Different results between Jenkins and test cases run from RCPTT IDE [message #1735576] |
Tue, 21 June 2016 05:49  |
Hi Folks,
When I run a test from RCPTT_IDE it always PASS.
The same not happened in JENKINS because it FAILS .
The Database and AUT are the same.
How to check it to have the same behavior ?
Please let me know. It is really frustrating.
Thanks in advance.
Angelo Luciani
JENKINS LOG
[INFO] Started at Tue Jun 21 11:00:35 CEST 2016
[INFO] RCPTT Runner version: 2.0.0
[INFO] Initializing target platform...
[INFO] Target platform is valid.
[INFO] Looking for tests...
[INFO] Existing projects in workspace:
[INFO] <none>
[INFO] Importing projects to workspace:
[INFO] Refreshing projects:
[INFO] C:\rcptt_tests_cases\Optimization\target\projects\productTests... OK
[INFO] C:\rcptt_tests_cases\Compliance\compliance... OK
[INFO] Optimization... OK
[INFO] compliance... OK
[INFO] Searching for tests in projects:
[INFO] -- Testcase is skiped by tag "GC_1.1.1_create_a_constraint_folder" -- GC_1.1.1_create_a_constraint_folder.test
[INFO] -- Testcase is skiped by tag "GC_1.1.1_create_a_constraint_folder" -- GC_1.1.2_edit_a_constraint_folder.test
[INFO] -- Testcase is skiped by tag "GC_1.1.1_create_a_constraint_folder" -- GC_1.1.3_create_a_constraint_subfolder.test
[INFO] -- Testcase is skiped by tag "GC_1.1.1_create_a_constraint_folder" -- GC_1.1.4_delete_a_constraint_folder.test
[INFO] -- Testcase is skiped by tag "GC_1.2.1_add_roles_to_folder_and_subfolder" -- GC_1.2.1_add_roles_to_folder_and_subfolder.test
[INFO] -- Testcase is skiped by tag "GC_1.2.2_add_roles_to_parent_folder" -- GC_1.2.2_add_roles_to_parent_folder.test
[INFO] -- Testcase is skiped by tag "GC_1.2.3_remove_roles_from_parent_folder" -- GC_1.2.3_remove_roles_from_parent_folder.test
[INFO] -- Testcase is skiped by tag "GC_1.3.2_delete_a_global_constraint" -- GC_1.3.2_delete_a_global_constraint.test
[INFO] -- Testcase is skiped by tag "GC_1.4.1_search_in library" -- GC_1.4.1_search_in library.test
[INFO] -- Testcase is skiped by tag "GC_1.5.1_edit_a_global_constraint" -- GC_1.5.1_edit_a_global_constraint.test
[INFO] -- Testcase is skiped by tag "GC_1.5.2_clone_a_global_constraint" -- GC_1.5.2_clone_a_global_constraint.test
[INFO] -- Testcase is skiped by tag "GC_3.1.1_constraint_editor_autocompletion_variables" -- GC_3.1.1_constraint_editor_autocompletion_variables.test
[INFO] -- Testcase is skiped by tag "GC_3.1.2_constraint_editor_autocompletion_constants" -- GC_3.1.2_constraint_editor_autocompletion_constants.test
[INFO] -- Testcase is skiped by tag "GC_3.2.1_constraint_editor_check_syntax" -- GC_3.2.1_constraint_editor_check_syntax.test
[INFO] -- Testcase is skiped by tag "GC_3.2.2_constraint_editor_check_syntax" -- GC_3.2.2_constraint_editor_check_syntax.test
[INFO] -- Testcase is skiped by tag "GC_3.2.3_constraint_editor_check_syntax" -- GC_3.2.3_constraint_editor_check_syntax.test
[INFO] Complete OK
[INFO] No tests found
[INFO] Testcase Artifacts:1
[INFO] AUT-0:Launching
[INFO] AUT-0:Product: xdm.client.rcp.xdm
[INFO] AUT-0:Application: null
[INFO] AUT-0:Architecture: x86_64
[INFO] 64bit arch is selected because
[INFO] - JVM is 64bit
[INFO] - AUT contains both launcher plugins
[INFO] -Equinox launcher
[INFO] - C:plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.100-20120516\
[INFO] - C:plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.100-20120516\
[INFO] C:\rcptt_tests_cases\Optimization\target\aut-ws-0: AUT arguments: "-os ${target.os}" "-ws ${target.ws}" "-arch x86_64" -consoleLog "-console -debug" -user=xdmadmin -pwd=xdm -url=rmi://localhost:12999 -os ${target.os} -arch ${target.arch}
