Re: Eclipse MARS (neon) [message #1739571 is a reply to message #1739544] |
Wed, 03 August 2016 05:46 |
Ed Merks Messages: 33142 Registered: July 2009 |
Yes, I've not been able to get the full IDE running with Java 9. There
are definitely some OSGi problems with that. Primarily for the
installer the problem looked to be related to the version numbers.
I.e., up to now, the Java versions were 1.7.0, 1.8.0, but for Java 9, it
appears to be 9-ea.
$./java -version
java version "1.7.0_79"
Java(TM) SE Runtime Environment (build 1.7.0_79-b15)
Java HotSpot(TM) 64-Bit Server VM (build 24.79-b02, mixed mode)
$./java -version
java version "9-ea"
Java(TM) SE Runtime Environment (build 9-ea+118)
Java HotSpot(TM) 64-Bit Server VM (build 9-ea+118, mixed mode)
This also prevented the installer from working but we fixed the way we
parsed the version string to produce 9.0.0.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=493759
But there's still https://bugs.eclipse.org/bugs/show_bug.cgi?id=493761
open for the platform itself.
On 02.08.2016 21:12, Eric Rizzo wrote:
> JDK 9 is implementing JSR 376 modularity
> (http://openjdk.java.net/jeps/200) - I suspect this has something to
> do with that, as perhaps javax injection/annotations is not included
> in the default modules <shrug>
> Eclipse Neon is not tested on Java 9 as far as I know, so follow
> Nitin's advice and run it in JDK 8.
Ed Merks
FUDForum. Page generated in 0.04817 seconds
