Home » Eclipse Projects » Eclipse 4 » MessageConsole
MessageConsole [message #1740292] Thu, 11 August 2016 05:34
I need to create a message console and show this console by using a
ConsoleHelper class with following methods.
	public MessageConsole findConsole(String name) {
		ConsolePlugin plugin = ConsolePlugin.getDefault();
		IConsoleManager conMan = plugin.getConsoleManager();
		IConsole[] existing = conMan.getConsoles();
		for (int i = 0; i < existing.length; i++)
			if (name.equals(existing[i].getName()))
				return (MessageConsole) existing[i];
		// no console found, so create a new one
		MessageConsole myConsole = new MessageConsole(name, null);
		conMan.addConsoles(new IConsole[] { myConsole });
		return myConsole;
and pin the console
	public void pinConsole(String pConsoleName, String pSecondaryID) {
		IWorkbench lWb = PlatformUI.getWorkbench();
		IWorkbenchWindow lWindow = lWb.getActiveWorkbenchWindow();
		IWorkbenchPage lPage = lWindow.getActivePage();
		IConsole lConsole = findConsole(pConsoleName);
		try {
			if (null != lPage) {
				IViewPart lVp = lPage.showView(IConsoleConstants.ID_CONSOLE_VIEW,
null, IWorkbenchPage.VIEW_ACTIVATE);
				if (null != lVp && lVp instanceof IConsoleView) {
					IConsoleView lCv = ((IConsoleView) lVp);
					lCv.setPinned(false);
					lCv.display(lConsole);
					lCv.setPinned(true);
		} catch (PartInitException e) {
			e.printStackTrace();
this works fine, but when I switch the perspectives I get:
!ENTRY org.eclipse.equinox.event 4 0 2016-08-11 11:32:57.206
!MESSAGE Exception while dispatching event org.osgi.service.event.Event
[topic=org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/SET]
{ChangedElement=org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl@36857d32
(elementId: org.eclipse.ui.ide.perspectivestack, tags: [],
contributorURI: null) (widget: Composite {}, renderer:
org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer@3d2b13f,
toBeRendered: true, onTop: false, visible: true, containerData: 7500,
accessibilityPhrase: null),
org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl@36857d32
accessibilityPhrase: null), AttName=selectedElement, EventType=SET,
OldValue=org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveImpl@6ea1fc9
(elementId: org.eclipse.wst.xml.ui.perspective, tags:
[persp.actionSet:org.eclipse.ui.cheatsheets.actionSet,
persp.actionSet:org.eclipse.search.searchActionSet,
persp.actionSet:org.eclipse.ui.edit.text.actionSet.annotationNavigation,
persp.actionSet:org.eclipse.ui.edit.text.actionSet.navigation,
persp.actionSet:org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo,
persp.actionSet:org.eclipse.ui.externaltools.ExternalToolsSet,
persp.actionSet:org.eclipse.ui.actionSet.keyBindings,
persp.actionSet:org.eclipse.ui.actionSet.openFiles,
persp.actionSet:file.actions, persp.actionSet:edit.actions,
persp.viewSC:org.eclipse.ui.navigator.ProjectExplorer,
persp.perspSC:de.bahntechnik.dd.opn.ui.perspective,
persp.perspSC:org.eclipse.ui.resourcePerspective,
persp.perspSC:org.eclipse.wst.xml.ui.perspective,
persp.perspSC:de.bahntechnik.dd.opn.psc.prj.ui.perspective,
persp.actionSet:org.eclipse.debug.ui.launchActionSet,
persp.newWizSC:org.eclipse.wst.xml.ui.internal.wizards.NewXMLWizard,
persp.newWizSC:org.eclipse.wst.xsd.ui.internal.wizards.NewXSDWizard,
persp.newWizSC:org.eclipse.wst.dtd.ui.internal.wizard.NewDTDWizard,
persp.newWizSC:org.eclipse.ui.wizards.new.folder,
persp.newWizSC:org.eclipse.ui.wizards.new.file,
persp.newWizSC:org.eclipse.ui.editors.wizards.UntitledTextFileWizard,
persp.viewSC:org.eclipse.ui.views.ResourceNavigator,
persp.viewSC:org.eclipse.ui.views.ContentOutline,
persp.viewSC:org.eclipse.ui.views.PropertySheet,
persp.viewSC:org.eclipse.ui.views.ProblemView,
persp.viewSC:org.eclipse.ui.console.ConsoleView,
persp.viewSC:org.eclipse.ui.views.TaskList,
persp.viewSC:org.eclipse.search.ui.views.SearchView,
persp.viewSC:org.eclipse.ui.views.ProgressView,
persp.perspSC:org.eclipse.debug.ui.DebugPerspective], contributorURI:
org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer@f10927f,
toBeRendered: true, onTop: false, visible: true, containerData: null,
accessibilityPhrase: null) (label: XML, iconURI:
platform:/plugin/org.eclipse.wst.xml.ui/$nl$/icons/full/xml_perspective.gif,
tooltip: null, context: PerspectiveImpl
(org.eclipse.wst.xml.ui.perspective) Context, variables: []),
Widget=Composite {},
NewValue=org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveImpl@3497ecea
(elementId: de.bahntechnik.dd.opn.ui.perspective, tags:
[persp.actionSet:org.eclipse.search.searchActionSet], contributorURI:
platform:/plugin/de.bahntechnik.dd.opn.ui) (widget: Composite {},
renderer:
accessibilityPhrase: null) (label: Simulation, iconURI:
platform:/plugin/de.bahntechnik.dd.opn.ui/icons/obj16/OPN_start_16x16.png,
tooltip: , context: PerspectiveImpl
(de.bahntechnik.dd.opn.ui.perspective) Context, variables: [])},
renderer:
(de.bahntechnik.dd.opn.ui.perspective) Context, variables: [])} to
handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@2bd2fa2c
!STACK 0
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showElementRecursive(LazyStackRenderer.java:238)
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showElementRecursive(LazyStackRenderer.java:284)
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showElementRecursive(LazyStackRenderer.java:290)
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.showTab(LazyStackRenderer.java:162)
org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:88)
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4813)
org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher$12.widgetSelected(PerspectiveSwitcher.java:593)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4410)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4228)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3816)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Does any one have an idea how to overcome this error?
I tried to find the console be EPartService but could not get hold of an
instance of EPartService as injection works only for framework created
object. But my ConsleHelper class is not instantiated by the framework.
Martin
Previous Topic:How to add a banner to an e4 application
Next Topic:Get position or triggering mouse event of MPopupMenu
Current Time: Tue Nov 04 12:39:10 EST 2025
Powered by FUDForum. Page generated in 0.02310 seconds
