Home » Modeling » TMF (Xtext) » Unit testing using CompilationTestHelper(Non-class file cannot be found when executing method trying to read that file.)
Re: Unit testing using CompilationTestHelper [message #1741890 is a reply to message #1741884] |
Tue, 30 August 2016 13:08 |
Marek Stankiewicz Messages: 11 Registered: June 2016 |
Junior Member |
This is snapshot of the test method:
@Inject extension ReflectExtensions
@Inject extension CompilationTestHelper
@Inject public TemporaryFolder temporaryFolder
@Test def void testMoveStatment() {
package example.one
import commonj.sdo.DataObject
import commonj.sdo.helper.DataFactory
import commonj.sdo.helper.XSDHelper
import org.eclipse.persistence.sdo.SDOType
jg-sys MySystem
jg-entity Person {
jg-attr number : int
jg-attr name : String
jg-action ShowPerson {
jg-imports {
jg-view imp jg-entity Person {
number, name
jg-exports {
jg-view exp jg-entity Person {
number, name
jg-main {
'''.compile [
allGeneratedResources.forEach[p1, p2|
println(p2)
getCompiledClass("example.one.ShowPerson").newInstance => [
it.invoke("entry")
All required code is generated correctly including xsd file.
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns="http://example.com/IPO" targetNamespace="http://example.com/IPO">
<xsd:element name="imp" type="Imp" />
<xsd:complexType name="Imp">
<xsd:attribute name="number" type="xsd:int" />
<xsd:attribute name="name" type="xsd:string" />
</xsd:complexType>
<xsd:element name="exp" type="Exp" />
<xsd:complexType name="Exp">
</xsd:complexType>
</xsd:schema>
package example.one;
import commonj.sdo.DataObject;
import commonj.sdo.helper.DataFactory;
import commonj.sdo.helper.XSDHelper;
import eu.jgen.gen.open.mdl.lib.IllegalRuntimeOperation;
import eu.jgen.gen.open.mdl.lib.JXActionBlock;
import eu.jgen.gen.open.mdl.lib.JXSimpleView;
import java.io.InputStream;
import java.net.URL;
import java.util.List;
import org.eclipse.persistence.sdo.SDOType;
@SuppressWarnings("all")
public class ShowPerson extends JXActionBlock {
private DataObject sdo;
private SDOType impType;
private SDOType expType;
public class Imp extends JXSimpleView {
public final static int START_PROPERTY_INDEX = 0;
public final static int END_PROPERTY_INDEX = START_PROPERTY_INDEX + 1;
public Imp(final DataObject sdo) {
super(sdo);
public void setNumber(final int value) {
get_sdo().set(START_PROPERTY_INDEX + 0, value);
public int getNumber() {
return get_sdo().getInt(START_PROPERTY_INDEX + 0);
public void setName(final String value) {
get_sdo().set(START_PROPERTY_INDEX + 1, value);
public String getName() {
return get_sdo().getString(START_PROPERTY_INDEX + 1);
public ShowPerson.Imp imp = null;
public class Exp extends JXSimpleView {
public Exp(final DataObject sdo) {
super(sdo);
public ShowPerson.Exp exp = null;
public ShowPerson() {
try {
URL url = ShowPerson.class.getResource("ShowPerson.xsd");
InputStream inputStream = url.openStream();
List<SDOType> list = XSDHelper.INSTANCE.define(inputStream, url.toString());
impType = findSDOType(list, "Imp");
imp = new ShowPerson.Imp(DataFactory.INSTANCE.create(impType));
expType = findSDOType(list, "Exp");
exp = new ShowPerson.Exp(DataFactory.INSTANCE.create(expType));
} catch (Exception e) {
throw new IllegalRuntimeOperation("ShowPerson: Cannot define SDO types");
public void entry() {
Test stops with
eu.jgen.gen.open.mdl.lib.IllegalRuntimeOperation: ShowPerson: Cannot define SDO types
at example.one.ShowPerson.<init>(ShowPerson.java:88)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
I am sure it fails on 'InputStream inputStream = url.openStream();'
Thanks for looking into the problem.