[INFO] C:\rcptt_tests_cases\Optimization\target\aut-ws-0: AUT VM arguments: -Xmx1024m -Xverify:none -XX:MaxPermSize=256M -XX:+UseParallelGC -XX:PermSize=20M -XX:MaxNewSize=32M -XX:NewSize=32M -Duser.language=en -Duser.country=EN -Dosgi.instance.area=@user.home/xdm/workspace -Dosgi.user.area=@user.home/xdm/user -Dosgi.configuration.area=@user.home/xdm/configuration -Dclient.update.memsize=-Xmx128m -DmultiInstance=true -Dorg.eclipse.swt.browser.DefaultType=ie,mozilla -Dorg.eclipse.swt.browser.IEVersion=9999 -Xmx1024m -Xverify:none -XX:MaxPermSize=256M -XX:+UseParallelGC -XX:PermSize=20M -XX:MaxNewSize=32M -XX:NewSize=32M -Duser.language=en -Duser.country=EN -Dosgi.instance.area=@user.home/xdm/workspace -Dosgi.user.area=@user.home/xdm/user -Dosgi.configuration.area=@user.home/xdm/configuration -Dclient.update.memsize=-Xmx128m -DmultiInstance=true -Dorg.eclipse.swt.browser.DefaultType=ie,mozilla -Dorg.eclipse.swt.browser.IEVersion=9999
[INFO] Fail 1 (1) processed. 1 failed. spent: 1:06, 0:00 mins remaining. GC_1.3.1_add_a_global_constraint. time: 30362ms Cause: The Editor "Library : test_folder_pet_costraint" could not be found.
[INFO] Failed Tests:
[INFO] GC_1.3.1_add_a_global_constraint
[INFO] Process terminated. Shut down AUTs
[INFO] Runner exit code is: 56
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 02:47 min
[INFO] Finished at: 2016-06-21T11:03:05+02:00
[INFO] Final Memory: 9M/244M
POM.XML
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<!-- Set artifact id according to a RCPTT project name -->
<artifactId>productTests</artifactId>
<!-- Set group id based on application under test name -->
<groupId>com.company.product</groupId>
<version>2.0.0-SNAPSHOT</version>
<!-- RCPTT Maven Plugin provides this packaging type -->
<packaging>rcpttTest</packaging>
<!-- RCPTT Maven Plugin and RCPTT Runner are hosted in this repository -->
<pluginRepositories>
<pluginRepository>
<id>rcptt-releases</id>
<name>RCPTT Maven repository</name>
<url>https://repo.eclipse.org/content/repositories/rcptt-releases/</url>
</pluginRepository>
<pluginRepository>
<id>rcptt-snapshots</id>
<name>RCPTT Maven Snapshots repository</name>
<snapshots>
<updatePolicy>never</updatePolicy>
</snapshots>
<url>https://repo.eclipse.org/content/repositories/rcptt-snapshots/</url>
</pluginRepository>
</pluginRepositories>
If RCPTT tests are planned to be run on an update site,
RCPTT Maven Plugin can download Eclipse SDK of required version
for current platform from repository below (to see
an up-to-date list of available versions visit this link:
http://maven.xored.com/nexus/content/repositories/ci4rcptt-releases/org/eclipse/sdk/
<properties>
<rcptt-maven-version>2.0.0</rcptt-maven-version>
</properties>
<!-- The main part of RCPTT Maven plugin -->
<build>
<plugins>
<plugin>
<groupId>org.eclipse.rcptt</groupId>
<artifactId>rcptt-maven-plugin</artifactId>
<version>${rcptt-maven-version}</version>
<extensions>true</extensions>
<configuration>
<!-- This element describes where to get an AUT to run tests -->
<aut>
<!-- There are several ways to specify AUT location,
Uncomment an element corresponding to a most suitable way
<!-- Use AUT from current build results. [classifier] will be
automatically replaced according to the current platform -->
<explicit>${project.basedir}/../product/target/products/org.eclipse.ui.examples.rcp.browser.product-[classifier].zip</explicit>
<!-- Or specify a path to AUT folder -->
<explicit>${path-client}</explicit>
<args>
<arg>-os ${target.os}</arg>
<arg>-ws ${target.ws}</arg>
<arg>-arch x86_64 </arg>
<arg> -consoleLog </arg>
<arg> -console -debug </arg>
<arg>${user}</arg>
<arg>${password}</arg>
<arg>${link}</arg>
</args>
<injections>
<!-- features are optional - when omitted, all features from given site will be installed -->
<injection>
<site></site>
<features>
<feature>com.comanyname.featureid</feature>
</features>
</injection>
</injections>
<vmArgs>
<vmArg>-Xmx1024m</vmArg>
<vmArg>-Xverify:none</vmArg>
<vmArg>-XX:MaxPermSize=256M</vmArg>
