Home » Modeling » TMF (Xtext) » First xtext project (First xtext project throws error can't find org.eclipse.ui.ide)
First xtext project [message #1739834] |
Thu, 04 August 2016 16:23  |
Its my first xtext project and I am simply running the "15 Minutes Tutorial". When I get to the section: "Run the Generated Eclipse Plug-in" I get an error saying "Could not resolve module: org.eclipse.ui.ide". Of course, the module is present in my $HOME/.p2/pool/plugins directory
I'm running eclipse neon and xtext appears to be v2.10.0.
What's going on?
For good measure, Here's the full text of the error:
!SESSION 2016-08-04 16:05:05.345 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_65
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data /Users/gcr1/hopeWorkspace/../ws-cdo.client.example -dev file:/Users/gcr1/hopeWorkspace/.metadata/.plugins/org.eclipse.pde.core/ExampleClient/dev.properties -debug /Users/gcr1/hopeWorkspace/.metadata/.plugins/org.eclipse.pde.core/ExampleClient/.options -os macosx -ws cocoa -arch x86_64 -console
!ENTRY org.eclipse.ui.ide 4 0 2016-08-04 16:05:05.776
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.ide [2]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.106.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui; bundle-version="3.108.0.v20160518-1929"; singleton:="true"
org.eclipse.ui [21]
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.105.0,4.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.ui.workbench; bundle-version="3.108.0.v20160602-1232"; singleton:="true"
org.eclipse.ui.workbench [12]
Unresolved requirement: Import-Package: org.eclipse.e4.core.commands.internal
-> Export-Package: org.eclipse.e4.core.commands.internal; bundle-symbolic-name="org.eclipse.e4.core.commands"; bundle-version="0.11.100.v20160506-0804"; version="0.0.0"; x-friends:="org.eclipse.e4.ui.bindings,org.eclipse.ui.workbench"
org.eclipse.e4.core.commands [39]
Unresolved requirement: Import-Package: org.eclipse.e4.core.contexts
-> Export-Package: org.eclipse.e4.core.contexts; bundle-symbolic-name="org.eclipse.e4.core.contexts"; bundle-version="1.5.0.v20160504-0909"; version="0.0.0"
org.eclipse.e4.core.contexts [80]
Unresolved requirement: Require-Bundle: org.eclipse.e4.core.di
-> Bundle-SymbolicName: org.eclipse.e4.core.di; bundle-version="1.6.0.v20160319-0612"
org.eclipse.e4.core.di [127]
Unresolved requirement: Require-Bundle: org.eclipse.e4.core.di.annotations; bundle-version="[1.4.0,2.0.0)"; visibility:="reexport"
Unresolved requirement: Require-Bundle: org.eclipse.e4.core.di; bundle-version="0.9.0"
Unresolved requirement: Import-Package: org.eclipse.e4.core.services.log
-> Export-Package: org.eclipse.e4.core.services.log; bundle-symbolic-name="org.eclipse.e4.core.services"; bundle-version="2.0.100.v20160509-1032"; version="0.0.0"; x-friends:="org.eclipse.e4.ui.bindings, org.eclipse.e4.ui.services, org.eclipse.e4.ui.workbench, org.eclipse.e4.ui.workbench.renderers.swt, org.eclipse.e4.ui.workbench.swt, org.eclipse.ui.workbench"
org.eclipse.e4.core.services [63]
-> Export-Package: org.eclipse.e4.core.commands; bundle-symbolic-name="org.eclipse.e4.core.commands"; bundle-version="0.11.100.v20160506-0804"; version="0.0.0"; x-friends:="org.eclipse.e4.ui.bindings, org.eclipse.e4.ui.workbench, org.eclipse.e4.ui.workbench.renderers.swt, org.eclipse.ui.workbench, org.eclipse.e4.ui.workbench.swt, org.eclipse.e4.ui.progress, org.eclipse.e4.core.commands.tests"
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.7.0,4.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.emf.cdo.ui 4 0 2016-08-04 16:05:05.780
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.cdo.ui [7]
