Home » Eclipse Projects » P2 » empty build.jars target(What properties should be set in build.properties in order to avoid empty build.jars target)
empty build.jars target [message #1739822] Thu, 04 August 2016 14:19
Hello to the forum members,
I am writing a build script for my feature, which contains a single plugin. For some reason, the generated build.xml for the plugin has build.jars empty, so the plugin is not build and bin folder is not created.
If you have idea what is missing, I'll be grateful if you could share here.
Gidi
[Updated on: Sun, 07 August 2016 03:42] by Moderator
Previous Topic:Picking Plugins outside eclipse folder @ Headless Build
Next Topic:How to set system environment variable eclipse configuration file?
Current Time: Sun Nov 09 01:48:05 EST 2025
Powered by FUDForum. Page generated in 0.02541 seconds
