Home » Language IDEs » C / C++ IDE (CDT) » GCC MinGW Compiler Settings(Incomplete output, no include paths or defines)
GCC MinGW Compiler Settings [message #1747309] Fri, 11 November 2016 16:46 Go to next message
I'm trying to configure the "CDT GCC Built-in Compiler Settings MinGW".
However, when it executes, I get the following output:
"C:\\git\\smv6-arm-build\\mingw\\bin\\gcc.exe" -E -P -v -dD C:/dev/workspace_neon/.metadata/.plugins/org.eclipse.cdt.managedbuilder.core/spec.c
Using built-in specs.
COLLECT_GCC=C:\git\smv6-arm-build\mingw\bin\gcc.exe
Target: mingw32
Configured with: ../gcc-4.8.1/configure --prefix=/mingw --host=mingw32 --build=mingw32 --without-pic --enable-shared --enable-static --with-gnu-ld --enable-lto --enable-libssp --disable-multilib --enable-languages=c,c++,fortran,objc,obj-c++,ada --disable-sjlj-exceptions --with-dwarf2 --disable-win32-registry --enable-libstdcxx-debug --enable-version-specific-runtime-libs --with-gmp=/usr/src/pkg/gmp-5.1.2-1-mingw32-src/bld --with-mpc=/usr/src/pkg/mpc-1.0.1-1-mingw32-src/bld --with-mpfr= --with-system-zlib --with-gnu-as --enable-decimal-float=yes --enable-libgomp --enable-threads --with-libiconv-prefix=/mingw32 --with-libintl-prefix=/mingw --disable-bootstrap LDFLAGS=-s CFLAGS=-D_USE_32BIT_TIME_T
Thread model: win32
gcc version 4.8.1 (GCC)
COLLECT_GCC_OPTIONS='-E' '-P' '-v' '-dD' '-mtune=generic' '-march=pentiumpro'
 c:/git/smv6-arm-build/mingw/bin/../libexec/gcc/mingw32/4.8.1/cc1.exe -E -quiet -v -P -iprefix c:\git\smv6-arm-build\mingw\bin\../lib/gcc/mingw32/4.8.1/ C:/dev/workspace_neon/.metadata/.plugins/org.eclipse.cdt.managedbuilder.core/spec.c -mtune=generic -march=pentiumpro -dD
It's missing the include paths and #defines, so it provides no useful output to be used with the CDT indexer.
However, when I use the "CDT GCC Built-in Compiler Settings Cross ARM" and point to the ARM toolchain, I get a successful output and everything works fine.
"C:\\git\\smv6-arm-build\\arm_toolchain\\windows\\gcc\\bin\\arm-none-eabi-gcc" -E -P -v -dD C:/dev/workspace_neon/.metadata/.plugins/org.eclipse.cdt.managedbuilder.core/spec.c
COLLECT_GCC=C:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\arm-none-eabi-gcc
Target: arm-none-eabi
Configured with: /home/build/work/GCC-4-9-build/src/gcc/configure --build=i686-linux-gnu --host=i686-w64-mingw32 --target=arm-none-eabi --prefix=/home/build/work/GCC-4-9-build/install-mingw --libexecdir=/home/build/work/GCC-4-9-build/install-mingw/lib --infodir=/home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/info --mandir=/home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-9-build/install-mingw/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-headers=yes --with-newlib --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build/work/GCC-4-9-build/install-mingw/arm-none-eabi --with-libiconv-prefix=/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --with-gmp=/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --with-mpfr=/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --with-mpc=/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --with-isl=/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --with-cloog=/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --with-libelf=/home/build/work/GCC-4-9-build/build-mingw/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m,cortex-m7,armv7-r
