Re: Select entry by value doesn't work in 8.3 version [message #1743336 is a reply to message #1743224] |
Wed, 14 September 2016 13:19 |
biks triks Messages: 13 Registered: August 2012 |
Now, when I try to execute one of the tests, I get this error:
2016-09-14 15:14:45.131 [Connection.ReaderThread:Socket[addr=/127.0.0.1,port=50583,localport=60001]] ERROR o.e.j.c.internal.Communicator - caught exception from 'org.eclipse.jubula.autagent.commands.ConnectToAutCommand.execute()'
java.lang.NullPointerException: null
at org.eclipse.jubula.autagent.agent.AutAgent.sendConnectToClientMessage(AutAgent.java:710) ~[na:na]
at org.eclipse.jubula.autagent.commands.ConnectToAutCommand.execute(ConnectToAutCommand.java:46) ~[na:na]
at org.eclipse.jubula.communication.internal.Communicator$ConnectionListener.received(Communicator.java:920) ~[org.eclipse.jubula.communication_4.0.0.201607281404.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.fireMessageReceived(Connection.java:402) [org.eclipse.jubula.communication_4.0.0.201607281404.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.access$2(Connection.java:391) [org.eclipse.jubula.communication_4.0.0.201607281404.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection$ReaderThread.run(Connection.java:454) [org.eclipse.jubula.communication_4.0.0.201607281404.jar:na]
[Updated on: Wed, 14 September 2016 13:20] Report message to a moderator
FUDForum. Page generated in 0.04125 seconds
