Home » Eclipse Projects » RCP Testing Tool » SWING UI Automation(Recording SWING UI)
SWING UI Automation [message #1742251] Thu, 01 September 2016 02:36 Go to next message
Experts
I work on enterprise application that's build on SWT, SWING and JFACE. RCPTT dont support Swing. Are thr any plans to support or any other thrid party supports this interaction.
thanks
Re: SWING UI Automation [message #1742288 is a reply to message #1742251] Thu, 01 September 2016 08:49 Go to previous messageGo to next message
RCPTT is support only SWT and controls based on it, we do not plan to support Swing or AWT, this is because Swing etc uses different event loop and we can't be sure we will replay events in correct order.
If you have a custom control based on Swing I could recommend only to write special ECL commands for your case and use them in test to replay scenarios based on your controls:
https://www.eclipse.org/rcptt/documentation/userguide/ecl/new-command-guide/
Andrey.
Re: SWING UI Automation [message #1742478 is a reply to message #1742288] Fri, 02 September 2016 04:23 Go to previous message
thanks for quick response. Has anyone tried this before. Any specific know issues where it fails.
Previous Topic:Unable to Launch AUT with RCPTT
Next Topic:How to use tab next key to move next control
Current Time: Thu Nov 06 10:45:56 EST 2025
Powered by FUDForum. Page generated in 0.04617 seconds
