Home » Modeling » TMF (Xtext) » Update a viewpart when dsl is modified
Update a viewpart when dsl is modified [message #1740313] Thu, 11 August 2016 09:28 Go to next message
Hello everybody,
I have a calculation with a list of x and y values. When I add values to the dsl, I want to update my diagram with x and y axis. How can I fill the Diagramm with the calculated values in the dsl.
Maybe it should be listen on value change in the editorpart.
Best regards.
Dim
Re: Update a viewpart when dsl is modified [message #1740316 is a reply to message #1740313] Thu, 11 August 2016 09:59 Go to previous messageGo to next message
there are multiple possible ways to do such things e.g.
org.eclipse.xtext.resource.IResourceDescription.Event.Listener.descriptionsChanged(Event) for changes in the builder
org.eclipse.xtext.ui.editor.model.IXtextModelListener.modelChanged(XtextResource) (at the editors ixtextdocument)
Re: Update a viewpart when dsl is modified [message #1740367 is a reply to message #1740316] Fri, 12 August 2016 06:07 Go to previous messageGo to next message
Where is the builder to find?
And how to add the modelChanged Listener to the XTextEditor and on which place?
Re: Update a viewpart when dsl is modified [message #1740369 is a reply to message #1740367] Fri, 12 August 2016 06:20 Go to previous messageGo to next message
You can inject clusteringbuilderstate
For the editor: I assumed you have already a Xtext editor in your hand
Then you can ask it for its document
Re: Update a viewpart when dsl is modified [message #1740425 is a reply to message #1740369] Fri, 12 August 2016 13:53 Go to previous message
It works, thank you very much!
Previous Topic:New project generated from existing metamodel contains errors
Next Topic:create custom folder structure
Current Time: Fri Sep 26 13:49:46 EDT 2025
Powered by FUDForum. Page generated in 0.04195 seconds