Thread model: single
gcc version 4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 227977] (GNU Tools for ARM Embedded Processors)
 c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../lib/gcc/arm-none-eabi/4.9.3/cc1.exe -E -quiet -v -P -iprefix c:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\../lib/gcc/arm-none-eabi/4.9.3/ -isysroot c:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\../arm-none-eabi -D__USES_INITFINI__ C:/dev/workspace_neon/.metadata/.plugins/org.eclipse.cdt.managedbuilder.core/spec.c -dD
#define __STDC__ 1
#define __STDC_HOSTED__ 1
#define __GNUC__ 4
#define __GNUC_MINOR__ 9
#define __GNUC_PATCHLEVEL__ 3
#define __VERSION__ "4.9.3 20150529 (release) [ARM/embedded-4_9-branch revision 227977]"
#define __ATOMIC_RELAXED 0
#define __ATOMIC_SEQ_CST 5
#define __ATOMIC_ACQUIRE 2
#define __ATOMIC_RELEASE 3
#define __ATOMIC_ACQ_REL 4
#define __ATOMIC_CONSUME 1
#define __FINITE_MATH_ONLY__ 0
#define __SIZEOF_INT__ 4
#define __SIZEOF_LONG__ 4
#define __SIZEOF_LONG_LONG__ 8
#define __SIZEOF_SHORT__ 2
#define __SIZEOF_FLOAT__ 4
#define __SIZEOF_DOUBLE__ 8
#define __SIZEOF_LONG_DOUBLE__ 8
#define __SIZEOF_SIZE_T__ 4
#define __CHAR_BIT__ 8
#define __BIGGEST_ALIGNMENT__ 8
#define __ORDER_LITTLE_ENDIAN__ 1234
#define __ORDER_BIG_ENDIAN__ 4321
#define __ORDER_PDP_ENDIAN__ 3412
#define __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__
#define __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__
#define __SIZEOF_POINTER__ 4
#define __SIZE_TYPE__ unsigned int
#define __PTRDIFF_TYPE__ int
#define __WCHAR_TYPE__ unsigned int
#define __WINT_TYPE__ unsigned int
#define __INTMAX_TYPE__ long long int
#define __UINTMAX_TYPE__ long long unsigned int
#define __CHAR16_TYPE__ short unsigned int
#define __CHAR32_TYPE__ long unsigned int
#define __SIG_ATOMIC_TYPE__ int
#define __INT8_TYPE__ signed char
#define __INT16_TYPE__ short int
#define __INT32_TYPE__ long int
#define __INT64_TYPE__ long long int
#define __UINT8_TYPE__ unsigned char
#define __UINT16_TYPE__ short unsigned int
#define __UINT32_TYPE__ long unsigned int
#define __UINT64_TYPE__ long long unsigned int
#define __INT_LEAST8_TYPE__ signed char
#define __INT_LEAST16_TYPE__ short int
#define __INT_LEAST32_TYPE__ long int
#define __INT_LEAST64_TYPE__ long long int
#define __UINT_LEAST8_TYPE__ unsigned char
#define __UINT_LEAST16_TYPE__ short unsigned int
#define __UINT_LEAST32_TYPE__ long unsigned int
#define __UINT_LEAST64_TYPE__ long long unsigned int
#define __INT_FAST8_TYPE__ int
#define __INT_FAST16_TYPE__ int
#define __INT_FAST32_TYPE__ int
#define __INT_FAST64_TYPE__ long long int
#define __UINT_FAST8_TYPE__ unsigned int
#define __UINT_FAST16_TYPE__ unsigned int
#define __UINT_FAST32_TYPE__ unsigned int
#define __UINT_FAST64_TYPE__ long long unsigned int
#define __INTPTR_TYPE__ int
#define __UINTPTR_TYPE__ unsigned int
