Re: Installing epf-composer once for many users [message #33534 is a reply to message #33394] |
Mon, 18 June 2007 21:34 |
Ricardo Balduino Messages: 191 Registered: July 2009 |
John,
You can unzip the published web site in a network drive or deploy to a web
server and have multiple users browsing through it using an Internet
browser.
For the library, you can have it unzipped to a network drive too, but if you
are going to allow multiple users to edit the library using EPF Composer,
you want to have the library under a version control system. For more
information, see "Using EPF Composer with a Version Control System" at
http://www.eclipse.org/epf/general/documentation.php.
Ricardo Balduino
IBM | EPF Committer
"John A. Murdie" <john@cs.york.ac.uk> wrote in message
news:420b376198b7aa877269f8add73a26cc$1@www.eclipse.org...
> Someone here has asked me for EPF Composer on Linux. I've unpacked
> epf-composer-1.0.2-linux.tar.gz under a Linux file server directory
> /usr/local/pkg/epf-composer-1.0.2 visible to all our Linux desktop clients
> here. I've arranged that a two-line shell script be callable as
> /usr/local/bin/epf which calls /usr/local/pkg/epf-composer-1.0.2/epf - and
> this starts fine. I'm wondering how similarly to make one copy of OpenUP,
> XP and Scrum available to all the Linux clients.
> I've read the installation instructions on the download pages for OpenUP,
> XP and Scrum on
> http://www.eclipse.org/epf/downloads/openup/openup_downloads .php,
> http://www.eclipse.org/epf/downloads/xp/xp_downloads.php and
> http://www.eclipse.org/epf/downloads/scrum/scrum_downloads.p hp,
> respectively. Taking OpenUp as an example, which has files
> OpenUP_Basic_published-0.9-20061002.zip and
> OpenUP_library-0.9-20061002.zip. The instructions say:
>>Published Web site
>> 1. Delete previous installations of the published web site.
>> 2. Unzip the downloaded zip file.
>> 3. This creates the following folder structure: "Publish\". Go into
> this directory and launch index.html.
>>Method Library
>> 1. Delete previous installations of the method library.
>> 3. Open EPF Composer, menu File->Open, then point to the folder
>> where
> you unzipped the library (where library.xmi file is)
> Does each user have to make a copy of each of the two zip files in their
> own directory, unzip them and follow the instructions above to make them
> available to EPF Composer? Or can I unpack the files once for all users to
> share? Such shared files are usually owned by user 'bin'.
Re: Installing epf-composer once for many users [message #579082 is a reply to message #33394] |
John,
browser.
Ricardo Balduino
IBM | EPF Committer
> XP and Scrum on
>>Published Web site
>>Method Library
>> where
FUDForum. Page generated in 0.03463 seconds
