Re: C++ compiler error for Eclipse plugin [message #1741940 is a reply to message #1741886] |
Tue, 30 August 2016 17:03 |
Hi ejabnoo,
the gcc version used when compiling Titan has to be the same as the gcc version you want to use when compiling TTCN-3 projects.
So please let me know:
-what operating system you have
-what is the version of the installed gcc (gcc -v)
-what version of Titan you have installed (compiler -v)
-did you install a pre-built version -if yes, what's the name of the downloaded package?- or compiled from source?
BR
Elemer
Re: C++ compiler error for Eclipse plugin [message #1741953 is a reply to message #1741940] |
Tue, 30 August 2016 18:46 |
ejabnoo ejabnoo Messages: 4 Registered: August 2013 |
thanks for the prompt response
i have two gcc versions 4.8 and 5.4
using update alternative i am switching between them but none of them works
before you spend more time to help me can i get a link to gcc 5.3.1 to download and try with that first
thanks
follwoing are the output of the commands which were asked
ejabnoo@ubuntu:~/workspace/helloworld_ttcn_project/src$ compiler -v
TTCN-3 and ASN.1 Compiler for the TTCN-3 Test Executor
Product number: CRL 113 200/5 R5A
Build date: May 24 2016 12:50:36
Compiled with: GCC 5.3.1
Copyright (c) 2000-2016 Ericsson Telecom AB
ejabnoo@ubuntu:~/workspace/helloworld_ttcn_project/src$ dpkg -l | grep gcc | awk '{print $2}'
gcc
gcc-4.8
gcc-4.8-base:amd64
gcc-5
gcc-5-base:amd64
gcc-6-base:amd64
gir1.2-packagekitglib-1.0
libcaca0:amd64
libgcc-4.8-dev:amd64
libgcc-5-dev:amd64
libgcc1:amd64
libpackagekit-glib2-16:amd64
libunity-action-qt1:amd64
libwebrtc-audio-processing-0:amd64
qtchooser
qtdeclarative5-unity-action-plugin:amd64
ejabnoo@ubuntu:~/workspace/helloworld_ttcn_project/src$ g++ -v
Using built-in specs.
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 5.4.0-6ubuntu1~16.04.2' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-5 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-5-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-5-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.2)
ejabnoo@ubuntu:~/workspace/helloworld_ttcn_project/src$ gcc -v
COLLECT_GCC=gcc
Thread model: posix
Re: C++ compiler error for Eclipse plugin [message #1741956 is a reply to message #1741953] |
Tue, 30 August 2016 19:37 |
Hi ejabnoo,
so you have downloaded the Titan binary package built on Ubuntu 16.04
tcn3-5.5.pl0-linux64-gcc5.3-ubuntu16.04.tgz
which was compiled with gcc 5.3.1 which probably was the default for Ubuntu 16.04,
but your gcc is 5.4.0 now, likely due to an upgrade.
As these might not be exactly compatible , Titan complains.
So you either install gcc 5.3.1, or , probably simplest , download the source from https://github.com/eclipse/titan.core and compile it;
please check README.linux for instructions.
I hope this helps.
Best regards
Elemer
FUDForum. Page generated in 0.03978 seconds
