Home » Newcomers » Newcomers » Eclipse (Neon) Marketplace inaccessible through proxy(Work-around for system-wide proxies works for everything except the Marketplace)
Eclipse (Neon) Marketplace inaccessible through proxy [message #1736261] Tue, 28 June 2016 01:08 Go to next message
Hi guys!
I've just installed Eclipse Neon and unfortunately I can't access the marketplace. We're using a company-wide proxy and there have been problems with previous Eclipse versions as well. However those problems could be circumvented by setting the parameter
Dorg.eclipse.ecf.provider.filetransfer.excludeContributors=org.eclipse.ecf.provider.filetransfer.httpclient4
at the end of the eclipse.ini (vmargs section).
At a first glance the situation is identical with Neon - without the parameter any connection to the internet fails (proxy authorization required). Once it's set everything seems to work including software updates, reloading available software sites and even browsing with the internal browser.
As soon as I try to open the Marketplace I get an error, though:
Cannot open Eclipse Marketplace
Cannot install remote marketplace locations: Cannot complete request to http:// marketplace.eclipse .org/catalogs/api/p: Unexpected response content: Parse result is null.
Cannot complete request to http://marketplace.eclipse.org/catalogs/api/p: Unexpected response content: Parse result is null.
Received response begins with:
1: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http:// www.w3 .org/TR/html4/loose.dtd">
2: <html>
3:   <head>
I'm pretty certain eclipse should be able to reach the mentioned url - when I try to access it via the internal browser it loads correctly...
Does anyone have any idea what's going wrong? Does the Marketplace handle the connection differently?
(Had to add spaces to the message urls since I'm not allowed to post urls.)
Re: Eclipse (Neon) Marketplace inaccessible through proxy [message #1736271 is a reply to message #1736261] Tue, 28 June 2016 03:39 Go to previous messageGo to next message
I have the same problem. with eclipse mars everything worked perfectly finde but with neon I cannot open the marketplace through the proxy. when I use our guest-Wifi I can enter the marketplace. So it seems to be a proxy problem.
Is there a way to force eclipse neon into using the https-webside?
Re: Eclipse (Neon) Marketplace inaccessible through proxy [message #1736333 is a reply to message #1736261] Tue, 28 June 2016 09:14 Go to previous messageGo to next message
windows 7 64bits
eclipse neon
on my system, the Marketplace shows after a very long time.
I even manage to select projects to install.
but when i click on "install" it fails with a proxy authentification error
Re: Eclipse (Neon) Marketplace inaccessible through proxy [message #1736375 is a reply to message #1736261] Tue, 28 June 2016 21:26 Go to previous messageGo to next message
I'm also experiencing the same problem.
  • behind a corporate firewall
  • added the -Dorg.eclipse.ecf.provider.filetransfer.excludeContributors=org.eclipse.ecf.provider.filetransfer.httpclient4 parameter to eclipse.ini
  • trying to access the marketplace gives the same error
Re: Eclipse (Neon) Marketplace inaccessible through proxy [message #1736382 is a reply to message #1736261] Wed, 29 June 2016 01:43 Go to previous messageGo to next message
I have just filed a bug:
Bug 496968 - [Proxy] Work-around for native proxy setting fails for Marketplace
Let's see if someone can dig into it...
Re: Eclipse (Neon) Marketplace inaccessible through proxy [message #1739495 is a reply to message #1736382] Tue, 02 August 2016 08:47 Go to previous messageGo to next message
There is a patch for the bug, 493014
it work for me, but it is very slow
Re: Eclipse (Neon) Marketplace inaccessible through proxy [message #1740984 is a reply to message #1739495] Mon, 22 August 2016 03:18 Go to previous messageGo to next message
I have the same problem! with eclipse mars everything worked very good, but with neon I cannot open the marketplace through the proxy (advanced.name/ru). when I use our guest-Wifi I can enter the marketplace. So it seems to be a proxy problem, or is it an error with my settings?
Re: Eclipse (Neon) Marketplace inaccessible through proxy [message #1741234 is a reply to message #1740984] Wed, 24 August 2016 00:55 Go to previous message
Hi Dmitriy,
there is currently a bug fix avaiable for the problem - just follow the link of boris monti's post - in comment #8: "The fix is available on http://download.eclipse.org/mpc/neon".
For me everything works fine with the fix installed.
As far as I know it will be integrated in the next version of Eclipse (presumably 4.6.1).
Previous Topic:Multiple User Installation
Next Topic:New to Eclipse - cannot operate on mac
Current Time: Thu Nov 06 22:16:46 EST 2025
Powered by FUDForum. Page generated in 0.11115 seconds