<vmArg>-XX:+UseParallelGC</vmArg>
<vmArg>-XX:PermSize=20M </vmArg>
<vmArg>-XX:MaxNewSize=32M</vmArg>
<vmArg>-XX:NewSize=32M</vmArg>
<vmArg>-Duser.language=en</vmArg>
<vmArg>-Duser.country=EN</vmArg>
<vmArg>-Dosgi.instance.area=@user.home/xdm/workspace </vmArg>
<vmArg>-Dosgi.user.area=@user.home/xdm/user </vmArg>
<vmArg>-Dosgi.configuration.area=@user.home/xdm/configuration</vmArg>
<vmArg>-Dclient.update.memsize=-Xmx128m </vmArg>
<vmArg>-DmultiInstance=true</vmArg>
<vmArg>-Dorg.eclipse.swt.browser.DefaultType=ie,mozilla</vmArg>
<vmArg>-Dorg.eclipse.swt.browser.IEVersion=9999</vmArg>
</vmArgs>
</aut>
<runner>
<!-- RCPTT Runner location can be set using the same methods
as AUT location:
<explicit>/path/to/rcptt/runner</explicit>
<explicit>C:\Users\angelo.luciani\Downloads\rcptt.runner-2.0.0\eclipse</explicit>
<!-- but the most convenient way is to just set its version,
RCPTT maven plugin will automatically set right groupId and
artifact ID and will download RCPTT Runner from Xored Maven Repo -->
<version>2.0.0</version>
<vmArgs>
<vmArg>-Dosgi.user.area=@user.home/xdm/user</vmArg>
</vmArgs>
</runner>
<!-- Test options for RCPTT Runner, most popular options listed here.
Full list of options is available at:
https://ci.xored.com/doc/runner/
<testOptions>
<!-- Timeout for all tests, in seconds -->
<execTimeout>3600</execTimeout>
<!-- Timeout for a single test case, in seconds -->
<testExecTimeout>1800</testExecTimeout>
<!-- When set to true, in case of test failure
AUT will be restarted. This significantly
slows down execution, but may be useful
for some test suites -->
<restartAUTOnFailure>false</restartAUTOnFailure>
</testOptions>
<!-- By default RCPTT Runner runs tests from a project directory,
but in some cases it might be required to import additional
projects into runner's workspace -->
<projects>
<project>${project.basedir}/../project</project>
</projects>
<projects>
<project>C:\rcptt_tests_cases\Compliance\compliance</project>
</projects>
<!-- By default RCPTT Runner runs all tests from workspace,
but it is possible to pass test suite names, so it
will execute only test suites from given project. -->
<suites>
<suite>optimization</suite>
</suites>
<!-- Sometimes it might be useful to skip a test case
(for instance because of some unresolved bug). RCPTT
can skip tests based on its tags. By default RCPTT skips
tests with tag 'skipExecution' (this value has been
chosen because on one hand it is descriptive enough,
on another hand it is unlikely that this tag name
will collide with some user's tag)
<skipTags>
<skipTag>GC_1.1.1_create_a_constraint_folder</skipTag>
<skipTag>GC_1.1.2_edit_a_constraint_folder</skipTag>
<skipTag>GC_1.1.3_create_a_constraint_subfolder</skipTag>
<skipTag>GC_1.1.4_delete_a_constraint_folder</skipTag>
<skipTag>GC_1.2.1_add_roles_to_folder_and_subfolder</skipTag>
<skipTag>GC_1.2.2_add_roles_to_parent_folder</skipTag>
<skipTag>GC_1.2.3_remove_roles_from_parent_folder</skipTag>
<skipTag>GC_1.3.2_delete_a_global_constraint</skipTag>
<skipTag>GC_1.4.1_search_in library</skipTag>
<skipTag>GC_1.5.1_edit_a_global_constraint</skipTag>
<skipTag>GC_1.5.2_clone_a_global_constraint</skipTag>
<skipTag>GC_3.1.1_constraint_editor_autocompletion_variables</skipTag>
<skipTag>GC_3.1.2_constraint_editor_autocompletion_constants</skipTag>
<skipTag>GC_3.2.1_constraint_editor_check_syntax</skipTag>
<skipTag>GC_3.2.2_constraint_editor_check_syntax</skipTag>
<skipTag>GC_3.2.3_constraint_editor_check_syntax</skipTag>
</skipTags>
<!-- By default RCPTT generates a single HTML report file with
all tests, but it is possible to generate one file per
test -->
<splitHtmlReport>true</splitHtmlReport>
</configuration>
</plugin>
</plugins>
</build>
</project>
[Updated on: Tue, 21 June 2016 06:13] by Moderator
FUDForum. Page generated in 0.03626 seconds