Unresolved requirement: Require-Bundle: org.eclipse.emf.ecp.edit; bundle-version="[1.5.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.emf.ecp.edit.swt; bundle-version="[1.5.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.emf.ecp.ui.view.swt; bundle-version="[1.5.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.5.0,4.0.0)"; visibility:="reexport"
org.eclipse.ui [21]
Unresolved requirement: Require-Bundle: org.eclipse.net4j.util.ui; bundle-version="[3.0.0,4.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.net4j.util.ui; bundle-version="3.6.0.qualifier"; singleton:="true"
org.eclipse.net4j.util.ui [118]
Unresolved requirement: Require-Bundle: org.eclipse.ui.views; bundle-version="[3.5.0,4.0.0)"; visibility:="reexport"; resolution:="optional"
-> Bundle-SymbolicName: org.eclipse.ui.views; bundle-version="3.8.100.v20160518-1929"; singleton:="true"
org.eclipse.ui.views [14]
Unresolved requirement: Require-Bundle: org.eclipse.net4j.ui.shared; bundle-version="[4.0.0,5.0.0)"
-> Bundle-SymbolicName: org.eclipse.net4j.ui.shared; bundle-version="4.3.100.qualifier"; singleton:="true"
org.eclipse.net4j.ui.shared [119]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.6.0,4.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.emf.cdo.transfer.ui; bundle-version="[4.2.0,5.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.emf.cdo.transfer.ui; bundle-version="4.2.300.qualifier"; singleton:="true"
org.eclipse.emf.cdo.transfer.ui [124]
Unresolved requirement: Require-Bundle: org.eclipse.ui.navigator; bundle-version="[3.5.0,4.0.0)"; resolution:="optional"
-> Bundle-SymbolicName: org.eclipse.ui.navigator; bundle-version="3.6.100.v20160518-1929"; singleton:="true"
org.eclipse.ui.navigator [47]
Unresolved requirement: Require-Bundle: org.eclipse.emf.cdo.ui.shared; bundle-version="[4.1.0,5.0.0)"
-> Bundle-SymbolicName: org.eclipse.emf.cdo.ui.shared; bundle-version="4.3.0.qualifier"; singleton:="true"
org.eclipse.emf.cdo.ui.shared [83]
Unresolved requirement: Require-Bundle: org.eclipse.net4j.ui.shared; bundle-version="[4.1.0,5.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench.texteditor; bundle-version="[3.5.0,4.0.0)"; resolution:="optional"
-> Bundle-SymbolicName: org.eclipse.ui.workbench.texteditor; bundle-version="3.10.0.v20160530-2011"; singleton:="true"
org.eclipse.ui.workbench.texteditor [36]
Unresolved requirement: Require-Bundle: org.eclipse.emf.cdo.ui.shared; bundle-version="[4.0.0,5.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.emf.edit.ui; bundle-version="[2.5.0,3.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.emf.edit.ui; bundle-version="2.12.0.v20160526-0356"; singleton:="true"
org.eclipse.emf.edit.ui [75]
Unresolved requirement: Require-Bundle: org.eclipse.ui.views; bundle-version="[3.4.0,4.0.0)"; visibility:="reexport"
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.5.0,4.0.0)"; visibility:="reexport"
!ENTRY org.eclipse.ui.workbench 4 0 2016-08-04 16:05:05.795
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.workbench [12]
!ENTRY org.eclipse.ui 4 0 2016-08-04 16:05:05.797
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui [21]
!ENTRY org.eclipse.ui.intro 4 0 2016-08-04 16:05:05.799
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.intro [22]
Unresolved requirement: Import-Package: org.eclipse.e4.core.di.annotations
!ENTRY org.eclipse.e4.ui.model.workbench 4 0 2016-08-04 16:05:05.801
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.model.workbench [24]
Unresolved requirement: Require-Bundle: org.eclipse.e4.core.contexts; bundle-version="1.0.0"
-> Bundle-SymbolicName: org.eclipse.e4.core.contexts; bundle-version="1.5.0.v20160504-0909"
