Home » Eclipse Projects » BPMN 2.0 Modeler » Change default drag/drop of task to abstract from script(How do I Change default drag/drop of task to abstract from script)
Change default drag/drop of task to abstract from script [message #1741829] Tue, 30 August 2016 01:44 Go to next message
Sean McPoland is currently offline Sean McPolandFriend
hi there,
I have a requirement to change the default drag/drop of task to abstract from script.
When using the toolbox it is easy to pick and drop what you need but some of our people like to design the full flow first and then assign the "type" of task, Script, Human, etc. They do this by using the drag/drop feature of the task to drop another task, but they always get script.
How do we change this default behaviour?
Many thanks and best regards
Re: Change default drag/drop of task to abstract from script [message #1741924 is a reply to message #1741829] Tue, 30 August 2016 15:33 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
Hmm, I'm not quite sure I understand what you're trying to do, but have you looked at using the "Morph" feature to change the Task type?
http://content.screencast.com/users/BobBrodt/folders/Jing/media/5371f1d3-04ea-4ec8-89b6-193562501fae/2016-08-30_0932.png
http://content.screencast.com/users/BobBrodt/folders/Jing/media/e3270841-68e2-43e5-88a0-ab432910ad65/2016-08-30_0933.png
Re: Change default drag/drop of task to abstract from script [message #1742064 is a reply to message #1741924] Wed, 31 August 2016 04:18 Go to previous messageGo to next message
Thanks but not quite,
When I drag a new task from the current selected task currently the newly created task is default (script), is there any way of changing what the default is?
thanks
Re: Change default drag/drop of task to abstract from script [message #1742462 is a reply to message #1742064] Thu, 01 September 2016 22:18 Go to previous messageGo to next message
OK, I still don't understand. What do you mean by "drag a new task from the current selected task"? Would it be possible to share a screencast?
Re: Change default drag/drop of task to abstract from script [message #1742549 is a reply to message #1742462] Sun, 04 September 2016 23:43 Go to previous messageGo to next message
Hi there,
sorry
it looks like there is an extension added to the tool I'm using that allows me to drag and drop new tasks as opposed to how it is implemented in the BPMN tool which is click->append.
Issue withdrawn, and thanks for the help.
regards
Re: Change default drag/drop of task to abstract from script [message #1743241 is a reply to message #1742549] Tue, 13 September 2016 14:05 Go to previous message
Uhhh...ok. I'm still not sure what was wrong :-/
Previous Topic:Can't create new BPMN2 model - project does not exist? Select parent folder?
Next Topic:Change font of selected elements
Current Time: Tue Mar 28 11:32:18 GMT 2023
Powered by FUDForum. Page generated in 0.02380 seconds
