Home » Archived » AMW » Is aspect-oriented modelling possible in papyrus?(How to add aspect-oriented modelling concept in state machine )
icon3.gif  Is aspect-oriented modelling possible in papyrus? [message #1739850] Fri, 05 August 2016 00:13 Go to next message
Hello, I am new in papyrus modelling. I am wondering how to do aspect-oriented modelling in papyrus state machine. I have some state machine. where each state has it's own state invariant. Apart from this, there is a number of constraints that act as state invariant in multiple states. So, adding all of those constraints as state invariant in each of those states would make the state machine more complex and messy. Probably, aspect-oriented modelling is a better option in this scenario. So, a single constraint can be added to the state invariant of states of the same aspect. i.e., the complete state invariant of a state would be its own state invariant and the constraint from the aspect.
Is this possible in papyrus? Any idea how to do this? Any suggestion? Thank you.
Re: Is aspect-oriented modelling possible in papyrus? [message #1739926 is a reply to message #1739850] Fri, 05 August 2016 13:35 Go to previous message
Dear Syed,
with AMW it is possible to create a model with annotations or constrains over one or more (meta) models. However, it is not integrated with Papyrus.
I suggest that you check with the Papyrus forum (https://www.eclipse.org/forums/index.php/f/121/) about any solution that couples AOP and Papyrus.
Marcos.
Previous Topic:AMW Use Case - Aspect Oriented Modeling
Next Topic:This forum has been archived
Current Time: Fri Nov 07 15:31:10 EST 2025
Powered by FUDForum. Page generated in 0.02952 seconds
