Home » Modeling » TMF (Xtext) » Problem with ecore and the new generator
Problem with ecore and the new generator [message #1737848] Wed, 13 July 2016 09:40 Go to next message
I have problems with the new Xtext Generator from Xtext 2.10. It seams like there is a problem with the import of the Ecore metamodel. Using the old workflow everything works fine. Do I have to add something new? It is probably some small change I have to make, but I don't find a solution.
My grammar:
// automatically generated by Xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.example.org/testModel"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Document returns Document:
	{Document}
	'Document'
	name=ID
	('pages' '{' pages+=Page ("," pages+=Page)* '}')?
Page returns Page:
	{Page}
	'Page'
	name=ID
	('attributes' '{' attributes+=Attribute ("," attributes+=Attribute)* '}')?
Attribute returns Attribute:
	{Attribute}
	'Attribute'
	name=ID
	('type' type=[ecore::EClassifier|ID])?
My workflow:
module org.xtext.example.mydsl.GenerateMyDsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "org.xtext.example.mydsl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "org.xtext.example.mydsl.MyDsl"
			fileExtensions = "mydsl"
			referencedResource = "platform:/resource/TestModel/model/testModel.genmodel"
			fragment = ecore2xtext.Ecore2XtextValueConverterServiceFragment2 auto-inject {}
			fragment = org.eclipse.xtext.generator.adapter.FragmentAdapter {
				fragment = org.eclipse.xtext.generator.ecore2xtext.FormatterFragment {}
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
Part of the error message where the ecore model fails:
[TransformationDiagnostic: null:28 Cannot find compatible feature type in sealed EClass Attribute from imported package http://www.example.org/testModel: The existing reference 'type' has an incompatible type 'null'. The expected type is 'EClassifier' [org.eclipse.emf.ecore.EClassifier]. (ErrorCode: CannotCreateTypeInSealedMetamodel)]
The full error:
0    [main] INFO  text.xtext.generator.XtextGenerator  - Initializing Xtext generator
6    [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
98   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.example.mydsl at 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl/'
98   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.example.mydsl.tests at 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl.tests/'
99   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.example.mydsl.ide at 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl.ide/'
99   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.example.mydsl.ui at 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl.ui/'
99   [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project org.xtext.example.mydsl.ui.tests at 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl.ui.tests/'
106  [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
388  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
390  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
403  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
403  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
426  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.example.org/testModel' from 'platform:/resource/TestModel/model/testModel.genmodel'
426  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/emf/2002/Ecore' from 'platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel'
529  [main] ERROR xt.generator.XtextGeneratorLanguage  - [TransformationDiagnostic: null:28 Cannot find compatible feature type in sealed EClass Attribute from imported package http://www.example.org/testModel: The existing reference 'type' has an incompatible type 'null'. The expected type is 'EClassifier' [org.eclipse.emf.ecore.EClassifier]. (ErrorCode: CannotCreateTypeInSealedMetamodel)]
531  [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - Problems running workflow org.xtext.example.mydsl.GenerateMyDsl: Problem parsing 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl/../org.xtext.example.mydsl/src/org/xtext/example/mydsl/MyDsl.xtext':
java.lang.RuntimeException: Problems running workflow org.xtext.example.mydsl.GenerateMyDsl: Problem parsing 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl/../org.xtext.example.mydsl/src/org/xtext/example/mydsl/MyDsl.xtext':
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
Caused by: java.lang.IllegalStateException: Problem parsing 'file:/C:/Users/jekkt/workspace/ScenarioTools-Neon-OCL/org.xtext.example.mydsl/../org.xtext.example.mydsl/src/org/xtext/example/mydsl/MyDsl.xtext':
	at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage.initialize(XtextGeneratorLanguage.java:272)
	at org.eclipse.xtext.xtext.generator.StandardLanguage.initialize(StandardLanguage.java:169)
	at org.eclipse.xtext.xtext.generator.XtextGenerator.initialize(XtextGenerator.java:176)
	at org.eclipse.xtext.xtext.generator.XtextGenerator.checkConfigurationInternal(XtextGenerator.java:120)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent2.checkConfiguration(AbstractWorkflowComponent2.java:21)
	at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:65)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.preInvoke(AbstractWorkflowComponent.java:197)
	at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.preInvoke(AbstractCompositeWorkflowComponent.java:29)
	at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:18)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
	... 4 more
  • Attachment: projects.zip
    (Size: 51.37KB, Downloaded 187 times)
Re: Problem with ecore and the new generator [message #1737852 is a reply to message #1737848] Wed, 13 July 2016 10:00 Go to previous messageGo to next message
i guess the problem is this one:
does this come from your genmodel?
can you please file a ticket at https://github.com/eclipse/xtext-core/issues/
i asume we have to circumvent loading this genmodel.
with a sample ecore and genmodel attached?
Re: Problem with ecore and the new generator [message #1738007 is a reply to message #1737852] Thu, 14 July 2016 19:01 Go to previous messageGo to next message
I think this comes form the GenModel or the Xtext generator.
Since my grammar (and my model) uses ecore::EClassifier, the Ecore GenModel is needed to generate the language artifacts.
Yes I can file a ticket there.
Do you think this is a bug in the Xtext generator itself?
Re: Problem with ecore and the new generator [message #1738015 is a reply to message #1738007] Fri, 15 July 2016 01:52 Go to previous messageGo to next message
Yes
Re: Problem with ecore and the new generator [message #1738407 is a reply to message #1738015] Tue, 19 July 2016 09:32 Go to previous message
Here is the link to the Issue: https://github.com/eclipse/xtext-core/issues/41
I hope this is enough and someone can look over this soon Smile
Previous Topic:Xtext external character as part of terminal rule?
Next Topic:referencing existing ecore-model from xtext
Current Time: Mon May 12 05:48:05 EDT 2025
Powered by FUDForum. Page generated in 0.49930 seconds
