Compatibility of structured and non-structured types is decribed in detail in ch 6.3 "Type compatibility" of the core language standard.
However, due to performance considerations type compatibility for structured types is enabled only in the function test run-time (run-time 2)
(except record of/set of types for certain element types, see section 4.32.2 of the referenceguide).
Titan generates different code in function test run-time mode and performance(load) test run-time mode:
the first type of code generated aims functional completeness, the second aims maximum performance( build-time performance, execution speed performance).
Let's take the below code as an example:
module test
type union Type0
charstring m1,
octetstring m2
type record ParamValueType
integer f1,
octetstring f2,
Type0 f3
type record Type1
record of ParamValueType parameter_list
type record Type3
Type1 tct
type record Type2
function getParameterValueById(Type1.parameter_list p_tot, integer p_id) return integer
return p_id
control {
var Type1.parameter_list v_list0:= {{f1:=1,f2:='ABDC'O,f3:={m1:="AAAAA"}} }
var Type2.parameter_list v_list1:= {{f1:=1,f2:='ABDC'O,f3:={m1:="AAAAA"}} }
var Type3.tct.parameter_list v_list2:= {{f1:=1,f2:='ABDC'O,f3:={m1:="AAAAA"}} }
var integer v_int
v_int:=getParameterValueById(v_list0, 2)
log(v_int)
v_int:=getParameterValueById(v_list1, 3)
log(v_int)
v_int:=getParameterValueById(v_list2, 4)
log(v_int)
}//endcontrol
}//endmodule
The function getParameterValueById has one parameter of type Type1.parameter_list;
when the function is called with parameters of compatible types,
in run-time #1(load test runtime) , which is selected by default, this will result in all kinds of errors;
however if code generation for function test run-time is chose by using the compiler flag -R
(see compiler -h for different flags )
# Flags for the TTCN-3 and ASN.1 compiler:
COMPILER_FLAGS = -L -R
then the compilation and execution is successful:
make
/proj/TTCN/Releases/TTCNv3_daily_LMWP3.1/bin/compiler -L -R \
test.ttcn - test.ttcn
Notify: Parsing TTCN-3 module `test.ttcn'...
Notify: Checking modules...
Notify: Generating code...
Notify: File `test.hh' was generated.
Notify: File `test.cc' was generated.
Notify: 2 files were updated.
touch compile
g++ -c -DLINUX -I/proj/TTCN/Releases/TTCNv3_daily_LMWP3.1/include -DTITAN_RUNTIME_2 -Wall -o test.o test.cc
if g++ -o test test.o \
-L/proj/TTCN/Releases/TTCNv3_daily_LMWP3.1/lib -lttcn3-rt2-parallel \
-L/proj/TTCN/Releases/TTCNv3_daily_LMWP3.1/lib -lcrypto \
-L/proj/TTCN/Releases/TTCNv3_daily_LMWP3.1/lib -lxml2 -lpthread -lrt; \
then : ; else /proj/TTCN/Releases/TTCNv3_daily_LMWP3.1/bin/titanver test.o ; exit 1; fi
The reason for the load test run-time being default goes back as usual to a careful design decision of which details no one remembers anymore.
For the tl;dr crowd: if you run into type compatibility problems with Titan, try function test run-time by using the -R flag for the compiler.
Best regards
Elemer
