Home » Modeling » TMF (Xtext) » No JVM Operators XExpressionOrVarDeclaration (Can't use var x = 1 +2 regradless of grammer edits or infer)
No JVM Operators XExpressionOrVarDeclaration [message #1736367] Tue, 28 June 2016 18:07 Go to next message
i'm a beginner at Xtext and i have the following grammer nearly identical to Tortoise language(one of 7 Languages )
grammar xjad.Opponent with org.eclipse.xtext.xbase.Xbase
generate opponent "http://www.Opponent.xjad"
import "http://www.eclipse.org/xtext/xbase/Xbase"
Program :
  subPrograms+=SubProgram*
  body=Body
SubProgram:
	'Node'  type=JvmTypeReference name=ID MAC=STRING  IP=STRING
Body returns XBlockExpression:
  {XBlockExpression}
  'begin'
  (expressions+= XExpressionOrVarDeclaration ';'?)*
  'end';
var alpha = 1 + 2; //Fails with + cannot be resolved.
The following is the inferance engine
public static val INFERRED_CLASS_NAME = 'OpponentProgram'
	final String ImplicitSocketName = "ImplicitSocket";
	def dispatch void infer(Program program, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
		acceptor.accept(program.toClass(INFERRED_CLASS_NAME)) [
			members += toField(ImplicitSocketName,typeRef(UsbSocket))[
					static = true
					final =true
					initializer = '''new UsbSocket()'''
			for (subp : program.subPrograms) {
				members += subp.toField(subp.name, subp.type) [
					static = true
					final =true
					initializer = '''new «subp.type.qualifiedName»(«ImplicitSocketName»,"«subp.MAC»","«subp.IP»")'''
			if (program.body != null) {
				members += program.toMethod("main", typeRef(Void.TYPE)) [
					parameters += program.toParameter("args", typeRef(String).addArrayTypeDimension)
					static = true
					varArgs = true
					body = program.body
if(y == "ASD") .....
i see the following error in the editor
== cannot be resolved.
and same for any == =< => ++ 1+2 and any similar operation
Re: No JVM Operators XExpressionOrVarDeclaration [message #1736448 is a reply to message #1736367] Wed, 29 June 2016 08:41 Go to previous message
make sure xbase.lib is on the classpath of the model project (the one containing xxxx.yourdsl)
e.g. by adding the libary "xtend" to the java build path of the (java) project
or adding it as required plugin to the (plugin) project
Previous Topic:No operations in Xexpressionorvardeclaration
Next Topic:Automatically Load generated Xtext
Current Time: Tue Sep 02 07:05:35 EDT 2025
Powered by FUDForum. Page generated in 1.03219 seconds
