Home » Eclipse Projects » OM2M » send SIP message to PhonerLite from IN-CSE
send SIP message to PhonerLite from IN-CSE [message #1743319] Wed, 14 September 2016 06:20 Go to next message
Hi all,
i'm currently building an application which simulate the smart sensor function. As I consider, after the evaluator receive and evaluate the sensor value, it would send the SIP message to a User (in this case is PhonerLite). I want to ask is it possible to do that? thanks in advance
Re: send SIP message to PhonerLite from IN-CSE [message #1743327 is a reply to message #1743319] Wed, 14 September 2016 07:55 Go to previous message
Hello Trung,
I think yes it's possible to send SIP message in this case. You can simply use JAINSIP library to create simple SIP Client in your plugin to send SIP message to your PhonerLite.
Good luck!
Yoshida
Previous Topic:send SIP message to PhonerLite from IN-CSE
Next Topic:asking about OM2M component
Current Time: Wed Jul 30 18:48:29 EDT 2025
Powered by FUDForum. Page generated in 0.10072 seconds
