Compile and launch from command line [message #1747112] |
Wed, 09 November 2016 14:28 |
I want to compile OT/J programs from the command line. But no matter how I set it up I keep getting the error that the BatchAnnotationProcessor is not on the class path.
Unable to load annotation processing manager org.eclipse.jdt.internal.compiler.apt.dispatch.BatchAnnotationProcessorManager from classpath.
The first command is java -jar lib/ecotj-R-2.5.0-201606070953.jar -1.8 -cp lib:/Applications/Eclipse.app/Contents/Eclipse/plugins/ src/otongraal/Mainclass.java and the ant file is called with
ant build -lib lib/ecotj-R-2.5.0-201606070953.jar -Dotre.jar=lib/org.eclipse.objectteams.runtime_2.5.0.201606070956.jar <?xml version="1.0" encoding="UTF-8"?>
<project name="otongraal" default="build" basedir=".">
<property name="build.compiler" value="org.eclipse.jdt.core.JDTCompilerAdapter" />
<!-- adjust this to your project's requirements: -->
<target name="build">
<mkdir dir="bin" />
<property name="user.cp" value="/Applications/Eclipse.app/Contents/Eclipse/plugins/" />
<javac srcdir="src" destdir="bin" classpath="${otre.jar):${user.cp}" source="1.8" target="1.8" />
</target>
</project>
What I have is both an ant build script and a single command which should both do the same. They both result in the same error message.
As you can see I added the Eclipse plugin directory into the class path where jdt.internal.compiler.apt is contained. I have read all the provided information about compiling from command line.
The lib folder contains the required runtime jars, the OT compiler. Building from within Eclipse is fine. When build from within Eclipse and running from command line
java -Xbootclasspath/a:${OTRE_MIN}:${BCEL} -javaagent:${OTRE_AGENT} -cp lib:bin otongraal.Mainclass
I get the error
Exception in thread "main" java.lang.IncompatibleClassChangeError: Class otongraal.Person does not implement the requested interface org.objectteams.IBoundBase2
at otongraal.Company$__OT__Employee.<init>(Company.java:23)
at otongraal.Company._OT$liftTo$Employee(Company.java:23)
at otongraal.Company.approveApplication(Company.java:37)
at otongraal.Company.receiveApplication(Company.java:34)
at otongraal.Mainclass.main(Mainclass.java:12)
For convenience I added all files as zip (but be aware of the hardcoded class path entries).
I want to be able to build from command line (would be a plus) and run from command line (mandatory). For now I tried everything that has been documented in the wiki, the blog and what I found in this forum. Thank you very much for your help.
[Updated on: Wed, 09 November 2016 14:29] Report message to a moderator
Re: Compile and launch from command line [message #1747121 is a reply to message #1747119] |
Wed, 09 November 2016 16:46 |
Quote:The command line, however, uses the old weaver (BCEL-based OTRE).
Even when using the dynamic jars (so ASM and otredyn agent) the error looks the same. Did not want to post too much, but I tried this, too.
java -Xbootclasspath/a:${OTRE_MIN}:${ASM} -javaagent:${OTRE_AGENT_DYN} -cp lib:bin otongraal.Mainclass
java.lang.IncompatibleClassChangeError: org/eclipse/objectteams/otredyn/bytecode/asm/AsmClassVisitor
Quote:Apparently, documentation is lagging behind. I'll update it and point you to the new information when done. Sorry for the inconvenience.
Nothing to worry about.
Re: Compile and launch from command line [message #1747158 is a reply to message #1747117] |
Thu, 10 November 2016 10:50 |
Stephan Herrmann wrote on Wed, 09 November 2016 17:09This seems to be a glitch in the packaging of ecotj.jar. Please try passing -proc:none as a workaround
Compiling from the command line now works. The only left problem is executing from the command line.
