| Re: DB2 connect blank [message #1738838 is a reply to message #1737261] |
Mon, 25 July 2016 06:55  |
Hi Ed.
I use BIRT report design to create my reports.
To connect to DB2 databases I use jt400.jar drivers.
I just copy Jt400.jar file to the ...eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_...\drivers directory and works fine.
To create the data source connection right click Data Sources and select New Data Source in the Data Explorer Tab.
In driver class select com.ibm.as400.access.AS400JDBCDriver (v9.9)
Database URL: jdbc:as400:<server_ip>/<database>
User name: <your username to connect the database>
Password: <your password to connect the database>
Click test connection to verify if the connection it's ok.
I hope it helps.
FUDForum. Page generated in 0.02311 seconds
