Re: Two DSL in same project [message #1740729 is a reply to message #1740728] |
Wed, 17 August 2016 19:45 |
if you use a generated metamodel and not a imported one you need emfgeneratorfragment (compare your workflow with a newly created one.
and you have to take care for the file extensions.
is there a reason you want to have this in one project?
module org.xtext.example.mydsla.GenerateMyDslA
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/org/xtext/example/mydsla/MyDslA.xtext"
var grammarURI2 = "classpath:/org/xtext/example/mydsla/MyDslB.xtext"
var projectName = "org.xtext.example.mydsls"
var runtimeProject = "../${projectName}"
var generateXtendStub = true
var encoding = "UTF-8"
Workflow {
bean = StandaloneSetup {
scanClassPath = true
platformUri = "${runtimeProject}/.."
// The following two lines can be removed, if Xbase is not used.
registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
component = DirectoryCleaner {
directory = "${runtimeProject}/src-gen"
directory = "${runtimeProject}/model/generated"
directory = "${runtimeProject}.ui/src-gen"
directory = "${runtimeProject}.tests/src-gen"
component = Generator {
pathRtProject = runtimeProject
pathUiProject = "${runtimeProject}.ui"
pathTestProject = "${runtimeProject}.tests"
projectNameRt = projectName
projectNameUi = "${projectName}.ui"
encoding = encoding
language = auto-inject {
fileExtensions = "mydsla"
uri = grammarURI
// Java API to access grammar elements (required by several other fragments)
fragment = grammarAccess.GrammarAccessFragment auto-inject {}
// generates Java API for the generated EPackages
fragment = ecore.EMFGeneratorFragment auto-inject {}
// the old serialization component
// fragment = parseTreeConstructor.ParseTreeConstructorFragment auto-inject {}
// serializer 2.0
fragment = serializer.SerializerFragment auto-inject {
generateStub = false
// a custom ResourceFactory for use with EMF
fragment = resourceFactory.ResourceFactoryFragment auto-inject {}
// The antlr parser generator fragment.
fragment = parser.antlr.XtextAntlrGeneratorFragment auto-inject {
// options = {
// backtrack = true
// Xtend-based API for validation
fragment = validation.ValidatorFragment auto-inject {
// composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// old scoping and exporting API
// fragment = scoping.ImportURIScopingFragment auto-inject {}
// fragment = exporting.SimpleNamesFragment auto-inject {}
// scoping and exporting API
fragment = scoping.ImportNamespacesScopingFragment auto-inject {}
fragment = exporting.QualifiedNamesFragment auto-inject {}
fragment = builder.BuilderIntegrationFragment auto-inject {}
// generator API
fragment = generator.GeneratorFragment auto-inject {}
// formatter API
fragment = formatting.FormatterFragment auto-inject {}
// labeling API
fragment = labeling.LabelProviderFragment auto-inject {}
// outline API
fragment = outline.OutlineTreeProviderFragment auto-inject {}
fragment = outline.QuickOutlineFragment auto-inject {}
// quickfix API
fragment = quickfix.QuickfixProviderFragment auto-inject {}
// content assist API
fragment = contentAssist.ContentAssistFragment auto-inject {}
// generates a more lightweight Antlr parser and lexer tailored for content assist
fragment = parser.antlr.XtextAntlrUiGeneratorFragment auto-inject {}
// generates junit test support classes into Generator#pathTestProject
fragment = junit.Junit4Fragment auto-inject {}
// rename refactoring
fragment = refactoring.RefactorElementNameFragment auto-inject {}
// provides the necessary bindings for java types integration
fragment = types.TypesGeneratorFragment auto-inject {}
// generates the required bindings only if the grammar inherits from Xbase
fragment = xbase.XbaseGeneratorFragment auto-inject {}
// generates the required bindings only if the grammar inherits from Xtype
fragment = xbase.XtypeGeneratorFragment auto-inject {}
// provides a preference page for template proposals
fragment = templates.CodetemplatesGeneratorFragment auto-inject {}
// provides a compare view
fragment = compare.CompareFragment auto-inject {
fileExtensions = "mydslb"
uri = grammarURI2
// serializer 2.0
// options = {
// backtrack = true
// generator API
// formatter API
// labeling API
// outline API
// quickfix API
Twitter : @chrdietrich
FUDForum. Page generated in 0.04524 seconds
