Home » Newcomers » Newcomers » JPA validation error in Eclipse Neon JPA persistence.xml(Can't work out file location for <jar-file> entry that will satisfy Eclipse)
icon8.gif  JPA validation error in Eclipse Neon JPA persistence.xml [message #1741203] Tue, 23 August 2016 12:20 Go to next message
I've spent a couple of hours experimenting and googling and I can't find a solution and I can't even find an appropriate forum to post a message to.
Eclipse Neon is checking my JPA persistence.xml file in a JPA project and it can't find the required jar file specified in the <jar-file></jar-file> element of the persistence.xml file.
The Dali project doesn't look like the appropriate forum to ask - I don't actually have the Dali plugin installed, and anyway there's been virtually no traffic this year.
What is processing this persistence.xml file and the JPA facet I configured for this project? Where do I ask?
Adam
Re: JPA validation error in Eclipse Neon JPA persistence.xml [message #1741211 is a reply to message #1741203] Tue, 23 August 2016 12:47 Go to previous messageGo to next message
> Thanks
> Adam
Have you tried the Eclipse data tools platform (DTP) forum?
Re: JPA validation error in Eclipse Neon JPA persistence.xml [message #1741221 is a reply to message #1741211] Tue, 23 August 2016 16:16 Go to previous message
Russell Bateman wrote on Tue, 23 August 2016 12:47
The DTP forum is probably even more quiet than the Dali forum. :-)
The Dali forum would be the correct place to ask; but, yes, you are correct: it is pretty quiet.
Dali is most likely what is generating any messages related to your persistence.xml file. So: I'm guessing you actually do have the Dali plug-in installed. What Eclipse package are you using? If you are using "Eclipse IDE for EE Developers" you have Dali installed. Dali is what provides the functionality behind the JPA facet.
Finding a jar file listed in a persistence.xml file is not an insignificant task, given all the places it could be in your workspace. What is the exact error message? Where is the jar, relative to your project and/or workspace?
If this is the only Dali message causing you grief, you can disable it via the Dali preferences (Preferences > Java Persistence > JPA > Errors/Warnings).
Previous Topic:Installing Eclipse on MacBook Pro
Next Topic:Multiple User Installation
Current Time: Thu Jul 17 05:17:16 EDT 2025
Powered by FUDForum. Page generated in 0.17371 seconds
