Home » Eclipse Projects » OM2M » OM2M on Android
OM2M on Android [message #1738401] Tue, 19 July 2016 13:06 Go to next message
Can LIU is currently offline Can LIUFriend
Hi guys,
Do you guys know that it is possible to run OM2M on Android platform?
Thanks in advance !
Can
Re: OM2M on Android [message #1738471 is a reply to message #1738401] Wed, 20 July 2016 07:28 Go to previous messageGo to next message
Thierry Monteil is currently offline Thierry MonteilFriend
Member
Hi Can,
We have done three years ago an LAAS experimental version of OM2M 0.8 on android. The main problem was that OM2M was based on OSGI. So on this version, we had removed OSGI framework to be more compliant with the android philosophy. On the eclipse version will also have also a difficulty with the database connexion based on eclipselink. So conclusion is, if you want to run eclipse OM2M on android there are several adaptations and development to do.
Thierry.
Re: OM2M on Android [message #1738520 is a reply to message #1738471] Wed, 20 July 2016 13:48 Go to previous messageGo to next message
hello thierry,
Thank you so much for your response. Smile
So recently, all the cellphone applications integrates into OM2M as an IN-AE, not a ASN? And the communication between cellphone application and In-CSE must to use REST API?
Thanks in advance!
Can
[Updated on: Wed, 20 July 2016 13:49]
Report message to a moderator
Re: OM2M on Android [message #1738793 is a reply to message #1738520] Sun, 24 July 2016 17:41 Go to previous message
Member
it depends on what you like to do. The simplest way is to create a ASN but if you need to have OneM2M common service, you will create an ADN or a MN.
Thierry.
Previous Topic:Subscriptions
Next Topic:Source code for OM2M v0.8
Current Time: Tue Oct 03 02:04:10 GMT 2023
Powered by FUDForum. Page generated in 0.02253 seconds
