Home » Eclipse Projects » EclipseLink » Persist @ElementCollection Map - The list of fields to insert into the table is empty
Persist @ElementCollection Map - The list of fields to insert into the table is empty [message #1737918] Thu, 14 July 2016 03:23 Go to next message
Hello everyone,
I have fallowing table with user properties: ID_USER, KEY, VALUE, where the PK is {ID_USER,KEY}
The entity looks like:
@Entity
@Table(name = "USER_PROPERTIES")
public class UserProperties implements Serializable {
    @Id
    @GeneratedValue(strategy = GenerationType.IDENTITY)
    @Column(name = "ID_USER")
    private Integer id;
    @ElementCollection
    @MapKeyColumn(name = "[key]", table = "USER_PROPERTIES")
    @Column(name = "[value]", table = "USER_PROPERTIES")
    @CollectionTable(name = "USER_PROPERTIES", joinColumns = @JoinColumn(name = "ID_USER"))
    private Map<String, String> properties = new HashMap<>();
    public Integer getId() {
        return id;
    public void setId(Integer id) {
        this.id = id;
    public Map<String, String> getProperties() {
        return properties;
    public void setProperties(Map<String, String> properties) {
        this.properties = properties;
I can successfully read these entity instances from database, but I am not able to save such entity.
Trying fallowing code:
UserProperties up= new UserProperties();
up.getProperties().put(UserPropertiesKeys.FIRST_NAME.toString(), response.getFirst("fName"));
up.getProperties().put(UserPropertiesKeys.LAST_NAME.toString(), response.getFirst("lName"));
up.getProperties().put(UserPropertiesKeys.COMPANY.toString(), response.getFirst("company"));
up.getProperties().put(UserPropertiesKeys.EMAIL.toString(), response.getFirst("mail"));
up.getProperties().put(UserPropertiesKeys.PHONE.toString(), response.getFirst("phone"));
em.persist(up);
I am getting fallowing exception:
(Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.QueryException
Exception Description: The list of fields to insert into the table [DatabaseTable(USER_PROPERTIES)] is empty.  You must define at least one mapping for this table.
Query: InsertObjectQuery(null)
The entity before saving looks like this (in JSON):
{"properties":{"mail":"mail@mail.com","first_name":"testt","phone":"987654","company":"cmp","last_name":"test"}}
What am I doing wrong? Can you please explain me how to persist such map?
Any help greatly appreciated!
Re: Persist @ElementCollection Map - The list of fields to insert into the table is empty [message #1738870 is a reply to message #1737918] Mon, 25 July 2016 11:51 Go to previous message
I'm not sure what you are after, but you should not be trying to use an ElementCollection to store properties on what appears to be the same table your UserProperties entity is mapped to. Any entries in your element collection will be read in as entities and collection elements.
Try creating a new table for the elementcollection mapping.
Previous Topic:ClassDescriptor.getPrimaryKeyFieldNames() (Dynamic MOXy)
Next Topic:Access raw unmapped data from Entity
Current Time: Thu Nov 06 07:55:40 EST 2025
Powered by FUDForum. Page generated in 0.02852 seconds
