Re: Limitation of RMT_DEV [message #1737406 is a reply to message #1737352] |
Thu, 07 July 2016 20:26 |
no there shouldn't be a limit. I tried myself and noticed that when you start a new project and start to drag in devices that 4diac-ide hangs always with the 22nd device.
Digging a bit further I found that the problem is in the random color generation. It looks like the algorithm used does not find a color with enough difference between the existing devices' colors and any new one. I have to reasearch a bit what a better color comparing algorithm would be.
Alois
Re: Limitation of RMT_DEV [message #1737623 is a reply to message #1737620] |
Mon, 11 July 2016 11:13 |
Dear Wolfgang,
yesterday evening i posted a first fix. With a better color generation algorithm and better comparision. In the next RC you should be able to use at least 100 devices and it can be expanded to more if necessary.
BR,
Alois
Re: Limitation of RMT_DEV [message #1737981 is a reply to message #1737960] |
Thu, 14 July 2016 15:56 |
You can have a look in the docs on how to compile 4diac-ide from source. It is rather straight forward (if you are not on Mac as I learned today . Furthermore we planned 1.8 RC3 for Monday.
BR,
Alois
FUDForum. Page generated in 0.04553 seconds
