Home » Modeling » TMF (Xtext) » Gets proposal for a position
Gets proposal for a position [message #1741025] Mon, 22 August 2016 08:12 Go to next message
Hello community,
i created the example xtext project (greetings).
Now iam looking for the function, which returns all proposal for a position.
Someting like that: Then i will get a proposal "Hello" etc.
parser.getProposals("He", 2);
Can anybody give me a hint, how to use the parser?
Thanks Michael
Re: Gets proposal for a position [message #1741038 is a reply to message #1741025] Mon, 22 August 2016 09:52 Go to previous messageGo to next message
hi you may digg into https://github.com/eclipse/xtext-core/blob/e1a4782403497dd27f73276c409049a3d3ecdcf9/org.eclipse.xtext.ide/src/org/eclipse/xtext/ide/server/contentassist/ContentAssistService.xtend or https://github.com/eclipse/xtext-web/blob/f4c4d9bb228014c01f8f468eab12e57ddcd26755/org.eclipse.xtext.web/src/main/java/org/eclipse/xtext/web/server/contentassist/ContentAssistService.xtend
Re: Gets proposal for a position [message #1741084 is a reply to message #1741038] Mon, 22 August 2016 16:29 Go to previous messageGo to next message
Thanks for your quick reply:
Tried it:
package org.xtext.example.mydsl.tests;
import org.eclipse.xtext.junit4.InjectWith;
import org.eclipse.xtext.junit4.XtextRunner;
import org.eclipse.xtext.util.ITextRegion;
import org.eclipse.xtext.util.TextRegion;
import org.eclipse.xtext.web.server.contentassist.ContentAssistResult;
import org.eclipse.xtext.web.server.contentassist.ContentAssistService;
import org.eclipse.xtext.web.server.model.XtextWebDocumentAccess;
import org.junit.Test;
import org.junit.runner.RunWith;
import org.xtext.example.mydsl.web.MyDslInjectorProvider;
import com.google.inject.Inject;
@RunWith(XtextRunner.class)
@InjectWith(MyDslInjectorProvider.class)
public class MyDslParsingTest {
	@Inject
	ContentAssistService contentAssistService;
	@Inject
	XtextWebDocumentAccess xtextWebDocumentAccess;
	@Test
	public void loadModel() {
		ITextRegion selection = new TextRegion(0, 3);
		ContentAssistResult result = contentAssistService.createProposals(xtextWebDocumentAccess, selection, 1, 1000);
		System.out.println(result);
but:
	at org.eclipse.xtext.web.server.model.XtextWebDocumentAccess.doAccess(XtextWebDocumentAccess.java:191)
	at org.eclipse.xtext.web.server.model.XtextWebDocumentAccess.priorityReadOnly(XtextWebDocumentAccess.java:164)
	at org.eclipse.xtext.web.server.contentassist.ContentAssistService.createProposals(ContentAssistService.java:78)
	at org.xtext.example.mydsl1.tests.MyDslParsingTest.loadModel(MyDslParsingTest.java:33)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
	at org.eclipse.xtext.junit4.XtextRunner$1.evaluate(XtextRunner.java:49)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:678)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Is there a small example?
Re: Gets proposal for a position [message #1741086 is a reply to message #1741084] Mon, 22 August 2016 17:07 Go to previous messageGo to next message
No i dont have a small example. I meant the code references more like a place to start digging than a injection and use reference
Re: Gets proposal for a position [message #1741093 is a reply to message #1741086] Tue, 23 August 2016 00:31 Go to previous messageGo to next message
i did just some playaround: btw. why do you want to do this?
@RunWith(XtextRunner)
@InjectWith(MyDslIdeInjectorProvider)
class MyDslParsingTest{
	static class MyDslIdeInjectorProvider extends MyDslInjectorProvider {
		override protected internalCreateInjector() {
			return new MyDslStandaloneSetup() {
			override Injector createInjector() {
				return Guice.createInjector(createRuntimeModule(), new MyDslIdeModule);
		}.createInjectorAndDoEMFRegistration();
	val List<ExecutorService> executorServices = newArrayList
	@Inject
	ParseHelper<Model> parseHelper
	@Inject Provider<ContentAssistContextFactory> contextFactoryProvider
	@Inject IdeContentProposalProvider proposalProvider
	ExecutorService executorService
	new() {
		executorService = Executors.newCachedThreadPool => [executorServices += it]
	@Test
	def void loadModel() {
		val model = '''
			Hello Xtext!
		val result = parseHelper.parse(model)
		Assert.assertNotNull(result)
		val contexts = (result.eResource as XtextResource).getContexts(new TextRegion(6,0), 6)
		val a = new IIdeContentProposalAcceptor {
			override accept(ContentAssistEntry e, int prio) {
				println(e.toString)
			override canAcceptMoreProposals() {
				true
		proposalProvider.createProposals(contexts, a)
	def ContentAssistContext[] getContexts(XtextResource resource, ITextRegion selection, int caretOffset) {
		val text = resource.parseResult.rootNode.text
		if (caretOffset > text.length)
			return #[]
		val contextFactory = contextFactoryProvider.get() => [it.pool = executorService]
		contextFactory.create(text, selection, caretOffset, resource)
	@After
	def void tearDown() {
		executorServices.forEach[shutdown()]
		executorServices.clear()
Re: Gets proposal for a position [message #1741112 is a reply to message #1741093] Tue, 23 August 2016 03:49 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 23 August 2016 04:31
Thanks a lot. I will try that.
