Re: Error at installation [message #1748274 is a reply to message #1747122] |
Mon, 21 November 2016 18:09 |
Eric Domeshek Messages: 12 Registered: October 2016 |
Junior Member |
I'm posting this as a follow-up because I think I may have a similar problem, and my question is: How do I fix a botched install. I'm hoping to fix this install (rather than just try all over again) because it's the closest I've come to a working environment install after several attempts (including a fresh attempt just this morning).
More specifically, I have an Oomph install (of Papyrus) on 11/15/2016 that seemed to run to completion, but produced a workspace with >500K errors. In the intervening time, it somehow magically reduced to a mere 2310 errors.
The reason I hypothesize this is related to this threat is that I found the logs and what I see are a lot of errors that all seem nested as follows:
[2016-11-15 08:53:39] ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while collecting items to be installed
at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:778)
at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl$4.run(TargletTaskImpl.java:1128)
at org.eclipse.oomph.util.pde.TargetPlatformUtil.runWithTargetPlatformService(TargetPlatformUtil.java:120)
at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl.perform(TargletTaskImpl.java:1036)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3151)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3094)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4315)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4309)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4307)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3085)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3060)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2960)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:556)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:682)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=_Users_domeshek_Documents_Projects_Projects_MATTER_PapyrusDevInstall_Workspaces_papyrus-master-ws-5124e7d0a10fe9d3bf0b6559047362e87dc29f39, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
ERROR: org.eclipse.equinox.p2.artifact.repository code=1201 The artifact is already available in the repository file:/Users/domeshek/.eclipse/org.eclipse.platform_3.6.1_119745494/.
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Failed to transfer artifact canonical: osgi.bundle,org.eclipse.xwt.source,1.2.0.v20160502-1019.
ERROR: org.eclipse.equinox.p2.artifact.repository code=13 Retry another mirror
ERROR: org.eclipse.equinox.p2.transport.ecf code=1200 Artifact not found: http://ftp.osuosl.org/pub/eclipse/xwt/updates/plugins/org.eclipse.xwt.source_1.2.0.v20160502-1019.jar.
java.io.FileNotFoundException: http://ftp.osuosl.org/pub/eclipse/xwt/updates/plugins/org.eclipse.xwt.source_1.2.0.v20160502-1019.jar
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryStatusHelper.checkFileNotFound(RepositoryStatusHelper.java:297)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.checkException(FileReader.java:478)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:435)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:358)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:101)
at org.eclipse.oomph.p2.internal.core.CachingTransport.download(CachingTransport.java:135)
at org.eclipse.oomph.p2.internal.core.CachingTransport.download(CachingTransport.java:251)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:669)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:591)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:723)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:319)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:288)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:223)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:153)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:707)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:778)
at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch(DownloadManager.java:112)
at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:100)
at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:104)
at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:251)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:101)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:42)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:543)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.targlets.internal.core.TargletContainer.updateProfile(TargletContainer.java:852)
at org.eclipse.oomph.targlets.internal.core.TargletContainer.resolveUnits(TargletContainer.java:556)
at org.eclipse.oomph.targlets.internal.core.TargletContainer.resolveBundles(TargletContainer.java:518)
at org.eclipse.pde.internal.core.target.AbstractBundleContainer.resolve(AbstractBundleContainer.java:81)
at org.eclipse.pde.internal.core.target.TargetDefinition.resolve(TargetDefinition.java:282)
at org.eclipse.oomph.util.pde.TargetPlatformUtil.activateTargetDefinition(TargetPlatformUtil.java:153)
at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:764)
Thanks or any guidance you can give to get me unstuck here.
--Eric
FUDForum. Page generated in 0.03320 seconds
