Re: Cannot complete the install because one or more required items could not be found [message #1736763 is a reply to message #1736761] |
Fri, 01 July 2016 14:54 |
Am 01.07.2016 um 16:39 schrieb Chandrayya Kumarswamimath:
> Getting the below error while setting up eclipse development platform:
> ERROR: org.eclipse.equinox.p2.director code=10053 Cannot complete the install because one or more required items could not be found.
> at org.eclipse.oomph.targlets.internal.core.TargletContainer.forceUpdate(TargletContainer.java:778)
> at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl$4.run(TargletTaskImpl.java:1128)
> at org.eclipse.oomph.util.pde.TargetPlatformUtil.runWithTargetPlatformService(TargetPlatformUtil.java:119)
> at org.eclipse.oomph.setup.targlets.impl.TargletTaskImpl.perform(TargletTaskImpl.java:1036)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3021)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2964)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4160)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4154)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4152)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2955)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2930)
> at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2861)
> at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:555)
> at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:681)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1467382214442
> ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: Infocenter_feature Feature 1.0.0 (org.eclipse.help.infocenter_feature.feature.group 1.0.0) requires 'org.apache.commons.el 0.0.0' but it could not be found
> ERROR: org.eclipse.equinox.p2.director code=1 Cannot satisfy dependency:
> ERROR: org.eclipse.equinox.p2.director code=0 From: artificial_root 1.0.0.v1467382214442
> ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.help.infocenter_feature.feature.group 0.0.0
> Took 2610 seconds.
> There are failed tasks.
> Press Back to choose different settings or Cancel to abort.
> How to reproduce:
> 1. Download latest eclipse installer (linux 64 bit) from here https://www.eclipse.org/downloads/
> 2. Unzipped tar file and opened installer. When installer opens selected advanced mode, in next page Selected all components under Eclipse platform for commiters.
The next page after switching to advance mode should be "Product" and on that page there is nothing to select "under"
anything.
I can only assume that you made a bunch of selection on the third page "Projects". Is that true?
Not all of these project setups are designed to cooperate nicely and some may even have errors. Most of them are not
maintained by the Oomph team itself.
But in order to understand where the problem is, we need to see what exactly you've done. Can you please attach the
entire install log?
Cheers
/Eike
http://www.esc-net.de
> See
> Click next and finish.
> 3. After finishing I closed the previous dialog and main eclipse window opens again then starts cloning the git repos. After cloning repos I am getting this error.
> I am facing this error few months back also. Repo's were cloned but working sets not created.
> I don't know how to proceed any clues/pointer to trouble shot this issue?
Cheers
/Eike
FUDForum. Page generated in 0.10895 seconds
