[CDO] postgresql Junit Tests [message #1746689] |
Thu, 03 November 2016 09:32 |
Per Sterner Messages: 91 Registered: October 2011 |
Member |
We have some issues with postgresql and cdo. I'd like to check and fix these issues. I have setup the CDO-Workspace with Oomph and I have run the tests for postgresql. Some tests get errors.
To simplify the postgresql server I have added a script for running a standalone instance of postgresql.
The standalone zips are located here:
- https://www.postgresql.org/download/windows/
- http://www.enterprisedb.com/products-services-training/pgbindownload
The postgresql-zip must be unzipped into the folder 'postgresql-standalone' from the attached and unzipped zipfile. After this, the folder pgsql should be renamed to postgresql-9.6.1-1. Finally you only need to run 'runme.bat'.
With an older version postgresql-9.2.2-1, the junit issues also occur.
Before I start I'd like to verify that there isn't any test-setup problem. The H2-Tests did all pass.
[Updated on: Thu, 03 November 2016 09:35] Report message to a moderator
Re: [CDO] postgresql Junit Tests [message #1746733 is a reply to message #1746730] |
Thu, 03 November 2016 19:24 |
These days it would be much better to have a Tycho-based build. Especially for running local builds and testing changes to the build system. I would love to switch to Tycho, but I have no idea how to run the API checks, our version checks and the API evolution report generator (which is currently a custom Buckminstor actor). Are you experienced in this area and would like to help me? In any case I would appreciate that you contact me via private email. Then we could exchange Skype IDs or just phone numbers and discuss more efficiently...
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.25588 seconds
