Home » Eclipse Projects » OM2M » Trouble with dependencies
Trouble with dependencies [message #1736784] Fri, 01 July 2016 12:56 Go to next message
Hi.
I cloned the latest version of the platform as described in the tutorial (before that I installed the eclipse, which is also recommended in the tutorial and comes with installed tycho plugin).
After I cloned and build the platform projects I attempted to add my own IPU plugin. I followed the tutorial and reached the "Add plugin dependencies" where I cant add the org.osgi.util.tracker.
Upon further inspection I noticed some errors in the depepndencies tab, as depicted in this picture.
I already created a few IPU plugins in the past and I had no problems following the tutorial. Would you know what could be causing this?
Thanks in advance!
https://dl.dropboxusercontent.com/u/55075286/Capture.PNG
[Updated on: Fri, 01 July 2016 12:59] by Moderator
Re: Trouble with dependencies [message #1737217 is a reply to message #1736784] Wed, 06 July 2016 09:00 Go to previous messageGo to next message
Which version of Eclipse are your using ?
Could you please try again with Eclipse RCP: Mars or Luna ?
Re: Trouble with dependencies [message #1737226 is a reply to message #1737217] Wed, 06 July 2016 09:27 Go to previous messageGo to next message
I tried using the newest Eclipse version (Neon) and it works. Don't know what the problem was.
Re: Trouble with dependencies [message #1737255 is a reply to message #1737226] Wed, 06 July 2016 11:49 Go to previous message
It is called magic.
Previous Topic:Running mn-cse in virtual machine.
Next Topic:Communication between two plugins
Current Time: Thu Jul 31 09:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.36334 seconds
