Home » Eclipse Projects » Eclipse Platform » Eclipse RCP crashes with lots of GTK warnings and errors after latest Gnome update
| Eclipse RCP crashes with lots of GTK warnings and errors after latest Gnome update [message #1743476] |
Thu, 15 September 2016 14:25  |
since today when I upgraded my Debian Linux to the latest testing version my Eclipse RCP 4diac keeps crashing all the time with a full list of GT warnings and errors (see below). Interestingly my Eclipse Neon instance works without issues. Is this an SWT issue? Any tips where I could look?
While I fetched the log output I did an additional test with a clean workspace, just to be sure. I noticed that the RCP crashed as soon as I opend one of our GEF3 based editors. Maybe this can give a hint.
Alois
Log output:
Gtk-Message: Not loading module "atk-bridge": The functionality is provided by GTK natively. Please try to not load it.
!SESSION 2016-09-15 20:04:53.260 -----------------------------------------------
eclipse.buildId=1.8.0
java.version=1.8.0_102
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en
Framework arguments: -product org.fordiac.ide.product
Command-line arguments: -product org.fordiac.ide.product -data /home/alil/prog/fordiac-ide_dev/fordiac-ide-neon-1.8/../runtime-org.fordiac.ide.product -dev file:/home/alil/prog/fordiac-ide_dev/fordiac-ide-neon-1.8/.metadata/.plugins/org.eclipse.pde.core/org.fordiac.ide.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.core.resources 2 10035 2016-09-15 20:04:57.107
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.fordiac.ide.util 4 0 2016-09-15 20:04:58.839
!MESSAGE Icon URL handler registered.
1.8.0
qualifier
eclipse.buildId: 1.8.0
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9e9ed1a00. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: Negative content width -6 (allocation 1, extents 4x3) while allocating gadget (node toolbar, owner GtkToolbar)
(4DIAC-IDE:4307): Gtk-WARNING **: Negative content height -3 (allocation 1, extents 2x2) while allocating gadget (node toolbar, owner GtkToolbar)
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9e9ed1da0. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea00a2a0. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea00a640. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea00a9e0. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea01c2a0. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea01c640. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea04b770. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea04bb10. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: Allocating size to GtkBox 0x7ff9e9ba51d0 without calling gtk_widget_get_preferred_width/height(). How does the code know the size to allocate?
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea5027a0. Allocation is 0x0, but minimum required size is 7x4.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea5027a0. Allocation is 7x4, but minimum required size is 7x31.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea5027a0. Allocation is 7x4, but minimum required size is 30x35.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate GtkToolbar's child GtkToggleButton 0x7ff9ea502960. Allocation is 23x1, but minimum required size is 23x31.
(4DIAC-IDE:4307): Gtk-WARNING **: Negative content height -6 (allocation 1, extents 3x4) while allocating gadget (node button, owner GtkToggleButton)
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate GtkToggleButton's child GtkImage 0x7ff9ea52f140. Allocation is 16x0, but minimum required size is 16x16.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkScrolledWindow 0x7ff9ea976360. Allocation is 46x47, but minimum required size is 46x71.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate GtkScrolledWindow's child GtkScrollbar 0x7ff9ea9d0670. Allocation is 13x22, but minimum required size is 13x46.
(4DIAC-IDE:4307): Gtk-CRITICAL **: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkScrollbar
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkFrame 0x7ff9ea1abf00. Allocation is 303x1, but minimum required size is 2x2.
(4DIAC-IDE:4307): Gtk-WARNING **: Negative content height -1 (allocation 1, extents 1x1) while allocating gadget (node border, owner GtkFrame)
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkEntry 0x7ff9e88b51b0. Allocation is 59x30, but minimum required size is 66x28.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkScrolledWindow 0x7ff9ea85e6c0. Allocation is 61x1, but minimum required size is 48x48.
(4DIAC-IDE:4307): Gtk-WARNING **: Negative content height -1 (allocation 1, extents 1x1) while allocating gadget (node scrolledwindow, owner GtkScrolledWindow)
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkToolbar 0x7ff9ea8e5680. Allocation is 1x28, but minimum required size is 34x31.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate GtkToolbar's child GtkToolButton 0x7ff9eaa453d0. Allocation is 27x24, but minimum required size is 27x27.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate GtkToolButton's child GtkButton 0x7ff9eaa30dc0. Allocation is 27x24, but minimum required size is 27x27.
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkProgressBar 0x7ff9eaa30f90. Allocation is 1x4, but minimum required size is 152x4.
https://www.eclipse.org/forums/#
(4DIAC-IDE:4307): Gtk-WARNING **: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node trough, owner GtkProgressBar)
(4DIAC-IDE:4307): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to underallocate SwtFixed's child GtkProgressBar 0x7ff9eaa53190. Allocation is 1x4, but minimum required size is 152x4.
Gtk:ERROR:/build/gtk+3.0-dFLfat/gtk+3.0-3.21.5/./gtk/gtkwidget.c:10232:gtk_widget_pop_verify_invariants: assertion failed: (widget->priv->verifying_invariants_count > 0)
Current Time: Sun Nov 09 06:51:32 EST 2025
Powered by FUDForum. Page generated in 0.04803 seconds