Re: Compile and launch from command line [message #1747161 is a reply to message #1747158] |
Thu, 10 November 2016 11:11 |
Just to give full information: I had to alter the *.jardescr files because they did not include the full /src folder of their respective plugin. Therefore, classes where missing when using the plain .jardescr files from git. The code I execute
export OTRE_MIN=lib/otre_min.jar
export OTRE_AGENT_DYN=lib/otredyn_agent.jar
export ASM=lib/org.objectweb.asm_3.3.1.v201105211655.jar
The result
Larss-MacBook-Pro:otongraal lschuetze$ ./run.sh
objc[9321]: Class JavaLaunchHelper is implemented in both /Users/lschuetze/Development/labsjdk1.8.0_92-jvmci-0.22/bin/java and /Users/lschuetze/Development/labsjdk1.8.0_92-jvmci-0.22/jre/lib/libinstrument.dylib. One of the two will be used. Which one is undefined.
java.lang.IncompatibleClassChangeError: class org.eclipse.objectteams.otredyn.bytecode.asm.AsmClassVisitor has interface org.objectweb.asm.ClassVisitor as super class
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.objectteams.otredyn.bytecode.asm.AsmBoundClass.parseBytecode(AsmBoundClass.java:81)
at org.eclipse.objectteams.otredyn.bytecode.AbstractBoundClass.isInterface(AbstractBoundClass.java:293)
at org.eclipse.objectteams.otredyn.transformer.jplis.ObjectTeamsTransformer.transform(ObjectTeamsTransformer.java:104)
at org.eclipse.objectteams.otredyn.transformer.jplis.ObjectTeamsTransformer.transform(ObjectTeamsTransformer.java:66)
at sun.instrument.TransformerManager.transform(TransformerManager.java:188)
at sun.instrument.InstrumentationImpl.transform(InstrumentationImpl.java:428)
at sun.misc.PostVMInitHook.trackJavaUsage(PostVMInitHook.java:28)
at sun.misc.PostVMInitHook.run(PostVMInitHook.java:21)
at sun.usagetracker.UsageTrackerClient.getPropertyPrivileged(UsageTrackerClient.java:136)
at sun.usagetracker.UsageTrackerClient.getPropertyPrivileged(UsageTrackerClient.java:132)
at sun.usagetracker.UsageTrackerClient.<clinit>(UsageTrackerClient.java:109)
at sun.usagetracker.UsageTrackerClient.run(UsageTrackerClient.java:317)
at sun.misc.PostVMInitHook.trackJavaUsage(PostVMInitHook.java:29)
at sun.usagetracker.UsageTrackerClient.getConfigFilePrivileged(UsageTrackerClient.java:169)
at sun.usagetracker.UsageTrackerClient.setupAndTimestamp(UsageTrackerClient.java:295)
at sun.usagetracker.UsageTrackerClient.access$000(UsageTrackerClient.java:78)
at sun.usagetracker.UsageTrackerClient$4.run(UsageTrackerClient.java:322)
at sun.usagetracker.UsageTrackerClient$4.run(UsageTrackerClient.java:317)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:519)
at otongraal.Mainclass.main(Unknown Source)
at otongraal.Company._OT$liftTo$Employee(Unknown Source)
at otongraal.Company.approveApplication(Unknown Source)
at otongraal.Company.receiveApplication(Unknown Source)
at otongraal.Company$__OT__Employee.<init>(Unknown Source)
Re: Compile and launch from command line [message #1747201 is a reply to message #1747161] |
Thu, 10 November 2016 16:47 |
Stephan Herrmann Messages: 1853 Registered: July 2009 |
Found it: you need to use a newer version of asm, and then asm is split into multiple jars (paths and some version numbers omitted for simplicity):
java -javaagent:otredyn_agent.jar -Xbootclasspath/a:otre_min.jar -classpath .:otredyn.jar:org.objectweb.asm_5.0.1.v201404071650.jar:org.objectweb.asm.commons_5.0.1.v201404071650.jar:org.objectweb.asm.tree_5.0.1.v201404071650.jar:org.eclipse.objectteams.runtime.jar otongraal.Mainclass
This runs and prints:
Hello, my name is Hans Peter. How may I help you?
Hi, I am Maya Maier. I have a problem!
HTH,
Stephan
[Updated on: Thu, 10 November 2016 16:56] Report message to a moderator
FUDForum. Page generated in 0.03666 seconds
