[NEON] Key Generation with secp256k1 [message #1740531] |
Mon, 15 August 2016 12:52 |
Thomas Mangold Messages: 7 Registered: October 2013 |
With new Scout Neon, the generation of a new Scout-Project compiles, but the client can't connect, because the generation of the key pair fails. I'm working on Linux Fedora24 x64 with jdk1.8.0_101.
On generation of the new scout project this warning is thrown, but the project is generated:
[WARNING]: Could not generate a new key pair.
java.security.InvalidAlgorithmParameterException: Unknown curve name: secp256k1
at sun.security.ec.ECKeyPairGenerator.initialize(ECKeyPairGenerator.java:100)
at java.security.KeyPairGenerator$Delegate.initialize(KeyPairGenerator.java:667)
at org.eclipse.scout.sdk.core.util.CoreUtils.generateKeyPair(CoreUtils.java:126)
at org.eclipse.scout.sdk.core.s.project.ScoutProjectNewHelper.generateKeyPair(ScoutProjectNewHelper.java:123)
at org.eclipse.scout.sdk.core.s.project.ScoutProjectNewHelper.createProject(ScoutProjectNewHelper.java:106)
at org.eclipse.scout.sdk.s2e.operation.project.ScoutProjectNewOperation.run(ScoutProjectNewOperation.java:95)
at org.eclipse.scout.sdk.s2e.job.ResourceBlockingOperationJob.run(ResourceBlockingOperationJob.java:104)
at org.eclipse.scout.sdk.s2e.job.AbstractResourceBlockingJob.doRun(AbstractResourceBlockingJob.java:87)
at org.eclipse.scout.sdk.s2e.job.AbstractResourceBlockingJob.run(AbstractResourceBlockingJob.java:75)
at org.eclipse.scout.sdk.core.s.project.ScoutProjectNewHelper.createProject(ScoutProjectNewHelper.java:107)
Where an how do I have do put in the key pair into the configuration? On starting the client, this error is thrown and I presume, this is somehow related to the missing key pair:
2016-08-15 14:47:48,004 INFO [main] org.eclipse.scout.dev.jetty.JettyServer - Starting Jetty with resourceBase=/home/u111979/workspaces/clique/trunk/clique/clique.ui.html.app.dev/src/main/webapp - MDC[]
2016-08-15 14:47:48,030 INFO [main] org.eclipse.jetty.server.Server - jetty-9.2.13.v20150730 - MDC[]
2016-08-15 14:47:48,141 INFO [main] org.eclipse.jetty.webapp.StandardDescriptorProcessor - NO JSP Support for /, did not find org.eclipse.jetty.jsp.JettyJspServlet - MDC[]
2016-08-15 14:47:48,270 INFO [Thread-9] org.eclipse.scout.rt.platform.inventory.internal.JandexInventoryBuilder - forcing rebuild of index 'file:/home/u111979/workspaces/clique/trunk/clique/clique.ui.html/target/classes/META-INF/jandex.idx'. scanning location... - MDC[]
2016-08-15 14:47:48,423 INFO [Thread-9] org.eclipse.scout.rt.platform.inventory.internal.JandexInventoryBuilder - forcing rebuild of index 'file:/home/u111979/workspaces/clique/trunk/clique/clique.client/target/classes/META-INF/jandex.idx'. scanning location... - MDC[]
2016-08-15 14:47:48,434 INFO [Thread-9] org.eclipse.scout.rt.platform.inventory.internal.JandexInventoryBuilder - forcing rebuild of index 'file:/home/u111979/workspaces/clique/trunk/clique/clique.shared/target/classes/META-INF/jandex.idx'. scanning location... - MDC[]
2016-08-15 14:47:48,438 INFO [Thread-9] org.eclipse.scout.rt.platform.inventory.ClassInventory - Finished preparation of jandex class inventory in 233.264369 ms - MDC[]
2016-08-15 14:47:48,720 INFO [Thread-9] org.eclipse.scout.rt.platform.job.internal.DevelopmentThreadNameDecorator - +++ Development thread name decoration - MDC[]
2016-08-15 14:47:48,727 INFO [Thread-9] org.eclipse.scout.rt.platform.logger.LoggerPlatformListener - registered logger support [org.eclipse.scout.rt.platform.logger.LogbackLoggerSupport] - MDC[]
2016-08-15 14:47:48,728 INFO [Thread-9] org.eclipse.scout.rt.shared.services.common.code.CodeTypeRegistrator - 0 code type classes registered. - MDC[]
2016-08-15 14:47:48,752 INFO [Thread-9] org.eclipse.scout.rt.shared.servicetunnel.RegisterTunnelToServerPlatformListener - Tunnel to server proxies registered. - MDC[]
