Jubula 8.3 - Database connection failed because of invalid or missing database detail [message #1743334] |
Wed, 14 September 2016 13:13 |
David Vlek Messages: 20 Registered: September 2014 |
Hello People
After migrating to the new Jubula 8.3 installation. I get the error below. Please what am I missing. My database is an Oracle 11g db. What does it mean major version invalid.
2016-09-14 15:13:16.331 [Worker-0] ERROR o.e.j.c.core.persistence.Persistor - DBVersion: major version invalid
2016-09-14 15:13:16.339 [Worker-0] ERROR o.e.j.c.core.persistence.Persistor - ITE version problem - database schema version: "60.0" <--> ITE expected version: "50.0"
2016-09-14 15:13:16.343 [main] ERROR o.e.j.a.testexec.core.TestexecClient - Database connection failed because of invalid or missing database detail
java.lang.IllegalArgumentException: Database connection failed because of invalid or missing database detail
at org.eclipse.jubula.app.testexec.core.ExecutionController.prepareDBConnection(ExecutionController.java:538) ~[na:na]
at org.eclipse.jubula.app.testexec.core.ExecutionController.executeJob(ExecutionController.java:322) ~[na:na]
at org.eclipse.jubula.app.testexec.core.TestexecClient.doRun(TestexecClient.java:78) ~[na:na]
at org.eclipse.jubula.client.cmd.AbstractCmdlineClient.run(AbstractCmdlineClient.java:444) [org.eclipse.jubula.client.cmd_4.0.0.201603111021.jar:na]
at org.eclipse.jubula.client.cmd.AbstractLauncher.start(AbstractLauncher.java:27) [org.eclipse.jubula.client.cmd_4.0.0.201603111021.jar:na]
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) [org.eclipse.equinox.app_1.3.200.v20130910-1609.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) [org.eclipse.osgi_3.10.2.v20150203-1939.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_66]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_66]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_66]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_66]
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at org.eclipse.equinox.launcher.Main.run(Main.java:1465) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at org.eclipse.equinox.launcher.Main.main(Main.java:1438) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62) [i4jruntime.jar:na]
at com.exe4j.runtime.WinLauncher.main(WinLauncher.java:101) [i4jruntime.jar:na]
at com.install4j.runtime.launcher.WinLauncher.main(WinLauncher.java:16) [i4jruntime.jar:na]
2016-09-14 15:13:16.344 [main] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: Database connection failed because of invalid or missing database detail
<configuration>
<project>XXXXX</project>
<version>XXXXXXX</version>
<autconfig>XXXXXX</autconfig>
<dburl>jdbc:oracle:thin:@XXXXX:XXXX:XXXXXX</dburl>
<dbuser>JTA_NEW</dbuser>
<dbpw>jta_new_sssss</dbpw>
<testjob>XXXXXX</testjob>
<server>qa-test-automation-pc1</server>
<port>60000</port>
</configuration>
I created a new schema. Imported old projects to the new installation. Trying to test if everything works well I get the error. I have tried via testexec and directly from the ITE itself i get the same error. I attached the full client log to the post and also screen shot showing successful connection to the db.
Thanks in advance.
Kind regards,
Dave
[Updated on: Wed, 14 September 2016 13:17] Report message to a moderator
FUDForum. Page generated in 0.03054 seconds