#define __has_include(STR) __has_include__(STR)
#define __has_include_next(STR) __has_include_next__(STR)
#define __GXX_ABI_VERSION 1002
#define __SCHAR_MAX__ 127
#define __SHRT_MAX__ 32767
#define __INT_MAX__ 2147483647
#define __LONG_MAX__ 2147483647L
#define __LONG_LONG_MAX__ 9223372036854775807LL
#define __WCHAR_MAX__ 4294967295U
#define __WCHAR_MIN__ 0U
#define __WINT_MAX__ 4294967295U
#define __WINT_MIN__ 0U
#define __PTRDIFF_MAX__ 2147483647
#define __SIZE_MAX__ 4294967295U
#define __INTMAX_MAX__ 9223372036854775807LL
#define __INTMAX_C(c) c ## LL
#define __UINTMAX_MAX__ 18446744073709551615ULL
#define __UINTMAX_C(c) c ## ULL
#define __SIG_ATOMIC_MAX__ 2147483647
#define __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1)
#define __INT8_MAX__ 127
#define __INT16_MAX__ 32767
#define __INT32_MAX__ 2147483647L
#define __INT64_MAX__ 9223372036854775807LL
#define __UINT8_MAX__ 255
#define __UINT16_MAX__ 65535
#define __UINT32_MAX__ 4294967295UL
#define __UINT64_MAX__ 18446744073709551615ULL
#define __INT_LEAST8_MAX__ 127
#define __INT8_C(c) c
#define __INT_LEAST16_MAX__ 32767
#define __INT16_C(c) c
#define __INT_LEAST32_MAX__ 2147483647L
#define __INT32_C(c) c ## L
#define __INT_LEAST64_MAX__ 9223372036854775807LL
#define __INT64_C(c) c ## LL
#define __UINT_LEAST8_MAX__ 255
#define __UINT8_C(c) c
#define __UINT_LEAST16_MAX__ 65535
#define __UINT16_C(c) c
#define __UINT_LEAST32_MAX__ 4294967295UL
#define __UINT32_C(c) c ## UL
#define __UINT_LEAST64_MAX__ 18446744073709551615ULL
#define __UINT64_C(c) c ## ULL
#define __INT_FAST8_MAX__ 2147483647
#define __INT_FAST16_MAX__ 2147483647
#define __INT_FAST32_MAX__ 2147483647
#define __INT_FAST64_MAX__ 9223372036854775807LL
#define __UINT_FAST8_MAX__ 4294967295U
#define __UINT_FAST16_MAX__ 4294967295U
#define __UINT_FAST32_MAX__ 4294967295U
#define __UINT_FAST64_MAX__ 18446744073709551615ULL
#define __INTPTR_MAX__ 2147483647
#define __UINTPTR_MAX__ 4294967295U
#define __GCC_IEC_559 0
#define __GCC_IEC_559_COMPLEX 0
#define __FLT_EVAL_METHOD__ 0
#define __DEC_EVAL_METHOD__ 2
#define __FLT_RADIX__ 2
#define __FLT_MANT_DIG__ 24
#define __FLT_DIG__ 6
#define __FLT_MIN_EXP__ (-125)
#define __FLT_MIN_10_EXP__ (-37)
#define __FLT_MAX_EXP__ 128
#define __FLT_MAX_10_EXP__ 38
#define __FLT_DECIMAL_DIG__ 9
#define __FLT_MAX__ 3.4028234663852886e+38F
#define __FLT_MIN__ 1.1754943508222875e-38F
#define __FLT_EPSILON__ 1.1920928955078125e-7F
#define __FLT_DENORM_MIN__ 1.4012984643248171e-45F
#define __FLT_HAS_DENORM__ 1
#define __FLT_HAS_INFINITY__ 1
#define __FLT_HAS_QUIET_NAN__ 1
#define __DBL_MANT_DIG__ 53
#define __DBL_DIG__ 15
#define __DBL_MIN_EXP__ (-1021)
#define __DBL_MIN_10_EXP__ (-307)
#define __DBL_MAX_EXP__ 1024
#define __DBL_MAX_10_EXP__ 308
#define __DBL_DECIMAL_DIG__ 17
#define __DBL_MAX__ ((double)1.7976931348623157e+308L)
#define __DBL_MIN__ ((double)2.2250738585072014e-308L)
#define __DBL_EPSILON__ ((double)2.2204460492503131e-16L)
#define __DBL_DENORM_MIN__ ((double)4.9406564584124654e-324L)
#define __DBL_HAS_DENORM__ 1
#define __DBL_HAS_INFINITY__ 1
#define __DBL_HAS_QUIET_NAN__ 1