2016-08-15 14:47:48,754 INFO [Thread-9] org.eclipse.scout.rt.shared.servicetunnel.http.MultiSessionCookieStoreInstaller - Successfully installed java.net.CookieManager@5e4fac9b (Cookie store: org.eclipse.scout.rt.shared.servicetunnel.http.MultiSessionCookieStore@9596e8f) - MDC[]
2016-08-15 14:47:48,868 INFO [main] org.eclipse.jetty.server.handler.ContextHandler - Started o.e.s.d.j.P_WebAppContext@5d76b067{/,file:/home/u111979/workspaces/clique/trunk/clique/clique.ui.html.app.dev/src/main/webapp/,AVAILABLE} - MDC[]
2016-08-15 14:47:48,872 ERROR [scout-thread-2 ClientNotificationPoller] org.eclipse.scout.rt.client.clientnotification.ClientNotificationPoller - Error receiving client notifications - MDC[principal=notification-authenticator, jobName=ClientNotificationPoller]
org.eclipse.scout.rt.platform.exception.PlatformException: org.eclipse.scout.rt.platform.exception.PlatformException: Invalid signature setup [translator=org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator, user=notification-authenticator, calling-thread=scout-thread-2 ClientNotificationPoller, job=Tunneling service request [seq=1, submitter=ClientNotificationPoller]]
at org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator.translateInternal(DefaultRuntimeExceptionTranslator.java:54)
at org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator.translate(DefaultRuntimeExceptionTranslator.java:37)
at org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator.translate(DefaultRuntimeExceptionTranslator.java:1)
at org.eclipse.scout.rt.platform.job.internal.JobExceptionTranslator.translateExecutionException(JobExceptionTranslator.java:63)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.awaitDoneAndGet(JobFutureTask.java:392)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.awaitDoneAndGet(JobFutureTask.java:381)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.tunnel(HttpServiceTunnel.java:230)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:48)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:42)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:191)
at org.eclipse.scout.rt.shared.servicetunnel.ServiceTunnelProxyProducer.invoke(ServiceTunnelProxyProducer.java:43)
at org.eclipse.scout.rt.platform.interceptor.DecoratingProxy.invokeImpl(DecoratingProxy.java:134)
at org.eclipse.scout.rt.platform.interceptor.DecoratingProxy$P_InvocationHandler.invoke(DecoratingProxy.java:172)
at com.sun.proxy.$Proxy16.getNotifications(Unknown Source)
at org.eclipse.scout.rt.client.clientnotification.ClientNotificationPoller$P_NotificationPoller.run(ClientNotificationPoller.java:84)
at org.eclipse.scout.rt.platform.util.concurrent.Callables$1.call(Callables.java:37)
at org.eclipse.scout.rt.platform.util.concurrent.Callables$1.call(Callables.java:1)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:185)
at org.eclipse.scout.rt.platform.job.internal.ExceptionProcessor.intercept(ExceptionProcessor.java:41)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:180)
at org.eclipse.scout.rt.platform.context.RunContextRunner$1.call(RunContextRunner.java:42)
at org.eclipse.scout.rt.platform.security.SubjectProcessor$1.run(SubjectProcessor.java:47)
at javax.security.auth.Subject.doAs(Subject.java:422)
at org.eclipse.scout.rt.platform.security.SubjectProcessor.intercept(SubjectProcessor.java:43)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:135)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:121)
at org.eclipse.scout.rt.platform.context.RunContextRunner.intercept(RunContextRunner.java:38)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask$1.call(JobFutureTask.java:100)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.run(JobFutureTask.java:160)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
at org.eclipse.scout.rt.platform.job.internal.NamedThreadFactory$1.run(NamedThreadFactory.java:54)
