Re: Use a Sonatype nexus p2 proxy to download with eclipse installer [message #1741255 is a reply to message #1741200] |
Wed, 24 August 2016 08:17 |
Dominique Jean-Prost Messages: 12 Registered: August 2016 |
I tried to add -Doomph.redirection.foo=http://download.eclipse.org/oomph/updates/milestone/latest->http://intra.my-company.com/nexus/repository/ in my eclipse-inst.ini, but the installer keep on trying to download from the internet. I don't know if it's because I made a mistake inmy configuration or because the url I mentionned in the redirection is not one that is currently used by eclipse installer.
I'm trying to use the Mirror of eclipse update site I setup in nexus.
Should I specify all the download url used my eclipse installer one by one ? Could my problem come form the fact that I'm using a incorrect uri-normally-used ?
Thank you.
dom
Here is my ini file
-Doomph.redirection.foo=http://download.eclipse.org/oomph/updates/milestone/latest->http://intra.my-company.com/nexus/repository/mars
-startup
plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.300.v20150602-1417
--launcher.appendVmargs
--launcher.XXMaxPermSize
256M
-name
Eclipse Installer
-data
@none
-vm
C:\Windows\system32
-vmargs
-Xms256M
-Xmx1024M
[Updated on: Wed, 24 August 2016 08:19] Report message to a moderator
Re: Use a Sonatype nexus p2 proxy to download with eclipse installer [message #1741256 is a reply to message #1741255] |
Wed, 24 August 2016 08:27 |
When trying with such a configuration,I get this log output, where you can see that my redirection is not mentionned and so not used.
Thank you.
Executing bootstrap tasks
Java(TM) SE Runtime Environment 1.8.0_45-b14
Product org.eclipse.products.epp.package.jee.latest
Bundle org.eclipse.oomph.setup 1.4.0.v20160530-1355, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Bundle org.eclipse.oomph.setup.core 1.4.0.v20160530-1200, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Bundle org.eclipse.oomph.setup.installer 1.4.0.v20160530-1200, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Bundle org.eclipse.oomph.setup.p2 1.4.0.v20160530-1200, build=2444, branch=d2a285619d608146f2b29fa5d42db7d6201863c2
Performing P2 Director (Eclipse IDE for Java EE Developers (Neon))
Offline = false
Mirrors = true
Resolving 63 requirements from 3 repositories to C:\bin\eclipse-test\jee-latest3\eclipse
Requirement epp.package.jee [4.6.0,5.0.0)
Requirement org.eclipse.platform.feature.group [4.6.0,5.0.0)
Requirement org.eclipse.rcp.feature.group [4.6.0,5.0.0)
Requirement org.eclipse.cft.server.core.feature.feature.group
Requirement org.eclipse.cft.server.ui.feature.feature.group
Requirement org.eclipse.datatools.common.doc.user.feature.group
Requirement org.eclipse.datatools.connectivity.doc.user.feature.group
Requirement org.eclipse.datatools.connectivity.feature.feature.group
Requirement org.eclipse.datatools.doc.user.feature.group
Requirement org.eclipse.datatools.enablement.feature.feature.group
Requirement org.eclipse.datatools.intro.feature.group
Requirement org.eclipse.datatools.modelbase.feature.feature.group
Requirement org.eclipse.datatools.sqldevtools.feature.feature.group
Requirement org.eclipse.datatools.sqltools.doc.user.feature.group
Requirement org.eclipse.egit.feature.group
Requirement org.eclipse.egit.mylyn.feature.group
Requirement org.eclipse.jdt.feature.group
Requirement org.eclipse.jpt.common.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.common.feature.feature.group
Requirement org.eclipse.jpt.dbws.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.jaxb.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.jaxb.feature.feature.group
Requirement org.eclipse.jpt.jpa.eclipselink.feature.feature.group
Requirement org.eclipse.jpt.jpa.feature.feature.group
Requirement org.eclipse.jsf.feature.feature.group
Requirement org.eclipse.jst.common.fproj.enablement.jdt.feature.group
Requirement org.eclipse.jst.enterprise_ui.feature.feature.group
Requirement org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature.feature.group
Requirement org.eclipse.jst.server_adapters.ext.feature.feature.group
Requirement org.eclipse.jst.server_adapters.feature.feature.group
Requirement org.eclipse.jst.server_ui.feature.feature.group
Requirement org.eclipse.jst.web_ui.feature.feature.group
Requirement org.eclipse.jst.webpageeditor.feature.feature.group
Requirement org.eclipse.jst.ws.axis2tools.feature.feature.group
Requirement org.eclipse.jst.ws.cxf.feature.feature.group
Requirement org.eclipse.jst.ws.jaxws.dom.feature.feature.group
Requirement org.eclipse.jst.ws.jaxws.feature.feature.group
Requirement org.eclipse.m2e.feature.feature.group
Requirement org.eclipse.m2e.logback.feature.feature.group
Requirement org.eclipse.m2e.wtp.feature.feature.group
Requirement org.eclipse.m2e.wtp.jaxrs.feature.feature.group
Requirement org.eclipse.m2e.wtp.jpa.feature.feature.group
Requirement org.eclipse.m2e.wtp.jsf.feature.feature.group
Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
Requirement org.eclipse.mylyn.context_feature.feature.group
Requirement org.eclipse.mylyn.ide_feature.feature.group
Requirement org.eclipse.mylyn.java_feature.feature.group
Requirement org.eclipse.mylyn.wikitext_feature.feature.group
Requirement org.eclipse.mylyn_feature.feature.group
Requirement org.eclipse.pde.feature.group
Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
Requirement org.eclipse.recommenders.rcp.feature.feature.group
Requirement org.eclipse.rse.feature.group
Requirement org.eclipse.rse.useractions.feature.group
Requirement org.eclipse.tm.terminal.feature.feature.group
Requirement org.eclipse.wst.common.fproj.feature.group
Requirement org.eclipse.wst.jsdt.chromium.debug.feature.feature.group
Requirement org.eclipse.wst.jsdt.feature.feature.group
Requirement org.eclipse.wst.server_adapters.feature.feature.group
Requirement org.eclipse.wst.web_ui.feature.feature.group
Requirement org.eclipse.wst.xml_ui.feature.feature.group
Requirement org.eclipse.wst.xsl.feature.feature.group
Requirement org.eclipse.oomph.setup.feature.group
Repository http://download.eclipse.org/technology/epp/packages/neon
Repository http://download.eclipse.org/releases/neon/201606221000
Repository http://download.eclipse.org/oomph/updates/milestone/latest
Adding repository http://download.eclipse.org/technology/epp/packages/neon
Adding repository http://download.eclipse.org/releases/neon/201606221000
Adding repository http://download.eclipse.org/oomph/updates/milestone/latest
ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 HTTP Proxy Authentication Required: http://download.eclipse.org/releases/neon/201606221000/content.xml
ERROR: org.eclipse.ecf.identity code=0 Proxy Authentication Required
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:287)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
FUDForum. Page generated in 0.05550 seconds
