| Read HTTP Post Parameter [message #1742650] |
Tue, 06 September 2016 07:15  |
Hi all,
I'm building a small web page application using RWT Standalone. This page should be redirected from a parent application. When the parent redirects, it also sends an encrypted data as HTTP post parameter. How can I access this data in my RWT page ?
When passing with URL I can just use getParameter<NAME> in AbstractEntryPoint, how can I access the same for HTTP Post parameter.
Any help would be greatly appreciated.
Thank & Regards,
Setya
| Re: Read HTTP Post Parameter [message #1742908 is a reply to message #1742696] |
Thu, 08 September 2016 10:19  |
Hi Dmitri,
Thank you for your response.
HTTP POST parameter will be attach in the body. Somehow I can access it with HttpServletRequest#getParameter within servlet, but not from within RAP code.
For know I have workaround where I use a Spring controller to receive the POST data, then store it in an HttpSession and forward the request to RAP. This way RAP can access the data via HttpSession.
Thanks & Regards,
Setya
FUDForum. Page generated in 0.04649 seconds