#define __LDBL_MANT_DIG__ 53
#define __LDBL_DIG__ 15
#define __LDBL_MIN_EXP__ (-1021)
#define __LDBL_MIN_10_EXP__ (-307)
#define __LDBL_MAX_EXP__ 1024
#define __LDBL_MAX_10_EXP__ 308
#define __DECIMAL_DIG__ 17
#define __LDBL_MAX__ 1.7976931348623157e+308L
#define __LDBL_MIN__ 2.2250738585072014e-308L
#define __LDBL_EPSILON__ 2.2204460492503131e-16L
#define __LDBL_DENORM_MIN__ 4.9406564584124654e-324L
#define __LDBL_HAS_DENORM__ 1
#define __LDBL_HAS_INFINITY__ 1
#define __LDBL_HAS_QUIET_NAN__ 1
#define __DEC32_MANT_DIG__ 7
#define __DEC32_MIN_EXP__ (-94)
#define __DEC32_MAX_EXP__ 97
#define __DEC32_MIN__ 1E-95DF
#define __DEC32_MAX__ 9.999999E96DF
#define __DEC32_EPSILON__ 1E-6DF
#define __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF
#define __DEC64_MANT_DIG__ 16
#define __DEC64_MIN_EXP__ (-382)
#define __DEC64_MAX_EXP__ 385
#define __DEC64_MIN__ 1E-383DD
#define __DEC64_MAX__ 9.999999999999999E384DD
#define __DEC64_EPSILON__ 1E-15DD
#define __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD
#define __DEC128_MANT_DIG__ 34
#define __DEC128_MIN_EXP__ (-6142)
#define __DEC128_MAX_EXP__ 6145
#define __DEC128_MIN__ 1E-6143DL
#define __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL
#define __DEC128_EPSILON__ 1E-33DL
#define __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL
#define __SFRACT_FBIT__ 7
#define __SFRACT_IBIT__ 0
#define __SFRACT_MIN__ (-0.5HR-0.5HR)
#define __SFRACT_MAX__ 0X7FP-7HR
#define __SFRACT_EPSILON__ 0x1P-7HR
#define __USFRACT_FBIT__ 8
#define __USFRACT_IBIT__ 0
#define __USFRACT_MIN__ 0.0UHR
#define __USFRACT_MAX__ 0XFFP-8UHR
#define __USFRACT_EPSILON__ 0x1P-8UHR
#define __FRACT_FBIT__ 15
#define __FRACT_IBIT__ 0
#define __FRACT_MIN__ (-0.5R-0.5R)
#define __FRACT_MAX__ 0X7FFFP-15R
#define __FRACT_EPSILON__ 0x1P-15R
#define __UFRACT_FBIT__ 16
#define __UFRACT_IBIT__ 0
#define __UFRACT_MIN__ 0.0UR
#define __UFRACT_MAX__ 0XFFFFP-16UR
#define __UFRACT_EPSILON__ 0x1P-16UR
#define __LFRACT_FBIT__ 31
#define __LFRACT_IBIT__ 0
#define __LFRACT_MIN__ (-0.5LR-0.5LR)
#define __LFRACT_MAX__ 0X7FFFFFFFP-31LR
#define __LFRACT_EPSILON__ 0x1P-31LR
#define __ULFRACT_FBIT__ 32
#define __ULFRACT_IBIT__ 0
#define __ULFRACT_MIN__ 0.0ULR
#define __ULFRACT_MAX__ 0XFFFFFFFFP-32ULR
#define __ULFRACT_EPSILON__ 0x1P-32ULR
#define __LLFRACT_FBIT__ 63
#define __LLFRACT_IBIT__ 0
#define __LLFRACT_MIN__ (-0.5LLR-0.5LLR)
#define __LLFRACT_MAX__ 0X7FFFFFFFFFFFFFFFP-63LLR
#define __LLFRACT_EPSILON__ 0x1P-63LLR
#define __ULLFRACT_FBIT__ 64
#define __ULLFRACT_IBIT__ 0
#define __ULLFRACT_MIN__ 0.0ULLR
#define __ULLFRACT_MAX__ 0XFFFFFFFFFFFFFFFFP-64ULLR
#define __ULLFRACT_EPSILON__ 0x1P-64ULLR
#define __SACCUM_FBIT__ 7
#define __SACCUM_IBIT__ 8
#define __SACCUM_MIN__ (-0X1P7HK-0X1P7HK)
#define __SACCUM_MAX__ 0X7FFFP-7HK
#define __SACCUM_EPSILON__ 0x1P-7HK
#define __USACCUM_FBIT__ 8
#define __USACCUM_IBIT__ 8
ignoring duplicate directory "c:/git/smv6-arm-build/arm_toolchain/windows/gcc/lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include"
#define __USACCUM_MIN__ 0.0UHK
