Home » Eclipse Projects » OM2M » Question about non-server-capable application for subscription/notification scenarios
Question about non-server-capable application for subscription/notification scenarios [message #1745382] Sun, 09 October 2016 17:25 Go to next message
Good morning/afternoon/evening everybody,
I just read in this post that OM2M already implemented two subscription/notification scenarios: server-capable application and non-server-capable application. For the server-capable application, we can use the Monitor server example to get the notification. For the non-server-capable application, OM2M will automatically notify to one of the container of the subscriber. However when I tried these two scenerios with OM2M ver 1.0.0 for oneM2M, only the server-capable application worked, the non-server-capable application didn't work. And I just recognized that these two scenerios work only with ver 0.8.0 for ETSI smartM2M. I would like to ask that if the non-server-capable application is already implemented in ver 1.0.0 for oneM2M or not? If yes, how can I use it? I tried the same way with the tutorial in the mentioned above post but it was not working.
Thank you so much!
Yoshida
Re: Question about non-server-capable application for subscription/notification scenarios [message #1772908 is a reply to message #1745382] Mon, 18 September 2017 11:19 Go to previous message
Is there any news about the implementation of the non-server-capable application for subscription/notification scenarios for the version 1.0 ?
Thank you !
Dorian
Previous Topic:New contentInstance is not created when a notification is received
Next Topic:OM2M in-cse and mn-cse connection through SSH port forwarding
Current Time: Sat Nov 08 00:19:07 EST 2025
Powered by FUDForum. Page generated in 0.03103 seconds
