CDO mapping with UUIDs [message #1737337] |
Thu, 07 July 2016 11:25 |
Jeremy Di Terlizzi Messages: 4 Registered: July 2016 |
Hi everyone, i'm working on a project which is supposed to use CDO to create a single file containing all the objects that are processed and used. It is currently based on 2 main files defining the objects and a third one using them.
Actually, the import of those resources on the server isn't an issue but the export of these resources is one.
I'm trying to create a single xmi resource containing the 3 resources from the server but i'm encountering some issues :
- i can't find a way to use the UUID of the objects as the mapping reference, since the project actually is based on this
- can't save it properly in an xmi file (xml or whatever) it only saves one of the referencing resource
Is there at least a way to set the id of the objects as their uuid?
Thanks for answering.
[Updated on: Fri, 08 July 2016 08:07] Report message to a moderator
Re: CDO mapping with UUIDs [message #1737469 is a reply to message #1737337] |
Fri, 08 July 2016 13:22 |
Hi Jeremy,
Most of what you explain is not fully clear to me. More comments below...
Cheers
/Eike
http://www.esc-net.de
Am 07.07.2016 um 20:58 schrieb Jeremy Di Terlizzi:
Do you mean file system files? How would that relate to CDO?
A resource can't contain other resources. Do you mean to create a file resource that contains (copies of) all root
objects of some CDO resources?
Are you actually using UUIDs? Or counter IDs?
What is a "mapping reference" and why do you need it?
What is a "project" in this context?
I have no idea what exactly you're trying to do. Maybe a test case or some source snippets can shed more light on it?
> Is there at least a way to set the id of the objects as their iduu?
If you're really using UUIDs (i.e., client-side assigned CDOIDs), you can hook up your own CDOIDGenerator via:
org.eclipse.emf.cdo.session.CDOSessionConfiguration.setIDGenerator(CDOIDGenerator)
Cheers
/Eike
Re: CDO mapping with UUIDs [message #1737471 is a reply to message #1737469] |
Fri, 08 July 2016 13:41 |
Hi Eike, thanks for answering. Well you were right i didn't explain it correctly and apologize.
Let's explain it again :
I have 3 CDOResources. One of them contains EObjects that refer to those contained in the other ones.
I am trying to put the whole content (all the EObjects) of these CDOResources in a single xmi Resource, so that the references will mention objects that are contained in this Resource (and i will get rid of the uri, nsuri or whatever taht were used before).
But CDO maps these objects using its own generated ids, while i'm using something else that he can understand because all the references he makes are correct.
Example :
- In the XMI Resource before importing it to the CDO Server:
<blablabla UUID="This_Is_An_UUID_1">
<blablabla UUID="This_Is_An_UUID_2">
<bla href="This_Is_An_UUID_1">
- In the CDOResource :
<blablabla xmi:id="L25628" UUID="This_Is_An_UUID_1">
<blablabla xmi:id="L25629" UUID="This_Is_An_UUID_2">
<bla href="L25628">
So, is there any way to make the server not use its own ids and use for example the UUID i generated before putting it all on the server?
Well i hope this will be clear enough x)
Edit :
I actually use an emfmodel that already had its own generated id attributes (corresponding to the UUIDs in the example) . Is it possible to make CDO use this attribute instead of adding its generated xmi:id ?
Because this one makes the exported XMI Resource noncompliant with the models.
[Updated on: Fri, 08 July 2016 14:45] Report message to a moderator
Re: CDO mapping with UUIDs [message #1737564 is a reply to message #1737471] |
Sun, 10 July 2016 05:41 |
Am 08.07.2016 um 16:41 schrieb Jeremy Di Terlizzi:
So let me first ask, does your export code work or not? E.g, are all the cross references serialized correctly?
That seems unrelated.
Who is he? Do I know him?
More importantly, why does it matter how CDO internally identifies objects? Compare it to a normal Java object; you can
put it in any number of maps, each for its own purpose and with its own key set.
> Example : - In the XMI Resource before importing it to the CDO Server:
> - In the CDOResource : <blablabla xmi:id="L25628" UUID="This_Is_An_UUID_1">
Well, this is clearly an XMI text and not a CDOResource. How have you created this XMI text? Please provide the code to
prevent further misunderstandings.
> <bla href="L25629">
> all on the server?
Yes, I told you about the CDOIDGenerator and how to hook it up. I forgot to mention that you also need to adjust your
cdo-server.xml *before* the first start of the repo:
<property name="idGenerationLocation" value="CLIENT"/> <!-- Possible values: STORE | CLIENT -->
Not really, but getting closer :P
Cheers
/Eike
Cheers
/Eike
Re: CDO mapping with UUIDs [message #1737655 is a reply to message #1737564] |
Mon, 11 July 2016 15:33 |
After some tests, i figured out the real issue. Sorry for lacking that much of precisions but i couldn't understand a lot of things through this problem.
So, ye you were right, i completely missunderstood the XMI text with the CDOResource and well, the mapping strategy isn't an issue actually i just misunderstood the problem.
The real problem here is that i can't manage to concatenate 3 CDOResources into an other one and save it as a XML file. For some reasons, CDO manages to create a correct CDORessource in its database (the concatenation is correct i've checked it through the CDO Session view) to be exported to a Resource but i can't get a correct Resource.
Here's the export code :
public static void exportCDO()
CDOResource rs1 = getOrCreateResource("res1");
CDOResource rs2 = getOrCreateResource("res2");
CDOResource rs3 = getOrCreateResource("res3");
CDOResource rs4 = getOrCreateResource("res4");
ResourceSet rss = new ResourceSetImpl();
Resource target = rss.createResource(URI.createURI("./output.xml"));
EList<EObject> targetContents = target.getContents();
rs4.addAll( rs1.getContents() );
rs4.addAll( rs2.getContents() );
rs4.addAll( rs3.getContents() );
transaction.commit();
target.getContents().addAll( rs4.getContents() );
target.save(null);
I can't figure out why the file "output.xml" only contains the elements of rs1. I tried a lot of different strategies (copiers, loops for the eobjects...) but none seem to work. Is there a special trick or something to do?
The Resource target only gets the elements that were placed first into rs4, so if i put rs2 first in rs4, target will only get rs2.
By the way, i thought it was a mapping issue because i was saving it through a ByteArray... Sorry for this :/
Re: CDO mapping with UUIDs [message #1737656 is a reply to message #1737564] |
target.save(null);
FUDForum. Page generated in 0.05074 seconds