Caused by: java.io.IOException: org.eclipse.scout.rt.platform.exception.PlatformException: Invalid signature setup
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.addSignatureHeader(HttpServiceTunnel.java:137)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.addCustomHeaders(HttpServiceTunnel.java:125)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.createURLConnection(HttpServiceTunnel.java:113)
at org.eclipse.scout.rt.shared.servicetunnel.http.RemoteServiceInvocationCallable.call(RemoteServiceInvocationCallable.java:73)
at org.eclipse.scout.rt.shared.servicetunnel.http.RemoteServiceInvocationCallable.call(RemoteServiceInvocationCallable.java:1)
... 12 common frames omitted
Caused by: org.eclipse.scout.rt.platform.exception.PlatformException: Invalid signature setup
at org.eclipse.scout.rt.shared.servicetunnel.http.DefaultAuthToken.init(DefaultAuthToken.java:103)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.createAuthToken(HttpServiceTunnel.java:164)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.addSignatureHeader(HttpServiceTunnel.java:131)
... 19 common frames omitted
Caused by: org.eclipse.scout.rt.platform.exception.ProcessingException: unable to create signature. [severity=ERROR]
at org.eclipse.scout.rt.platform.security.SecurityUtility.createSignature(SecurityUtility.java:423)
at org.eclipse.scout.rt.shared.servicetunnel.http.DefaultAuthToken.sign(DefaultAuthToken.java:156)
at org.eclipse.scout.rt.shared.servicetunnel.http.DefaultAuthToken.init(DefaultAuthToken.java:100)
... 21 common frames omitted
Caused by: java.security.spec.InvalidKeySpecException: java.security.InvalidKeyException: IOException : DerInputStream.getLength(): lengthTag=96, too big.
at sun.security.ec.ECKeyFactory.engineGeneratePrivate(ECKeyFactory.java:169)
at java.security.KeyFactory.generatePrivate(KeyFactory.java:366)
at org.eclipse.scout.rt.platform.security.SecurityUtility.createSignature(SecurityUtility.java:413)
... 23 common frames omitted
Caused by: java.security.InvalidKeyException: IOException : DerInputStream.getLength(): lengthTag=96, too big.
at sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:351)
at sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:356)
at sun.security.ec.ECPrivateKeyImpl.<init>(ECPrivateKeyImpl.java:73)
at sun.security.ec.ECKeyFactory.implGeneratePrivate(ECKeyFactory.java:237)
at sun.security.ec.ECKeyFactory.engineGeneratePrivate(ECKeyFactory.java:165)
... 25 common frames omitted
2016-08-15 14:47:48,883 INFO [main] org.eclipse.jetty.server.ServerConnector - Started ServerConnector@4a615877{HTTP/1.1}{0.0.0.0:8082} - MDC[]
Re: [NEON] Key Generation with secp256k1 [message #1775027 is a reply to message #1742248] |
Mon, 23 October 2017 17:03 |
Dan Mumford Messages: 20 Registered: October 2017 Location: US |
I am having this issue in a Linux environment (Centos 7.0) with OpenJDK8. Was there any resolution?
My OpenSSL does support secp256k1 but I am not sure how to make the jump from there to TODO_use_org.eclipse.scout.rt.platform.security.SecurityUtility.main(String[])).
A solution would be great as I am sure others have been discouraged by this.
I am aware this is an old post.
[Updated on: Mon, 23 October 2017 17:04] Report message to a moderator
Re: [NEON] Key Generation with secp256k1 [message #1775550 is a reply to message #1775100] |
Tue, 31 October 2017 23:44 |
OK. So Either I associated my issue with this post because they both referenced "Error receiving client notifications " or I actually saw a reference to "secp256k1". I actually hold myself to a higher standard then to quote "secp256k1" without seeing it but it is no longer referenced in the compilation output. After Thinking that the Java environments should be the same I explicitly pointed Eclipse to the Java 1.8 JDK via the eclipse.ini file and got the below error output. Centos 7.0 environment.
INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building Maven Stub Project (No POM) 1
[INFO]
[INFO] >>> maven-archetype-plugin:3.0.1:generate (default-cli) > generate-sources @ standalone-pom >>>
[INFO]
[INFO] <<< maven-archetype-plugin:3.0.1:generate (default-cli) < generate-sources @ standalone-pom <<<
[INFO]
[INFO] --- maven-archetype-plugin:3.0.1:generate (default-cli) @ standalone-pom ---
[INFO] Generating project in Batch mode
[INFO] Archetype repository not defined. Using the one from [org.eclipse.scout.archetypes:scout-helloworld-app:7.1.0.001_Photon_M2] found in catalog remote
[INFO] ----------------------------------------------------------------------------
[INFO] Using following parameters for creating project from Archetype: scout-helloworld-app:6.0.300.RC2
[INFO] Parameter: groupId, Value: org.eclipse.scout.apps
[INFO] Parameter: artifactId, Value: helloworld3
[INFO] Parameter: version, Value: 1.0.0-SNAPSHOT
[INFO] Parameter: package, Value: org.eclipse.scout.apps.helloworld3
[INFO] Parameter: packageInPathFormat, Value: org/eclipse/scout/apps/helloworld3
[INFO] Parameter: scoutAuthPublicKeyDev, Value: TODO_use_org.eclipse.scout.rt.platform.security.SecurityUtility.main(String[]))
[INFO] Parameter: scoutAuthPublicKey, Value: TODO_use_org.eclipse.scout.rt.platform.security.SecurityUtility.main(String[]))
[INFO] Parameter: scoutAuthPrivateKeyDev, Value: TODO_use_org.eclipse.scout.rt.platform.security.SecurityUtility.main(String[]))
[INFO] Parameter: userName, Value: dmumford
[INFO] Parameter: displayName, Value: My Application
[INFO] Parameter: javaVersion, Value: 1.8
[INFO] Parameter: scoutAuthPrivateKey, Value: TODO_use_org.eclipse.scout.rt.platform.security.SecurityUtility.main(String[]))
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3/pom.xml
[WARNING] Don't override file /home/dmumford/workspace/helloworld3/helloworld3/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.shared/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.server/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.client/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.server.app.war/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.server.app.dev/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.ui.html/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.ui.html.app.war/pom.xml
[INFO] Parent element not overwritten in /home/dmumford/workspace/helloworld3/helloworld3.ui.html.app.dev/pom.xml
[INFO] Project created from Archetype in dir: /home/dmumford/workspace/helloworld3
[INFO] BUILD SUCCESS
[INFO] Total time: 4.085 s[INFO] Scanning for projects...
2017-10-31 19:26:17,118 ERROR [scout-thread-2 ClientNotificationPoller] org.eclipse.scout.rt.client.clientnotification.ClientNotificationPoller - Error receiving client notifications - MDC[principal=notification-authenticator, jobName=ClientNotificationPoller]
org.eclipse.scout.rt.platform.exception.PlatformException: org.eclipse.scout.rt.platform.exception.PlatformException: Invalid signature setup [translator=org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator, user=notification-authenticator, calling-thread=scout-thread-2 ClientNotificationPoller, job=Tunneling service request [seq=23, submitter=ClientNotificationPoller]]
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.awaitDoneAndGet(Jo"secp256k1"bFutureTask.java:392)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.tunnel(HttpServiceTunnel.java:247)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:52)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:44)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:208)
at com.sun.proxy.$Proxy17.getNotifications(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.addSignatureHeader(HttpServiceTunnel.java:154)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.addCustomHeaders(HttpServiceTunnel.java:126)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.addCustomHeaders(HttpServiceTunnel.java:143)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.createAuthToken(HttpServiceTunnel.java:181)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.addSignatureHeader(HttpServiceTunnel.java:148)
... 20 common frames omitted
... 22 common frames omitted
... 24 common frames omitted
at sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:352)
at sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:357)
... 26 common frames omitted
Any clue? The "secp256k1" warning was not in my subsequent project creation.
[Updated on: Wed, 01 November 2017 00:03] Report message to a moderator
FUDForum. Page generated in 0.05346 seconds
