is a reply to message #1747434] |
Mon, 14 November 2016 20:37 |
Hello Christian,
Thank you for your relpy. I'll try to implement the Scope extension.
I know that generating (static) Methods for each expression could be done, but some of our Enumerations are really big and this would be a disaster (Thousends of methods returning mostly a literal).
I managed to come to the place where I could generate the additional values to the Literal:
class MyDslJvmModelGenerator extends JvmModelGenerator {
@Inject extension JvmModelAssociator
@Inject XbaseCompiler compiler
override generateEnumLiteral(JvmEnumerationLiteral it, ITreeAppendable appendable, GeneratorConfig config) {
super.generateEnumLiteral(it, appendable, config)
val pse = primarySourceElement
switch pse {
EnumEntry: {
/* Special handling for EnumEntries */
appendable.append("(")
/* Handle the primary 'code' and 'text' columns */
appendable.append(if(pse.code.empty) "null" else pse.code.get(0).toString);
appendable.append(",")
appendable.append(if(pse.text == null) "null" else {"\"" + pse.text + "\""})
/* Use the Parameter types together with additional values for the other columns */
val enumDef = pse.eContainer as EnumDef
val parameterIterator = enumDef.params.iterator
for(expression : pse.values) {
if(parameterIterator.hasNext) {
val type = parameterIterator.next.parameterType
// XXX this call causes Lightweight Type NPE problems in many constellations ...
// I need at least support for expressions like:
// - null
// - boolean values (true, false)
// - Numeric values (1, 0xFF, 123.45) or maybe Arithmetic expressions (60 * 24, 2^3)
// - String values ("Hello", "World")
// - Enumeration values (EModality.mandatory, EVisibility.invisible)
// - Date values, build using library extensions ("2016-11-14".isodate could generate DateLib.isodate(String isodate))
compiler.compileAsJavaExpression(expression, appendable, type)
appendable.append(")")
- null
All of them result in a simple Java expression with no need for an own method. Which would be the right XExpression Subclass for that?
The Code shown above works for boolean values but not for number values (literals) or enumeration literals. I always get the NPE
900910 [Worker-55] ERROR org.eclipse.xtext.builder.BuilderParticipant - Error during compilation of 'platform:/resource/core.fipos/src/my.dsl'.
at org.eclipse.xtext.xbase.compiler.LiteralsCompiler._toJavaExpression(LiteralsCompiler.java:134)
at org.eclipse.xtext.xbase.compiler.LiteralsCompiler.internalToConvertedExpression(LiteralsCompiler.java:43)
at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.internalToConvertedExpression(FeatureCallCompiler.java:102)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.internalToConvertedExpression(XbaseCompiler.java:317)
at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToConvertedExpression(TypeConvertingCompiler.java:104)
at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToJavaExpression(TypeConvertingCompiler.java:47)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compileAsJavaExpression(AbstractXbaseCompiler.java:225)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compileAsJavaExpression(AbstractXbaseCompiler.java:148)
at mydsl.compiler.MyDslJvmModelGenerator.generateEnumLiteral(MyDslJvmModelGenerator.java:82)
at
public void _toJavaExpression(XNumberLiteral expr, ITreeAppendable b) {
LightweightTypeReference type = getLightweightType(expr);
if(type.isType(BigInteger.class)) { [...]
because getLightweightType() returns null for almost every expression. Do you have a hint for me what the problem could be here?
By the way: What is the reason to call ".copyWithProxies" on JvmTypeReferences in inferrer methods before using them? I saw that in many examples but I did not know the reason.
Thank you,
Thomas
Re: How to override and extend the JvmModelGenerator to generate complex enumerations [message #1748513 is a reply to message #1747456] |
Wed, 23 November 2016 20:55 |
Quote:alternatives you can adapt the type computer to compute the types for the expressions
Please help me once more! If I try to compile the XExpression when generating the additional values in the Enumeration Literal the method
getLightweightType(expression)
always returns null. When I use an expression with the same content in an field initializer the evaluation of the lightweight type works. I debugged the generator and compiler, but I did'nt realize the difference...
I have the correct type as a JvmTypeReference - how can I convert a JvmTypeReference to a LightweightType? What is the meaning of the Lightweight Types?
An ugly fix for Numbers and Strings is to catch the NPE and do the same as the last else which does not need the lightweight type:
try {
super._toJavaExpression(expr, b);
} catch(NullPointerException npx) {
GeneratorConfig config = b.getGeneratorConfig();
if (config != null && config.getJavaSourceVersion().isAtLeast(JAVA7)) {
b.append(numberLiterals.toJavaLiteral(expr, false));
} else {
b.append(numberLiterals.toJavaLiteral(expr, true));
protected void toJavaExpression(XStringLiteral literal, ITreeAppendable appendable, boolean useUnicodeEscapes) {
try {
super.toJavaExpression(literal, appendable, useUnicodeEscapes);
String javaString = Strings.convertToJavaString(literal.getValue(), useUnicodeEscapes);
appendable.append("\"").append(javaString).append("\"");
but that is not a solution ...
thx in advance,
Tom
Current Time: Sat Apr 27 03:37:35 GMT 2024
Powered by FUDForum. Page generated in 0.03388 seconds