ignoring nonexistent directory "c:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\../arm-none-eabi/home/build/work/GCC-4-9-build/install-mingw/lib/gcc/arm-none-eabi/4.9.3/../../../../include"
#define __USACCUM_MAX__ 0XFFFFP-8UHK
ignoring duplicate directory "c:/git/smv6-arm-build/arm_toolchain/windows/gcc/lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/include-fixed"
#define __USACCUM_EPSILON__ 0x1P-8UHK
ignoring duplicate directory "c:/git/smv6-arm-build/arm_toolchain/windows/gcc/lib/gcc/../../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include"
#define __ACCUM_FBIT__ 15
ignoring nonexistent directory "c:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\../arm-none-eabi/usr/include"
#define __ACCUM_IBIT__ 16
#include "..." search starts here:
#define __ACCUM_MIN__ (-0X1P15K-0X1P15K)
#include <...> search starts here:
#define __ACCUM_MAX__ 0X7FFFFFFFP-15K
 c:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\../lib/gcc/arm-none-eabi/4.9.3/include
#define __ACCUM_EPSILON__ 0x1P-15K
 c:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\../lib/gcc/arm-none-eabi/4.9.3/include-fixed
#define __UACCUM_FBIT__ 16
 c:\git\smv6-arm-build\arm_toolchain\windows\gcc\bin\../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/include
#define __UACCUM_IBIT__ 16
End of search list.
#define __UACCUM_MIN__ 0.0UK
#define __UACCUM_MAX__ 0XFFFFFFFFP-16UK
#define __UACCUM_EPSILON__ 0x1P-16UK
#define __LACCUM_FBIT__ 31
#define __LACCUM_IBIT__ 32
#define __LACCUM_MIN__ (-0X1P31LK-0X1P31LK)
#define __LACCUM_MAX__ 0X7FFFFFFFFFFFFFFFP-31LK
#define __LACCUM_EPSILON__ 0x1P-31LK
#define __ULACCUM_FBIT__ 32
#define __ULACCUM_IBIT__ 32
#define __ULACCUM_MIN__ 0.0ULK
#define __ULACCUM_MAX__ 0XFFFFFFFFFFFFFFFFP-32ULK
#define __ULACCUM_EPSILON__ 0x1P-32ULK
#define __LLACCUM_FBIT__ 31
#define __LLACCUM_IBIT__ 32
#define __LLACCUM_MIN__ (-0X1P31LLK-0X1P31LLK)
#define __LLACCUM_MAX__ 0X7FFFFFFFFFFFFFFFP-31LLK
#define __LLACCUM_EPSILON__ 0x1P-31LLK
#define __ULLACCUM_FBIT__ 32
#define __ULLACCUM_IBIT__ 32
#define __ULLACCUM_MIN__ 0.0ULLK
#define __ULLACCUM_MAX__ 0XFFFFFFFFFFFFFFFFP-32ULLK
#define __ULLACCUM_EPSILON__ 0x1P-32ULLK
#define __QQ_FBIT__ 7
#define __QQ_IBIT__ 0
#define __HQ_FBIT__ 15
#define __HQ_IBIT__ 0
#define __SQ_FBIT__ 31
#define __SQ_IBIT__ 0
#define __DQ_FBIT__ 63
#define __DQ_IBIT__ 0
#define __TQ_FBIT__ 127
#define __TQ_IBIT__ 0
#define __UQQ_FBIT__ 8
#define __UQQ_IBIT__ 0
#define __UHQ_FBIT__ 16
#define __UHQ_IBIT__ 0
#define __USQ_FBIT__ 32
#define __USQ_IBIT__ 0
#define __UDQ_FBIT__ 64
#define __UDQ_IBIT__ 0
#define __UTQ_FBIT__ 128
#define __UTQ_IBIT__ 0
#define __HA_FBIT__ 7
#define __HA_IBIT__ 8
#define __SA_FBIT__ 15
#define __SA_IBIT__ 16
#define __DA_FBIT__ 31
#define __DA_IBIT__ 32
#define __TA_FBIT__ 63
#define __TA_IBIT__ 64
#define __UHA_FBIT__ 8
#define __UHA_IBIT__ 8
#define __USA_FBIT__ 16
#define __USA_IBIT__ 16
#define __UDA_FBIT__ 32
#define __UDA_IBIT__ 32
#define __UTA_FBIT__ 64
#define __UTA_IBIT__ 64
#define __REGISTER_PREFIX__
#define __USER_LABEL_PREFIX__
#define __GNUC_GNU_INLINE__ 1
#define __NO_INLINE__ 1
#define __CHAR_UNSIGNED__ 1
#define __GCC_ATOMIC_BOOL_LOCK_FREE 1
#define __GCC_ATOMIC_CHAR_LOCK_FREE 1