Unresolved requirement: Require-Bundle: org.eclipse.e4.core.services; bundle-version="0.9.0"
-> Bundle-SymbolicName: org.eclipse.e4.core.services; bundle-version="2.0.100.v20160509-1032"; singleton:="true"
!ENTRY org.eclipse.net4j.ui 4 0 2016-08-04 16:05:05.805
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.net4j.ui [30]
org.eclipse.ui [21]
!ENTRY org.eclipse.emf.cdo.examples.client 4 0 2016-08-04 16:05:05.812
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.cdo.examples.client [32]
Unresolved requirement: Require-Bundle: org.eclipse.emf.cdo.ui; bundle-version="[4.0.0,5.0.0)"
-> Bundle-SymbolicName: org.eclipse.emf.cdo.ui; bundle-version="4.5.0.qualifier"; singleton:="true"
org.eclipse.ui [21]
Unresolved requirement: Require-Bundle: org.eclipse.emf.cdo.ui.admin; bundle-version="[4.0.0,5.0.0)"
-> Bundle-SymbolicName: org.eclipse.emf.cdo.ui.admin; bundle-version="4.1.300.qualifier"; singleton:="true"
org.eclipse.emf.cdo.ui.admin [106]
Unresolved requirement: Require-Bundle: org.eclipse.net4j.ui; bundle-version="[4.0.0,5.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.net4j.ui; bundle-version="4.2.300.qualifier"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.emf.cdo.ui; bundle-version="[4.0.0,5.0.0)"; visibility:="reexport"
Unresolved requirement: Require-Bundle: org.eclipse.ui.ide.application; bundle-version="[1.0.0,2.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.ide.application; bundle-version="1.1.100.v20160518-1929"; singleton:="true"
org.eclipse.ui.ide.application [42]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.workbench
-> Bundle-SymbolicName: org.eclipse.e4.ui.workbench; bundle-version="1.4.0.v20160517-1624"; singleton:="true"
org.eclipse.e4.ui.workbench [95]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.model.workbench; bundle-version="1.2.0"
-> Bundle-SymbolicName: org.eclipse.e4.ui.model.workbench; bundle-version="1.2.0.v20160229-1459"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.services; bundle-version="0.9.0"
-> Bundle-SymbolicName: org.eclipse.e4.ui.services; bundle-version="1.2.100.v20160506-0759"; singleton:="true"
org.eclipse.e4.ui.services [107]
Unresolved requirement: Require-Bundle: org.eclipse.ui.navigator.resources; bundle-version="[3.4.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.navigator.resources; bundle-version="3.5.100.v20160518-1929"; singleton:="true"
org.eclipse.ui.navigator.resources [71]
Unresolved requirement: Require-Bundle: org.eclipse.ui.ide; bundle-version="[3.6.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.ide; bundle-version="3.12.0.v20160601-1609"; singleton:="true"
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2016-08-04 16:05:05.814
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.workbench.texteditor [36]
org.eclipse.ui [21]
!ENTRY org.eclipse.ui.ide.application 4 0 2016-08-04 16:05:05.817
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.ide.application [42]
org.eclipse.ui [21]
!ENTRY org.eclipse.e4.ui.di 4 0 2016-08-04 16:05:05.818
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.di [43]
Re: First xtext project [message #1739897 is a reply to message #1739896] |
Fri, 05 August 2016 09:40  |
Geoffry Roberts <forums-noreply@xxxxxxxx> wrote:
> That was the first thing I tried. I did nothing but follow the xtext
> tutorial. Could the tutorial be out of date? I was commenting how
> things have changed. In my new installation, there are no plugins in the
> installation. They now are all in this .p2 directory. I've been
> Googling and everything I find seems dated.
Did you try a fresh workspace or a fresh eclipse
Current Time: Sat Apr 19 08:47:27 EDT 2025
Powered by FUDForum. Page generated in 0.03869 seconds