I would like to integrate xText with Vaadin. I just need a Textfield (not a whole Editor) with auto completion or suggestion support. Additionally i need the parsing and error handling.
So the user enter "Hel" and now there is a suggestion to use the keyword "Hello"
	@Test
		val model = '''
			Hel
		val contexts = (result.eResource as XtextResource).getContexts(new TextRegion(3,0), 6)
				println(e.toString)
				true
[Updated on: Tue, 23 August 2016 04:36] by Moderator
Re: Gets proposal for a position [message #1741132 is a reply to message #1741112] Tue, 23 August 2016 05:33 Go to previous messageGo to next message
yoiu should have a look at the upcoming language server support in xtext 2.11 as well
Re: Gets proposal for a position [message #1741134 is a reply to message #1741132] Tue, 23 August 2016 05:41 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 23 August 2016 09:33
Sure, where can i find the server support?
Re: Gets proposal for a position [message #1741138 is a reply to message #1741134] Tue, 23 August 2016 06:18 Go to previous messageGo to next message
this is still wip. http://typefox.io/the-language-server-protocol-in-java might give a starting point
Re: Gets proposal for a position [message #1741141 is a reply to message #1741138] Tue, 23 August 2016 06:35 Go to previous messageGo to next message
Thanks for that, but i think is currently a little to powerful.
Iam just need 2 functions for my textfield.
Sugesstion support: e.g. if i enter 'Hell' then i get the suggestion 'Hello'.
And after typing i can parse the whole string and looking for erros. Thats it
Is this possible with the xtext runtime?
Re: Gets proposal for a position [message #1741144 is a reply to message #1741141] Tue, 23 August 2016 06:43 Go to previous messageGo to next message
sure. that should be no problem as my test shows
Re: Gets proposal for a position [message #1741146 is a reply to message #1741144] Tue, 23 August 2016 06:50 Go to previous messageGo to next message
Mhm sorry then iam don't get it Embarrassed
I changedt he model value from your test like:
But now the result is null. So how could i get the proposal "Hello" for the keyword?
	@Test
		val model = '''
			Hel
				println(e.toString)
				true
Re: Gets proposal for a position [message #1741149 is a reply to message #1741146] Tue, 23 August 2016 07:03 Go to previous messageGo to next message
well that was you abusing parsehelper Wink
 * generated by Xtext 2.10.0
package org.xtext.example.mydsl5.tests
import com.google.inject.Guice
import com.google.inject.Injector
import com.google.inject.Provider
import java.util.List
import java.util.concurrent.ExecutorService
import java.util.concurrent.Executors
import org.eclipse.emf.common.util.URI
import org.eclipse.xtext.ide.editor.contentassist.ContentAssistContext
import org.eclipse.xtext.ide.editor.contentassist.ContentAssistEntry
import org.eclipse.xtext.ide.editor.contentassist.IIdeContentProposalAcceptor
import org.eclipse.xtext.ide.editor.contentassist.IdeContentProposalProvider
import org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory
import org.eclipse.xtext.junit4.util.ParseHelper
import org.eclipse.xtext.resource.FileExtensionProvider
import org.eclipse.xtext.resource.XtextResource
import org.eclipse.xtext.resource.XtextResourceSet
import org.eclipse.xtext.util.StringInputStream
import org.junit.After
import org.xtext.example.mydsl5.MyDslStandaloneSetup
import org.xtext.example.mydsl5.ide.MyDslIdeModule
import org.xtext.example.mydsl5.myDsl.Model
	@Inject
	Provider<XtextResourceSet> rsp
	@Inject
	extension FileExtensionProvider
	new() {
	@Test
		val model = '''
			Hel
		val rs = rsp.get
		val resource = rs.createResource(URI.createURI("demo." + primaryFileExtension)) as XtextResource
		resource.load(new StringInputStream(model), null)
		val contexts = resource.getContexts(new TextRegion(3,0), 3)
				println(e.toString)
				true
			return #[]
	@After
Re: Gets proposal for a position [message #1741152 is a reply to message #1741149] Tue, 23 August 2016 07:30 Go to previous message
Thanks a lot for the support. Thats an good starting point Very Happy
Previous Topic:How to add xtext sdk with eclipse plugin?
Next Topic:Parsing exception in xtext grammar
Current Time: Thu Sep 25 17:25:53 EDT 2025
Powered by FUDForum. Page generated in 0.05595 seconds