Re: Unit testing using CompilationTestHelper [message #1741935 is a reply to message #1741891] |
Tue, 30 August 2016 16:44 |
Junior Member |
I followed your advice and here is modified InMemoryJavaCompiler so can load non-java text files. It works for me.
package eu.jgen.gen.open.mdl.tests
import java.io.ByteArrayInputStream
import java.net.URL
import java.net.URLConnection
import java.util.HashMap
import java.util.Map
import java.util.Set
import org.eclipse.jdt.core.compiler.CategorizedProblem
import org.eclipse.jdt.internal.compiler.Compiler
import org.eclipse.jdt.internal.compiler.DefaultErrorHandlingPolicies
import org.eclipse.jdt.internal.compiler.batch.CompilationUnit
import org.eclipse.jdt.internal.compiler.classfmt.ClassFileConstants
import org.eclipse.jdt.internal.compiler.classfmt.ClassFileReader
import org.eclipse.jdt.internal.compiler.env.ICompilationUnit
import org.eclipse.jdt.internal.compiler.env.INameEnvironment
import org.eclipse.jdt.internal.compiler.env.NameEnvironmentAnswer
import org.eclipse.jdt.internal.compiler.impl.CompilerOptions
import org.eclipse.jdt.internal.compiler.problem.DefaultProblemFactory
import org.eclipse.xtend.lib.annotations.Accessors
import org.eclipse.xtend.lib.annotations.Data
import org.eclipse.xtend.lib.annotations.FinalFieldsConstructor
import org.eclipse.xtext.util.JavaVersion
import eu.jgen.gen.open.mdl.tests.InMemoryJavaCompiler2.Result
class InMemoryJavaCompiler2 {
@FinalFieldsConstructor private static class ClassLoaderBasedNameEnvironment implements INameEnvironment {
val ClassLoader classLoader
Map<String, NameEnvironmentAnswer> cache = newHashMap()
override cleanup() {
cache.clear
override findType(char[][] compoundTypeName) {
val fileName = compoundTypeName.map[String.valueOf(it)].join("/") + ".class"
if (cache.containsKey(fileName)) {
return cache.get(fileName)
val url = classLoader.getResource(fileName)
if (url == null) {
cache.put(fileName, null)
return null;
val reader = ClassFileReader.read(url.openStream, fileName)
val result = new NameEnvironmentAnswer(reader, null)
cache.put(fileName, result)
return result
override findType(char[] typeName, char[][] packageName) {
val fileName = packageName.map[String.valueOf(it)].join("/") + "/" + String.valueOf(typeName) + ".class"
if (url == null) {
return null;
return result
override isPackage(char[][] parentPackageName, char[] packageName) {
// Working hack
return Character.isLowerCase(packageName.head)
static package class ByteClassLoader extends ClassLoader {
Map<String, byte[]> classMap
JavaSource[] sources
new(Map<String, byte[]> classMap, ClassLoader parent, JavaSource[] sources) {
super(parent)
this.classMap = classMap
this.sources = sources
override protected Class<?> findClass(String name) throws ClassNotFoundException {
var byte[] bytes = classMap.get(name)
if (bytes === null) {
return super.findClass(name)
} else {
return defineClass(name, bytes, 0, bytes.length)
override protected findResource(String path) {
if (path.endsWith(".class")) {
val className = path.substring(0, path.length - 6).replace("/", ".")
