Home » Eclipse Projects » Eclipse Platform » New java project does not get created correctly on network share
New java project does not get created correctly on network share [message #1740763] Thu, 18 August 2016 06:49 Go to next message
I have a problem which I already posted at http://eclip.se/499603 but maybe someone here is able to help.
When I create a new Java project and use a network share as location, an error with following message occurs:
"Problems encountered while setting project description.
Could not write file: H:\workspaces\eclipse45\test2\sdf\.project."
I can see that the ".project" file gets created. Manually, I am also able to modify it. Looking at the Windows permissions seems also fine, as I am allowed to write on that file, but nobody else.
When I create the project on a local drive, everything works fine. But since I am in a school environment, it is necessary that a project gets created on each student's home directory on the network share.
I am using Mars.2 but trying with Neon gave the same result.
Does anyone have an idea what might cause this problem? Can I provide more information?
Best regards
Sebastian
Re: New java project does not get created correctly on network share [message #1752021 is a reply to message #1740763] Tue, 17 January 2017 19:43 Go to previous message
I'm having the same issue. Any update?
Previous Topic:AGAIN! After Eclipse update the setup won't start any more
Next Topic:bundleresource:// URL problem in library plugin
Current Time: Fri Apr 25 02:35:18 EDT 2025
Powered by FUDForum. Page generated in 0.03164 seconds
