Home » Modeling » TMF (Xtext) » XtextActivator instead of <MyLang>Activator
XtextActivator instead of <MyLang>Activator [message #1745783] Mon, 17 October 2016 10:13 Go to next message
I just start to use xtext 2.10
after the generation process,
in the ui.internal package, I found a class named XtextActivator instead of <MyLanguage>Activator.
Is it normal?
How can i customize it?
best regards,
Re: XtextActivator instead of <MyLang>Activator [message #1745784 is a reply to message #1745783] Mon, 17 October 2016 10:15 Go to previous messageGo to next message
yes and no,
it depends on your language and plugin naming how the activator i named.
thus: can you share a reproducable example?
Re: XtextActivator instead of <MyLang>Activator [message #1745785 is a reply to message #1745784] Mon, 17 October 2016 10:18 Go to previous messageGo to next message
Yes!
this is my generator
module fr.irit.fiacre.xtext.GenerateFiacre
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "fr.irit.fiacre.xtext"
				rootPath = rootPath
				eclipsePlugin = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "fr.irit.fiacre.xtext.Fiacre"
			fileExtensions = "fcr"
			grammarAccess = grammarAccess.GrammarAccessFragment2 auto-inject{}
			emfGenerator = ecore.EMFGeneratorFragment2 auto-inject{}
			serializer = {
				generateStub = false
			validator = validation.ValidatorFragment2 {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
			scopeProvider = scoping.ImportNamespacesScopingFragment2 auto-inject{}
			qualifiedNamesProvider = exporting.QualifiedNamesFragment2 auto-inject{}
			builder = builder.BuilderIntegrationFragment2 auto-inject{}
			generator = generator.GeneratorFragment2 auto-inject{}
			formatter =formatting.Formatter2Fragment2 auto-inject{}
			labelProvider=ui.labeling.LabelProviderFragment2 auto-inject{}
			outline=ui.outline.OutlineTreeProviderFragment2 auto-inject{}
			quickOutline = ui.outline.QuickOutlineFragment2 auto-inject{}
			quickFixProvider = ui.quickfix.QuickfixProviderFragment2 auto-inject{}
			contentAssist =ui.contentAssist.ContentAssistFragment2 auto-inject{}
			parserGenerator = parser.antlr.XtextAntlrGeneratorFragment2 {
				options={
					backtrack=true
					classSplitting=true
					fieldsPerClass="500"
			junitSupport =auto-inject {}
			renameRefactoring = auto-inject{}
			resourceFactoryFragment = auto-inject{}
			compareEditor = auto-inject{}
Re: XtextActivator instead of <MyLang>Activator [message #1745798 is a reply to message #1745785] Mon, 17 October 2016 11:06 Go to previous messageGo to next message
i assume it is derived from this one fr.irit.fiacre.xtext
Re: XtextActivator instead of <MyLang>Activator [message #1745799 is a reply to message #1745798] Mon, 17 October 2016 11:15 Go to previous messageGo to next message
Ok
But why all others classes names contain Fiacre like, AbstractFiacreUiModule, FiacreExecutableExtensionFactory, AbstractFiacreProposalProvider, FiacreQuickfixProvider, FiacreDescriptionLabelProvider etc...
Re: XtextActivator instead of <MyLang>Activator [message #1745801 is a reply to message #1745799] Mon, 17 October 2016 11:28 Go to previous messageGo to next message
with the same grammar and generator in xtext 2.8.4, I obtained a FiacreActivator generated class
Re: XtextActivator instead of <MyLang>Activator [message #1745805 is a reply to message #1745801] Mon, 17 October 2016 11:47 Go to previous messageGo to next message
Yes that is a change in the generator to derive the activator from plugin name
I cannot tell you why this was done
Re: XtextActivator instead of <MyLang>Activator [message #1745960 is a reply to message #1745805] Wed, 19 October 2016 17:26 Go to previous message
We did it to support multiple languages in one project. There can only be one activator per project.
Previous Topic:How to generate code from Xbase expressions
Next Topic:Cross Referencing an already crossreferenced element in xtext doesn't work
Current Time: Wed Oct 29 13:15:41 EDT 2025
Powered by FUDForum. Page generated in 0.05465 seconds