val bytes = classMap.get(className)
if (bytes != null) {
return new URL("in-memory", null, -1, path, [
new URLConnection(it) {
override void connect() {}
override InputStream getInputStream() {
return new ByteArrayInputStream(bytes)
} else if (!path.endsWith(".class")) {
val source = sources.findFirst [ source |
source.fileName.endsWith(path)
if (source != null) {
val bytes = source.code.bytes
return null
val INameEnvironment nameEnv
val ClassLoader parentClassLoader
val CompilerOptions compilerOptions
new(ClassLoader parent, JavaVersion javaVersion) {
nameEnv = new ClassLoaderBasedNameEnvironment(parent)
parentClassLoader = parent
compilerOptions = new CompilerOptions
val classFmt = javaVersion.toClassFmt
sourceLevel = classFmt
complianceLevel = classFmt
compilerOptions.targetJDK = classFmt
compilerOptions.inlineJsrBytecode = true
compilerOptions.preserveAllLocalVariables = true
new(ClassLoader parent, CompilerOptions compilerOptions) {
this.compilerOptions = new CompilerOptions(compilerOptions.map)
private def long toClassFmt(JavaVersion version) {
switch (version) {
case JAVA5: return ClassFileConstants.JDK1_5
case JAVA6: return ClassFileConstants.JDK1_6
case JAVA7: return ClassFileConstants.JDK1_7
case JAVA8: return ((ClassFileConstants.MAJOR_VERSION_1_7 + 1) << 16) + ClassFileConstants.MINOR_VERSION_0 // ClassFileConstants.JDK1_8
* sets the source level (see @link(org.eclipse.jdt.internal.compiler.classfmt.ClassFileConstants))
private def void setSourceLevel(long jdkVersion) {
compilerOptions.sourceLevel = jdkVersion
// these fields have been introduces in JDT 3.7
try {
CompilerOptions.getField("originalSourceLevel").setLong(compilerOptions, jdkVersion)
} catch (NoSuchFieldException e) {
// ignore
* sets the compliance level (see @link(org.eclipse.jdt.internal.compiler.classfmt.ClassFileConstants))
private def void setComplianceLevel(long jdkVersion) {
compilerOptions.complianceLevel = jdkVersion
try {
CompilerOptions.getField("originalComplianceLevel").setLong(compilerOptions, jdkVersion)
// ignore
def Result compile(JavaSource... sources) {
val nonjavaSources = sources.filter[source |
!source.fileName.endsWith(".java")
val Result result = new Result(parentClassLoader, nonjavaSources)
var compiler = new Compiler(nameEnv, DefaultErrorHandlingPolicies.proceedWithAllProblems(), compilerOptions, [
for (cf : it.getClassFiles()) {
val name = String.valueOf(cf.fileName)
// println(name)
result.classMap.put(cf.compoundName.map[String.valueOf(it)].join('.'), cf.bytes)
new DefaultProblemFactory() {
override createProblem(char[] originatingFileName, int problemId, String[] problemArguments,
int elaborationId, String[] messageArguments, int severity, int startPosition, int endPosition,
int lineNumber, int columnNumber) {
val problem = super.createProblem(originatingFileName, problemId, problemArguments, elaborationId,
messageArguments, severity, startPosition, endPosition, lineNumber, columnNumber)
result.compilationProblems.add(problem)
return problem
String[] messageArguments, int severity, int startPosition, int endPosition, int lineNumber,
int columnNumber) {
return problem
val javaSources = sources.filter[source |
var ICompilationUnit[] units = javaSources.map[new CompilationUnit(code.toCharArray(), fileName, null)]
compiler.compile(units)
return result
@FinalFieldsConstructor public static class Result {
@Accessors val Set<CategorizedProblem> compilationProblems = newLinkedHashSet()
val classMap = new HashMap<String, byte[]>
val JavaSource[] sources
def ClassLoader getClassLoader() {
new ByteClassLoader(classMap, parentClassLoader, sources)
* @since 2.9
@Data class JavaSource {
String fileName
String code
Current Time: Sat Apr 27 03:24:19 GMT 2024
Powered by FUDForum. Page generated in 0.05196 seconds