#define __GCC_ATOMIC_CHAR16_T_LOCK_FREE 1
#define __GCC_ATOMIC_CHAR32_T_LOCK_FREE 1
#define __GCC_ATOMIC_WCHAR_T_LOCK_FREE 1
#define __GCC_ATOMIC_SHORT_LOCK_FREE 1
#define __GCC_ATOMIC_INT_LOCK_FREE 1
#define __GCC_ATOMIC_LONG_LOCK_FREE 1
#define __GCC_ATOMIC_LLONG_LOCK_FREE 1
#define __GCC_ATOMIC_TEST_AND_SET_TRUEVAL 1
#define __GCC_ATOMIC_POINTER_LOCK_FREE 1
#define __PRAGMA_REDEFINE_EXTNAME 1
#define __SIZEOF_WCHAR_T__ 4
#define __SIZEOF_WINT_T__ 4
#define __SIZEOF_PTRDIFF_T__ 4
#define __ARM_32BIT_STATE 1
#define __ARM_SIZEOF_MINIMAL_ENUM 1
#define __ARM_SIZEOF_WCHAR_T 4
#define __arm__ 1
#define __ARM_ARCH 4
#define __ARM_ARCH_ISA_ARM 1
#define __APCS_32__ 1
#define __ARM_ARCH_ISA_THUMB 1
#define __ARMEL__ 1
#define __SOFTFP__ 1
#define __VFP_FP__ 1
#define __ARM_FP 12
#define __ARM_NEON_FP 4
#define __THUMB_INTERWORK__ 1
#define __ARM_ARCH_4T__ 1
#define __ARM_PCS 1
#define __ARM_EABI__ 1
#define __GXX_TYPEINFO_EQUALITY_INLINE 0
#define __ELF__ 1
#define __USES_INITFINI__ 1
COMPILER_PATH=c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../lib/gcc/arm-none-eabi/4.9.3/;c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../lib/gcc/;c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/
LIBRARY_PATH=c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../lib/gcc/arm-none-eabi/4.9.3/;c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../lib/gcc/;c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/;c:/git/smv6-arm-build/arm_toolchain/windows/gcc/bin/../arm-none-eabi/lib/
Any idea what I'm doing wrong?
In case anyone is wondering, this is within the same eclipse project, but using different configurations. We compile our executable for ARM, but compile unit-tests and run them on x86 which is why we have two different GCC compilers to configure/use.
Re: GCC MinGW Compiler Settings [message #1747442 is a reply to message #1747309] Mon, 14 November 2016 12:51 Go to previous messageGo to next message
You might try executing the x86 command (shown below) from a command window and see what you get.
If you have MinGW for your current Windows version, try
gcc -E -P -v -dD <some c file>
For comparison, the following is the ARM version (both taken from your post)
EDIT:
The version you are using for the X86 compiles defaults to -mtune=generic -march=pentiumpro.
Could it be your build machine is different architecture?
[Updated on: Mon, 14 November 2016 13:13] by Moderator
Re: GCC MinGW Compiler Settings [message #1747505 is a reply to message #1747442] Tue, 15 November 2016 09:40 Go to previous message
David Vavra wrote on Mon, 14 November 2016 17:51
Thanks for this suggestion. By calling this I got quite a few MessageBox errors pop-up from Windows about missing DLLs.
It seems after all I was missing ${MINGW_HOME}/bin from $PATH.
I'm still dumbfounded why the same issue didn't show with the ARM compiler though Confused
But hey, at least it works... Thanks!
Previous Topic:GraphicsMagick on Eclipse
Next Topic:ImageMagick++ on EclipseCDT
Current Time: Mon Nov 03 16:28:04 EST 2025
Powered by FUDForum. Page generated in 0.03281 seconds
