Don't know where to start on Linux install [message #1741713] |
Sun, 28 August 2016 11:48 |
Richard Shearer Messages: 3 Registered: August 2016 |
What I want to do is install the report engine on my linux centos server through console. Then use the report designer on a windows machine. Unfortunately I am not very knowledgeable when it comes to linux.
My main issue is around the reports engine and I am not fully sure where to start.
I was guessing that I would just need the BIRT Runtime Release Build: 4.6.0
I have tried installing the engine on linux but I get the message the BIRT_HOME needs to be set I have read the readme about the below
In order to run the BIRT engine in command you should:
1. set BIRT_HOME to the directory where BIRT Report Runtime Package is extracted.
2. enter into $BIRT_HOME/ReportEngine folder.
But how do I set the BIRT_HOME? Within the genReport.sh file?
If so where abouts am I setting it? I have had a go but am having no luck at this.
FUDForum. Page generated in 0.02918 seconds
