Re: ETSI ITS wireshark capture [message #1741895 is a reply to message #1741878] |
Tue, 30 August 2016 13:52 |
Hi Anandh,
-did you copy them to the right folder? You should see some other plug-ins there.
-did you restart wireshark?
I'll send you some files tomorrow, but I can confirm the plug-ins are working.
Maybe you can nudge it by selecting the packet and then telling wireshark to 'decode as'.
Best regards
Elemer
[Updated on: Tue, 30 August 2016 13:56] Report message to a moderator
Re: ETSI ITS wireshark capture [message #1741925 is a reply to message #1741913] |
Tue, 30 August 2016 15:34 |
Hi Anandh,
on a Ubuntu 14.04 my plugins are in
/usr/local/lib/wireshark/plugins/1.12.7/
ll /usr/local/lib/wireshark/plugins/1.12.7/
total 7416
drwxr-xr-x 2 root root 4096 Oct 13 2015 ./
drwxr-xr-x 4 root root 4096 Oct 13 2015 ../
-rwxr-xr-x 1 root root 28924 Oct 13 2015 btp.so*
-rwxr-xr-x 1 root root 199312 Oct 13 2015 cam.so*
-rwxr-xr-x 1 root root 211502 Oct 13 2015 denm.so*
-rwxr-xr-x 1 root root 968 Oct 13 2015 docsis.la*
-rwxr-xr-x 1 root root 819460 Oct 13 2015 docsis.so*
-rwxr-xr-x 1 root root 980 Oct 13 2015 ethercat.la*
-rwxr-xr-x 1 root root 332675 Oct 13 2015 ethercat.so*
-rwxr-xr-x 1 root root 155007 Oct 13 2015 gn.so*
-rwxr-xr-x 1 root root 974 Oct 13 2015 gryphon.la*
-rwxr-xr-x 1 root root 197262 Oct 13 2015 gryphon.so*
-rwxr-xr-x 1 root root 956 Oct 13 2015 irda.la*
-rwxr-xr-x 1 root root 154628 Oct 13 2015 irda.so*
-rwxr-xr-x 1 root root 129636 Oct 13 2015 itsut.so*
-rwxr-xr-x 1 root root 950 Oct 13 2015 m2m.la*
-rwxr-xr-x 1 root root 59434 Oct 13 2015 m2m.so*
-rwxr-xr-x 1 root root 316861 Oct 13 2015 map.so*
-rwxr-xr-x 1 root root 956 Oct 13 2015 mate.la*
-rwxr-xr-x 1 root root 304280 Oct 13 2015 mate.so*
-rwxr-xr-x 1 root root 962 Oct 13 2015 opcua.la*
-rwxr-xr-x 1 root root 669646 Oct 13 2015 opcua.so*
-rwxr-xr-x 1 root root 980 Oct 13 2015 profinet.la*
-rwxr-xr-x 1 root root 1186683 Oct 13 2015 profinet.so*
-rwxr-xr-x 1 root root 273314 Oct 13 2015 spat.so*
-rwxr-xr-x 1 root root 992 Oct 13 2015 stats_tree.la*
-rwxr-xr-x 1 root root 34411 Oct 13 2015 stats_tree.so*
-rwxr-xr-x 1 root root 974 Oct 13 2015 unistim.la*
-rwxr-xr-x 1 root root 287217 Oct 13 2015 unistim.so*
-rwxr-xr-x 1 root root 992 Oct 13 2015 wimaxasncp.la*
-rwxr-xr-x 1 root root 186272 Oct 13 2015 wimaxasncp.so*
-rwxr-xr-x 1 root root 962 Oct 13 2015 wimax.la*
-rwxr-xr-x 1 root root 998 Oct 13 2015 wimaxmacphy.la*
-rwxr-xr-x 1 root root 198858 Oct 13 2015 wimaxmacphy.so*
-rwxr-xr-x 1 root root 1742425 Oct 13 2015 wimax.so*
So I believe yours should be
in
/usr/local/lib/wireshark/plugins/1.12.13/
and not in
/usr/local/lib/wireshark/1.12.X/
(I'm missing "plugins" and the version should be exact)
What do you think?
Re: ETSI ITS wireshark capture [message #1743780 is a reply to message #1743746] |
Mon, 19 September 2016 14:58 |
Hi Anandh,
> Could you please let me know if these test cases are ported to Titan.
There is no straightforward answer to this; let me explain:
-Titan does not natively support PER encoding; in the solution you have we use an external open source ASN.1 compiler to generate PER encoding/decoding.
Unfortunately this compiler does not have support for Information object classes , and the version you have pointed out makes of of that. The earlier version we have used does not , so we could generate the PER encoding as described above.
So unfortunately there is no end-to-end open source solution available for newer versions of the ITS conformance stack.
However within the company we use a commercial ASN.1 compiler for PER ; if you buy the PER encoder from such a vendor, we can use it to write the PER codec functions. ETSI, and as far as we know, most TTCN-3 vendors are also using a 3rd party solution for PER codecs.
See more details here:
https://www.eclipse.org/forums/index.php/t/1070344/
Best regards
Elemer
FUDForum. Page generated in 0.05103 seconds
